rednakes1 Posted October 24, 2016 Share Posted October 24, 2016 (edited) Here's a quick power LED mod I did for my 4-switch woody 2600. It's not pretty but it works so far. I didn't want to mess with the original look of my Atari, so I chose not to drill a hole at the top or through the power switch itself. I used a 150 Ohm resistor and used the 5V and Ground on the main board. I didn't want to solder directly to pins 2 and 3 of the voltage regulator but I could have done that instead. The short pin on the LED goes to Ground. I also made sure the wires did not touch the 'heat plate' surrounding the voltage regulator, which can get very hot. Edited October 24, 2016 by rednakes1 5 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted October 24, 2016 Share Posted October 24, 2016 That's pretty cool! Quote Link to comment Share on other sites More sharing options...
robbievgb Posted October 25, 2016 Share Posted October 25, 2016 Yeah this is actually a great idea! Quote Link to comment Share on other sites More sharing options...
Osgeld Posted October 25, 2016 Share Posted October 25, 2016 Yea someone did something similar to a sixer here on the forums I saw it while image searching for different power led ideas, and I like it a lot Quote Link to comment Share on other sites More sharing options...
rednakes1 Posted October 25, 2016 Author Share Posted October 25, 2016 Yea someone did something similar to a sixer here on the forums I saw it while image searching for different power led ideas, and I like it a lot Thanks, yeah I'm sure someone had thought of it before. I've only seen threads with the normal panel-mounted LED and the one where the LED was actually drilled into the switch knob itself - which is pretty clever but I'd be scared to do it myself. This mod of mine doesn't show the actual LED through the gap for the switch; all you see is a bright red light. EDIT: Did a Google image search and looks like bradd1978 had though of this too: http://atariage.com/forums/topic/209603-fsft-atari-2600-vader-with-led-mod/ Quote Link to comment Share on other sites More sharing options...
Osgeld Posted October 25, 2016 Share Posted October 25, 2016 yea that's the one I saw Quote Link to comment Share on other sites More sharing options...
Keatah Posted December 3, 2016 Share Posted December 3, 2016 I like it. Recessed and indirect diffuse lighting looks cool here. Atmospheric and moody if you turn the room lighting down I bet. Quote Link to comment Share on other sites More sharing options...
