T•Rex aka First Attempt at 6507
36 replies to this topic
#26 chavert OFFLINE
chavert
    Moonsweeper
  • 357 posts
Posted Sat Nov 5, 2016 9:45 AM
#27 Secamline OFFLINE
Secamline
    Space Invader
  • 42 posts
Posted Sun Nov 6, 2016 1:05 AM
 I see you're usign a PAL system, should I make a version compatible with PAL and SECAM?
#28 chavert OFFLINE
chavert
    Moonsweeper
  • 357 posts
Posted Sun Nov 6, 2016 2:44 AM
ok, for pal version .please :)
#29 Secamline OFFLINE
Secamline
    Space Invader
  • 42 posts
Posted Sun Nov 6, 2016 6:25 AM
I've added a PAL version, I'd say it's better to play with the difficulty set on A with this one since the game's slower.
#30 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,883 posts
  • Medieval Mayhem
Posted Sun Nov 6, 2016 9:27 AM
Instead of PAL make it PAL60, then the game speed will be the same.  PAL60 = PAL color values with NTSC timing.  For testing in Stella just hit CONTROL-F a few times until you see PAL60:
That's a temporary change, to make it permanent do this:
  • hit TAB
  • click on GAME PROPERTIES
  • click on DISPLAY
  • click on FORMAT
  • select PAL60
  • click OK
  • click on EXIT MENU
  • press CONTROL-R to reload game
For permanent that's just for that specific build of the ROM, if you make a change you'll have to do it again.
#31 Secamline OFFLINE
Secamline
    Space Invader
  • 42 posts
Posted Sun Nov 6, 2016 1:19 PM
But games won't run at 60 fps on a regular European VCS, right?
#32 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,883 posts
  • Medieval Mayhem
Posted Sun Nov 6, 2016 1:29 PM
they will - for the 2600 the game code controls frame rate, not the console.
http://atariage.com/...3459-pal60-roms
#33 Secamline OFFLINE
Secamline
    Space Invader
  • 42 posts
Posted Mon Nov 7, 2016 12:28 AM
So if I just replace the colours with their PAL counterparts, and keep the number of scanlines at 262, a real PAL hardware will display the game in full screen, at 50 fps? (I'd like to try it by myself but I don't own a harmony cart)
#34 chavert OFFLINE
chavert
    Moonsweeper
  • 357 posts
Posted Mon Nov 7, 2016 3:09 AM
#35 nanochess ONLINE
nanochess
  • 5,174 posts
  • Coding something good
Posted Mon Nov 7, 2016 6:21 AM
No, it will be PAL60 and will look right.
For PAL50 your kernel needs to be adapted to 312 lines, typically making longer the delay after active screen.
#36 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,883 posts
  • Medieval Mayhem
Posted Mon Nov 7, 2016 8:32 AM
Yep, though it'll be full screen at 60 fps.  Apparently PAL TVs are just fine with that.  On the flip side, NTSC TVs are not normally fine with 50 fps - though I use a C= 1084S which can handle both NTSC and PAL frame rates without any problem.  I would often boot my Amiga 2000HD in PAL mode for the increase in screen resolution.
In 2006 for my first homebrew, Medieval Mayhem, I went the 312 scanline route for PAL.  I even had separate speed tables for 50 fps so the game would play the same, but a few years later there were some reviews commenting about "wasted space" on the screen, so I built a PAL60 version.  All of my later homebrews have been PAL60.
#37 Secamline OFFLINE
Secamline
    Space Invader
  • 42 posts
Posted Mon Nov 7, 2016 9:22 AM
Okay! So I changed the file again, this time the game has the correct PAL color values and it runs at 60 fps, so if I got it right, it should be displayed in fullscreen on a european CRT TV.
