New development: GTIA in CPLD
956 replies to this topic
#701 mytek OFFLINE
mytek
  • 2,710 posts
Posted Sun Jul 16, 2017 9:21 AM
Not to mention, these *are* atari *computers* we're talking about here, dunno why you are all trying to use them on TV's anyway ;)
So that's what I've been doing wrong  :ponder:   :rolling:
- Michael
#702 mytek OFFLINE
mytek
  • 2,710 posts
Posted Sun Jul 16, 2017 1:34 PM
I got this coming...
Hopefully this will work better doing PAL RGB from Sofia. Can anyone out there confirm doing the same?
- Michael
#703 mytek OFFLINE
mytek
  • 2,710 posts
Posted Mon Jul 24, 2017 5:51 PM
Sophia connected to Atari SC1224 'ST' RGB Monitor
Live picture 1088XEL in PAL Mode
This will not work from a standard Sophia board, since the SC1224 Monitor requires higher level signals than VGA (or likely other RGB monitors). The Sophia only puts out 0.75 volt RGB and CSYNC when set to RGB mode (at least my Sophia running the 'B' core did). The SC1224 requires 1 volt RGB and close to logic level CSYNC. So the first thing I did was change a resistor on the Sophia board to increase the video output from the ADV7125 Triple High-Speed Video DAC chip.
Increase Video Output Level Mod (opps I see there is an extra '2' shown for the monitor part number :P )
Next we need a buffered logic level CSYNC to substitute for Sophia's low level one, so we'll steal that from the CD4050 chip on the A8.
And assuming all the Mods were done correctly you should now see a beautiful full color display on the SC1224 Monitor coming from your Sophia upgraded A8. And depending upon what video mode you use on your A8 (NTSC or PAL), you might need to tweak some of the back panel controls for V and H Hold, and possibly Vertical Position and Height, as well as Horizontal Position. I have only tested this on the 'JVC' version of the SC1224, so I have no idea if it'll work correctly on either the Goldstar or the Samsung models.
Disclaimer: This Mod is done at your own risk, will probably violate any warranty you may have, and is not endorsed what-so-ever by Simius (creator of the Sophia board).
- Michael
#704 Mark loves Stella OFFLINE
Mark loves Stella
    Space Invader
  • 42 posts
Posted Mon Jul 24, 2017 8:53 PM
- Michael
If you have a VBXE installed and replace the NTSC Antic with a PAL Antic, it will work. I did this. I have only experienced a few PAL demos not working. But, so far, all PAL games work.
#705 mytek OFFLINE
mytek
  • 2,710 posts
Posted Mon Jul 24, 2017 11:13 PM
That is very Interesting, but I'm actually running as a true PAL machine in every regard so all games and demos should work as they were meant to (fingers crossed).
My photo doesn't even do it justice as to how good this looks on the SC1224 monitor. There's just something about a CRT RGB monitor that is very difficult to match with an LCD. Now of course if we were talking HDMI that would be the ultimate, but we have yet to see native support for that in a real A8 machine. And with Sophia being about 1/2 the price of a VBXE (when factoring in shipping), it's really the best you are going to do at that price point. Now of course the VBXE has a few tricks up it's sleeve, but other than the 80 column mode, most of those tricks require specific software support to see them in action. And when considering how long the VBXE has been available, that support is still kind of sparse.
Since the 1088XEL doesn't have a CD4050 video/sync buffer chip, it needs to be implemented with a separate one transistor (Q11) buffer as shown in this schematic...
This circuit produces a 3.3 volt CSYNC signal, and is what I was using to generate the display I showed in the photo of the SC1224.
- Michael
Edited by mytekcontrols, Mon Jul 24, 2017 11:37 PM.
#706 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 616 posts
Posted Mon Jul 24, 2017 11:58 PM
Michael, cool stuff!
Also thanks for pointing out the resistor change. I´ve experienced several problems with Sophia and some monitors connected using the SCART interface (very common in Europe). Also I recognise the weak levels at RGB output lines. SCART also demands 1V levels. So this may be "the" issue. Will try it out...
:thumbsup:
#707 Simius OFFLINE
Simius
    Moonsweeper
  • 494 posts
Posted Tue Jul 25, 2017 3:48 AM
SCART RGB signals are 0.7Vpp @ 75ohm. 1Vpp level is required on the CVBS input, because the SYNC pulses (0.3V) are added.
http://cncms.com.au/...rtconnector.pdf
Edited by Simius, Tue Jul 25, 2017 3:49 AM.
#708 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 616 posts
Posted Tue Jul 25, 2017 10:28 AM
Oops... my fault. Thanks for correction. But I will try it with smoother values for that resistor :)
#709 foft ONLINE
foft
    Dragonstomper
  • 710 posts
Posted Tue Jul 25, 2017 3:09 PM
On the eclaireXL we've been using the CDK3405 which is similar but cheaper to the ADV7125 I think.
RGB is great, though for composite I'm not sure if I need to boost composite beyond 0.3V sync + 0.7V for the signal. I tried it the 'Atari way' with stepped luma. Using 90/256 * 0.7v for the colour signal (fixed amplitude, phase shifted for hue) + brightness*11/256*0.7v for the luma. Still it seems not quite bright enough to me.
Anyway I'm just curious if you've tried composite from the Sophia?
#710 enito OFFLINE
enito
    Chopper Commander
  • 209 posts
Posted Fri Aug 4, 2017 12:42 PM
Hi , still possible order a Sophia? and price? thx!!!!
#711 Simius OFFLINE
Simius
    Moonsweeper
  • 494 posts
Posted Fri Aug 4, 2017 4:27 PM
CDK3405 is cheaper but I've more trust for Analog Devices. :)
I've not tried to make composite from Sophia because I don't like composite at all. I think a low quality interface isn't worth the time spent on it. Unless for fun.
#712 enito OFFLINE
enito
    Chopper Commander
  • 209 posts
Posted Mon Aug 7, 2017 10:47 AM
Sophia board if possible connect to a sc1435? i have one of this, and have a db9 style connector if im not bad.
thx!
#713 GlowingGhoul ONLINE
GlowingGhoul
    Moonsweeper
  • 260 posts
Posted Mon Aug 7, 2017 10:59 AM
That's only because Europeans have no appreciation for the early games that used artifacting for color. Ultima III, Choplifter, David's Midnight Magic, are all monochrome with this board.
Edited by GlowingGhoul, Mon Aug 7, 2017 10:59 AM.
#714 mytek OFFLINE
mytek
  • 2,710 posts
Posted Sat Aug 19, 2017 10:06 AM
I've been using my Sophia board for driving into two different SC1224 ST monitors lately with a PAL setup, and although it looks very, very cool, and produces the best image I've seen thus far, the color pallete still appears to be not quite right. In particular light (pale) blues are not quite right, being more on the greenish side of things. So for instance, the normally light blue background in Basic looks more cyan, and in Star Raiders when you enable the shields it's light green instead of light blue. Is it just me, or are others seeing this as well? Keep in mind that I am using a PAL system, and that this has been verified on two different SC1224 monitors.
I'm also using the latest Sophia firmware revision.
- Michael
#715 flashjazzcat ONLINE
flashjazzcat
  • 13,479 posts
Posted Sat Aug 19, 2017 10:33 AM
My stock PAL hardware all produces cyan backgrounds. I've tested a Sofia here in RGB mode and it looks right to me (identical to VBXE).
#716 mytek OFFLINE
mytek
  • 2,710 posts
Posted Sat Aug 19, 2017 11:18 AM
I guess all is ok then  :)
- Michael
#717 Simius OFFLINE
Simius
    Moonsweeper
  • 494 posts
Posted Sun Aug 20, 2017 10:50 AM
Firmware update.
1. Our5oft issue fixed.
2. bit4 PMCTL controls additional color in hi-res mode.
3. VSYNC output comes back in rev.B.
Please report any comments.
Edited by Simius, Sun Aug 20, 2017 11:01 AM.
#718 towmater OFFLINE
towmater
    Dragonstomper
  • 528 posts
Posted Tue Aug 29, 2017 7:11 PM
Forgive me, Simius, but I couldn't make it through all 30 pages of this thread to find out... is this a thing that I can buy for a 1200xl that will give me rgb output? (I was tuckered out by page 27.) I don't want to hack up the motherboard to do a composite mod, which goes against my "first do no harm" retro hardware edict.
#719 ApolloBoy OFFLINE
ApolloBoy
  • 5,706 posts
Posted Tue Aug 29, 2017 7:33 PM
It should work on a 1200XL just fine, it even works on a 5200 without any problems.
#720 Simius OFFLINE
Simius
    Moonsweeper
  • 494 posts
Posted Tue Aug 29, 2017 11:25 PM
Yes, it is.
#721 Philsan ONLINE
Philsan
  • 3,624 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Wed Aug 30, 2017 12:56 PM
Firmware update.
I tested new firmware and now Our5oft demo is perfect.
Thank you very much Jacek!
Can you please explain:
#722 Lavalamp OFFLINE
Lavalamp
    Star Raider
  • 85 posts
Posted Wed Aug 30, 2017 5:15 PM
H
Yes, it is.
Hi , is this still around, where can I purchase one?  :)
#723 towmater OFFLINE
towmater
    Dragonstomper
  • 528 posts
Posted Thu Aug 31, 2017 9:33 AM
I wish the first message in the thread could be updated with ordering info, but as far as I can tell the "Sophia" costs $55 plus shipping from Eastern Europe, order by PM'ing Simius. I gather the thing goes out to a db-9 connector and is suitable for a Scart-to-hdmi conversion box if you make a Scart cable for it.
#724 mytek OFFLINE
mytek
  • 2,710 posts
Posted Thu Aug 31, 2017 1:12 PM
H
I hope he is around, and keeps selling this board, because the 1088XEL has been modeled to allow this to be dropped in and directly drive Atari SC1224 monitors (well with a very small mod, change a resistor and add one more crimp connector on the existing cable). Works great  :thumbsup:
- Michael
#725 towmater OFFLINE
towmater
    Dragonstomper
  • 528 posts
Posted Thu Aug 31, 2017 10:03 PM
I just sent an order inquiry, I gather I need to start reading this whole thread, to find out what I'm in for. I'm hoping I won't need to cut holes in the case or pull out existing components, although some soldering of wires might be OK.
