Atari Flashback Portable FAQ and Compatibility List
I haven't played it in a week or so, but I think the rectangular shaped yellow button above the face buttons on the right hand side does it. If not, just try them all since one definitely does it.
What's the light on the front signify? Unless it was on as I was charging it before using it, I've yet to ever see it lit.
Edited by Atariboy
It turns green to signify when the unit it fully charged.
I think the idea was to put the BW/Color in there for games that use it for gameplay, like Secret Quest or Starmaster. It's not like a color LCD needs a black and white mode, and making it a "sticky" toggle would probably generate dumb support questions.
Also, this
http://nerdlypleasures.blogspot.com/2015/03/the-forgotten-switch-atari-2600s-b.html
Quote
Finally, there are several games that use the B&W switch for a special function unrelated to its original intent. Often it could be used to pause the game, but other games assigned a unique function to it. Here is a list of games that I have verified :
B&W Switch used for Something Else
Space Shuttle (engine controls)
Cosmic Ark (turn on/off star field on some cartridges)
Fantastic Voyage (pause)
Solaris (inverts planet horizons)
Mouse Trap (removes playfield)
Starmaster (brings up Galactic Chart)
Beany Bopper (pause)
Flash Gordon (pause)
Spacemaster X-7 (pause)
There are undoubtedly more games than on this list, but it serves as an illustrative example of why the B&W/Color switch should not be utterly ignored.
Id say that is a great explanation as to why the TV Mode switch is the way it is. I didn't realize that so many games made use of it.
Wow! Big thanks to Nukey Shay for doing this. Looking forward to playing Maraduer and Jawbreaker on the portable.
I tried a few more ROMs that weren't on the list or didn't have anything for condition.
Allia Quest - works perfectly
Alfred Challenge - bottom of screen cut off, makes it impossible to play because you can't see gaps in the bottom platform.
Pac-Man (Ebivision) works perfectly
Pesco - works perfectly
Ghost Manor - works perfectly
Motocross Racer - works perfectly
Robin Hood - works perfectly
Sir Lancelot - works perfectly
Spike's Peak - bottom of screen cut off
Snail Against Squirrel - bottom of screen cut off. playable, but you can't see how many lives you have left
I also tried The Extraterrestrials, which is a 2-player game that doesn't run right in Stella, so no surprise it doesn't work on the portable.
I would like to try some of these games, can you post the .bin files for them?
Thanks
Actually, that's why the TV Mode switch on the Flashback Portable is bad. It doesn't work the way these games expect it to. The only game it works correctly for that I know of it Secret Quest, because Secret Quest wants you to quickly flick the TV mode on and off to access the status screen. Games that expect you to switch the switch and keep it in that position don't work properly. To make Secret Quest work great they kinda broke the switch for every other game.
Starmaster is unplayable. After your first warp you're basically stuck on the galactic map for the rest of the game.
Ok, so I guess it is just bad implantation on ATgames part (trying to use a momentary pushbutton instead of a slide/toggle switch). So back to Bill, any logic behind this, or just cost cutting?
Just press the fire button to leave the map and warp to the sector you've selected. Works fine.
If I hold down the TV mode button I can access the galactic map, yes. I press fire, begin the warp and it automatically switches back to the action screen, then let go of TV mode. But after the warp is completed it automatically switches back to the galactic map, and from then on I can only see the action screen by holding down the TV mode button. It's impossible to play keeping one finger on the TV mode button the whole time.
For me the TV mode's function changes after the game begins. When the game begins pressing it brings up the galactic map, but after the first warp pressing it brings up the action screen. It works like this is Stella too, but in Stella we don't have the TV mode button problem.
Edited by Glorkbot
My mistake. I use the difficulty buttons on the AFP instead of the TV type button. I have no problems with the game using those.
Oh! I didn't even know you could also use the difficulty buttons to access the galactic map. Well, thank you very much!
I'm 99.44% certain one can play Starmaster without touching those buttons, I certainly remember just sitting on my butt and waiting for empty sectors to time out and take me back to the galaxy map. It doesn't take much fuel/time as I recall.
I also asked about making the HARD, MONO, etc., less noticeable when on the screen.
It should disappear after a few seconds just like the volume bar and so on does on a television when a setting is modified. Nothing is gained by it being continually displayed that you've selected the hard setting, even if done in a less intrusive manner than is the case with the 2016 release.
If they're afraid that people will forget that they set one or both switches to hard as they move from game to game, I'd suggest just coding it where the switches both default back to easy each time you exit the emulator and load up a new rom (If it doesn't already do that; I haven't noticed since I've usually left it set to easy). Then there's no question when firing up a new game at what the switches are set at.
Edited by Atariboy
All good stuff and seems like we got Starmaster figured out.
Just for fun I bought the Sega Flashback Portable off ebay for like $20. Kinda fun but man with the sound I think I payed about $10 too much.
We really got lucky with the Atari Flashback Portable. :o
Already defaults back to easy when moving to another game, I just noticed.
Since you can't move to another game with it inadvertently left set to hard, I'm now even more confused on why they felt it necessary to constantly display that the difficulty switches have been set to hard as you're playing a game, rather than just let the notification fade away after a few seconds.
Edited by Atariboy
