new products at arcadeshopper.com
219 replies to this topic
#1 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Sun Nov 6, 2016 12:30 PM
Composite Video Cables
TI Lapel Pins
80 track floppy controller
32k Sidecar Ram expansion (w/optional power supply)
3d Printed Mini TI-99/4a's
books & manuals coming soon
#2 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Sun Nov 6, 2016 12:32 PM
also coming soon flashrom99 cartridge boards in kit and assembled form
#3 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Thu Nov 10, 2016 4:44 PM
testing the waters, newly designed atari->TI joystick adapters, interest?
#4 Shift838 OFFLINE
Shift838
  • 2,533 posts
  • SHIFT838
Posted Thu Nov 10, 2016 5:34 PM
i know I for one would be interested.
#5 aftyde OFFLINE
aftyde
    Moonsweeper
  • 250 posts
Posted Thu Nov 10, 2016 7:38 PM
HDX HDX HDX!  :)
#6 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Thu Nov 10, 2016 8:58 PM
HDX HDX HDX!   :)
I have new daughterboards in stock.. a few anyway..
And I'm working on my backlog :P  finally got everything set up at the warehouse workbench and now it's just time
Greg
#7 aftyde OFFLINE
aftyde
    Moonsweeper
  • 250 posts
Posted Thu Nov 10, 2016 9:37 PM
Greg
Can I order you a pizza or something?!?  :)  Sadly - I finally broke down and bought a bench magnifier - eyesight at 50 is starting to drop off... :(
#8 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,521 posts
  • Distracted at the Keyboard
Posted Fri Nov 11, 2016 3:49 AM
I use a card holder (helping hands) to hold my cell phone, then I use macro zoom.
#9 warpman OFFLINE
warpman
    Space Invader
  • 25 posts
Posted Fri Nov 11, 2016 9:14 AM
I would buy a newly designed Atari/TI joystick adapter.  The more flush mount the better.
#10 LynxHandyCaster OFFLINE
LynxHandyCaster
    Chopper Commander
  • 231 posts
Posted Fri Nov 11, 2016 11:54 AM
Yes, count me in, please.
#11 remowilliams OFFLINE
remowilliams
  • 10,607 posts
Posted Fri Nov 11, 2016 12:00 PM
This!
#12 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Fri Nov 11, 2016 12:25 PM
Here's an idea we're working on.  Hard to case this though so may end up a little bigger.. you could put a short or long extension cable on the TI side if you wanted a cable..
#13 PeBo OFFLINE
PeBo
    Dragonstomper
  • 911 posts
Posted Fri Nov 11, 2016 4:45 PM
It would truly make it a must-have is if it could also include a straight pass-thru connector as well, so one would not have to remove it to plug in TI joysticks. I know, I know, why would anyone WANT to plug in TI joysticks (maybe I'm nuts - I like em for Slymoids), but the MBX also uses the joystick port. They wouldn't have to work simultaneously, I'd just much rather wear-out an add-on adapter plugging and unplugging stuff than the only joystick port the TI console has!
And it is one thing no other joystick adapter offers
#14 Ksarul OFFLINE
Ksarul
  • 5,204 posts
Posted Sat Nov 12, 2016 6:25 AM
PeBo, there are other things that the pass-through would be useful for as well: there are at least two third-party joysticks with a TI pinout (Personal Peripherals Inc. Super Stik and Amiga Power Sticks); the MBX uses the port; Joyprint uses it; and lastly, the X-10 Interace uses it. Note that in the case of the third-party joysticks, both of them were also made with the standard Atari pinout, so you have to look for the part number to be sure you have the right type (IIRC, the TI variants included two joysticks on a "Y" cable, whereas the other variants were always a single joystick).
#15 sometimes99er OFFLINE
sometimes99er
  • 4,222 posts
Posted Sat Nov 12, 2016 7:16 AM
The joystick adapter I got back in the day looked like a 9 to 25 pin serial adapter. And then you'd put the one or two joysticks at the ends of the 25 pin. Worked fine.
#16 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Sat Nov 12, 2016 11:18 AM
How about a short cable you can unplug from the adapter, not the console and then plug whatever into that?
Greg
#17 PeBo OFFLINE
PeBo
    Dragonstomper
  • 911 posts
Posted Sat Nov 12, 2016 5:23 PM
Greg
Well that would work to be sure, but then I'd be more likely to just get the cable instead of the adapter (already have a Wico Command Control, and a couple standard Y cable adapters).
What sparked my interest in your proposed design is that it is a board that plugs directly into the console - a design which would be defeated by the addition of a cable. An adapter that offered on board support for both TI and 3rd party controllers/devices (switchable or with some kind of cut-off) would really bring something new to the table.
With a 2.5cm space between the port and the bottom of the console, there should be more than enough vertical real-estate for a TI connector below the Atari connectors (easily said since I'm not concerning myself with the logistics of wiring and switching), and heck, being direct-connect it would amount to being our first left-side sidecar device.
Not even Milton Bradley pulled that off!
#18 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Wed Nov 16, 2016 12:31 PM
note, this is shipping this week :)
#19 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Wed Nov 16, 2016 12:32 PM
I will have the y cables on the site.  We're trying to make it cheap and easy so probably will offer options of cables to extend out if people want them and also the option to add 5v to the atari joystick ports for use with rapid fire/trackball/etc that require it.
Greg
#20 warpman OFFLINE
warpman
    Space Invader
  • 25 posts
Posted Fri Nov 18, 2016 8:25 AM
Stargunner....  that design is perfect.  Wow  x  3  :)
#21 jedimatt42 OFFLINE
jedimatt42
  • 1,890 posts
Posted Sat Nov 19, 2016 12:19 AM
Not sure how many games benefit from auto-fire... So I added a power supply to my homebrew joystick adapter for player-1, just to see..
Seemed like in parsec, you could shoot a little longer without overheating...
Didn't seem to matter in killer caterpiller.
Shooting Stars, on the other hand... I got to level M and gave up... I realized something was up when I got to level ';'... too busy shooting at stars to look at the screen.
Saddly, the only autofire joystick I have is also the absolute worst joystick I have :) But it seemed to test out well.
Also, inconvenient, ground for the power supply goes to Atari pin 8. Which is also player 1 and player 2 on the two different port when adapted to a TI. Hooking them together to ground on a power supply would break having player 1 and player 2, as they would be joined. I'm sure this is basic electronics... But I cannot reason it out... If I put diodes between the ground junction and pin 8's that'll stop it from joining, but will also stop power flow to the rapid fire circuit...
Has this been solved before?
-M@
#22 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Fri Dec 2, 2016 9:47 AM
Black Flashrom99 cases now available
floppy disk lapel pins now available
adding soon
ti external power supplies
ti dual cassette cables
Flashrom99 assembled boards
Flashrom99 bare boards
new game!
Edited by arcadeshopper, Fri Dec 2, 2016 9:52 AM.
#23 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,521 posts
Posted Fri Dec 2, 2016 9:57 AM
It looks like you're giving away assembled flashrom99 for free ($0.00)
#24 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Fri Dec 2, 2016 10:21 AM
just haven't set the price yet, there are none available at free :D
There! set a price.. :P
Edited by arcadeshopper, Fri Dec 2, 2016 10:53 AM.
#25 arcadeshopper OFFLINE
arcadeshopper
  • 4,272 posts
Posted Fri Dec 2, 2016 11:32 AM
new game NOW AVAILABLE!
https://www.arcadesh...tegory=15846003
