malarrya Posted November 12, 2016 Share Posted November 12, 2016 Hey guys! I've been playing with my CV a lot lately and recently got the game Nova Blast off of eBay. I cleaned and repaired everything on the CV a while ago including the controllers but just now found out that the ASTERISK (*) button on one of them doesn't seem to work. Nova Blast needs this button pressed to start the game. My question is, everything else (as far as I can tell) works on the keypad (even the # key) except the * button. Is there something I can do to locate the cause of the malfunction? In other words, I am not sure how 12 buttons on the keypad are translated into 1 or 2 wires that feed into the CV but it seems to me if all the buttons except this one work the problem may be with the ribbon cable? If so, is this something that can be repaired easily? Thanks, Larry Quote Link to comment Share on other sites More sharing options...
malarrya Posted November 12, 2016 Author Share Posted November 12, 2016 (edited) I found this thread: http://atariage.com/forums/topic/159346-controler-keypad-not-working/ It seems to say the cause may be a trace broken although peeling back the top layer I don't readily see a broken trace. The ribbon that plugs into the board is slightly frayed on the left side but it's definitely not split. Does someone on the board repair these or can trade a working one with mine + $? Thanks! EDIT: Looks like it is a broken trace: Edited November 12, 2016 by malarrya Quote Link to comment Share on other sites More sharing options...
Milli V Posted November 13, 2016 Share Posted November 13, 2016 Hi - you can get a mAdam controller and switch out the pad - I sell them http://retrosystemrescue.com Milli Quote Link to comment Share on other sites More sharing options...
Milli V Posted November 13, 2016 Share Posted November 13, 2016 Direct link to the controllers: http://retrosystemrescue.com/product/adam-game-controller/ or if you prefereBay http://www.ebay.com/itm/222237697843?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 (I charge a little more on eBay) 1 Quote Link to comment Share on other sites More sharing options...
malarrya Posted November 13, 2016 Author Share Posted November 13, 2016 Thanks, Milli V. I am actually refurbishing/repairing this system for sale and, with the cost I've already incurred, I'd be lucky to break even. I was hoping to find a cheap way to fix this. I did think that it may be possible to sand down the plastic around the broken trace and use metal ventilation tape to complete the circuit but I am not sure that will work. I will definitely keep you in mind if one of my main controllers dies Quote Link to comment Share on other sites More sharing options...
malarrya Posted November 14, 2016 Author Share Posted November 14, 2016 This may be a stupid question but here goes... I know I can fix the trace by sanding the plastic and using a trace pen to draw another trace but would this work as well... How about putting a small staple on the trace to bridge the connection? Would that work? Thanks! Quote Link to comment Share on other sites More sharing options...
adamcon Posted November 14, 2016 Share Posted November 14, 2016 This may be a stupid question but here goes... I know I can fix the trace by sanding the plastic and using a trace pen to draw another trace but would this work as well... How about putting a small staple on the trace to bridge the connection? Would that work? Thanks! Long as it allows the elec circuit to complete, should work. That route is a little suspect, but I knew a guy who only used alligator clips and paper clips. 1 Quote Link to comment Share on other sites More sharing options...
Milli V Posted November 14, 2016 Share Posted November 14, 2016 This may be a stupid question but here goes... I know I can fix the trace by sanding the plastic and using a trace pen to draw another trace but would this work as well... How about putting a small staple on the trace to bridge the connection? Would that work? Thanks! If you are reselling it I would suggest not, unless you tell the buyer - I have refurbished a lot of adam parts that were fixed with hot glue, tape etc- messy and ruins the original (and getting rarer) parts Quote Link to comment Share on other sites More sharing options...
