fiddlepaddle Posted March 12, 2017 Share Posted March 12, 2017 I don't use a mac, but I think the files come up in the order that they were copied to the SD card. I just have to highlight the LAST game in the list, hold SHIFT and then press HOME, which selects the entire list in reverse order, then CNTL-C (for COPY), then PASTE on the SD card...but I use Ubuntu. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted March 13, 2017 Author Share Posted March 13, 2017 I think the AFBP reads them in the order they were placed on the card. You should be able to copy them to a different volume, sort by name, and then copy them back again to get them in the order you want. Quote Link to comment Share on other sites More sharing options...
Asaki Posted March 13, 2017 Share Posted March 13, 2017 It's a lot easier and a little faster to just use a FAT sorting utility. Quote Link to comment Share on other sites More sharing options...
onmode-ky Posted March 16, 2017 Share Posted March 16, 2017 You are welcome to check out the take apart pictures I made of the pre-production model I did at one point and see if you can determine anything from that: http://atariage.com/forums/topic/254611-atari-flashback-portable/page-20?do=findComment&comment=3637891 I'm over a month late replying, but your pictures of the pre-production model were the ones I had already looked at. Thanks for that contribution! If you're game for taking it aaaaallll apart once again, though, well hey, I won't stop you. In no small part because I can't reach you from way over here, even with a spatula. Those who are within spatula range, however . . . . onmode-ky Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted March 16, 2017 Author Share Posted March 16, 2017 1 Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted April 29, 2017 Author Share Posted April 29, 2017 I've received a bunch of requests to edit the spreadsheet recently. If any of them were you, could you please send me a PM and tell me what you'd like to add? Quote Link to comment Share on other sites More sharing options...
ComputerSpaceFan Posted April 30, 2017 Share Posted April 30, 2017 I can't get Threes to work so if it's not fixable can it be listed as not compatible? Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted May 1, 2017 Share Posted May 1, 2017 I can't get Threes to work so if it's not fixable can it be listed as not compatible? I tested several versions of THREE·S and found that v0.7 version's title screen works perfectly, but gameplay is scrambled for each version released EXCEPT, for v0.3 & v0.4 look like they are playable.......... possible Thomas or Nukey Shay can work on it for you........... Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 13, 2017 Share Posted May 13, 2017 (edited) Just got my Portable today. Many thanks for this FAQ! It'll probably be 2 months before I could get access to the card reader for downloading games onto my SD card, but I hope to download some Activision titles, arcade ports and homebrews like Omicron and Juno First. I remember reading a FBP-compatible version for the latter somewhere. Hopefully it won't be hard to find. Also, no character limit on the file names, I assume. Oh one more question: do they only work with NTSC Roms? I'm hoping to put Klax onto it and as far as I know the NTSC version is only a prototype and I'm not sure if it's available for download or complete. (I'll check the AtariAge page for it afterwards) Would PAL games suffer on the FBP? Edited May 13, 2017 by Tangentg Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 13, 2017 Share Posted May 13, 2017 Also I'm thinking of getting Avalanche but it doesn't seem to be in the compatibles spreadsheet. Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 16, 2017 Share Posted May 16, 2017 (edited) Missing from the list: I was able to get Dungeon, Omicron and Avalanche to work, though Dungeon and Avalanche suffered from file corruption problems that permanently corrupts 2 files (if I fix those then 2 other files go corrupt) on the SD card (it's possible though that they're a local problem rather than a problem with the games themselves) got around the problem by leaving 2 junk files and renaming the "real" files to get them to work. Edited May 16, 2017 by Tangentg 2 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 17, 2017 Share Posted May 17, 2017 (edited) Ms Hack has severe graphical glitches and L.E.M. is unplayable cause your ship keeps exploding (also the menu is glitched up). Flashback 2 version of Space Duel works (and without the more glitchy dots in Stella). Kinda hope someone could hack Galaxian to make it playable or get rid of the graphical glitches in Midnight Magic and Pressure Cooker too. And perhaps a FBP hack for Codebreaker. These are games I'd like to play on mine. Edited May 17, 2017 by Tangentg 2 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 18, 2017 Share Posted May 18, 2017 Hack'Em / Ms.Hack won't ever be playable on the portable. They hit CTRLPF at variable times...and the portable has demonstrated a *very* short window allowed for that (it's not true to how a real machine operates). Galaxian hits the sprite position reset multiple times per scanline, a trick that the portable also does not allow. Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 18, 2017 Share Posted May 18, 2017 Hack'Em / Ms.Hack won't ever be playable on the portable. They hit CTRLPF at variable times...and the portable has demonstrated a *very* short window allowed for that (it's not true to how a real machine operates). Galaxian hits the sprite position reset multiple times per scanline, a trick that the portable also does not allow. Aww I see, so no modification would make it work huh Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted May 19, 2017 Share Posted May 19, 2017 Missing from the list: I was able to get Dungeon, Omicron and Avalanche to work, I added them to the list. Thanks for the info! 1 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 21, 2017 Share Posted May 21, 2017 I think I found a graphical glitch in Dungeon where "SP" becomes replaced by the last digit of the spell points, but otherwise it seems to run fine. Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 24, 2017 Share Posted May 24, 2017 Another game not listed that's tested to run fine on the FBP: Cave 1k! 1 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 26, 2017 Share Posted May 26, 2017 I noticed Brain Games is listed as perfect. That shouldn't be possible since it requires the keyboard controllers. Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted May 26, 2017 Share Posted May 26, 2017 Another game not listed that's tested to run fine on the FBP: Cave 1k! added that title and added links to the .bins too 1 Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted May 26, 2017 Share Posted May 26, 2017 I noticed Brain Games is listed as perfect. That shouldn't be possible since it requires the keyboard controllers. done 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted May 27, 2017 Share Posted May 27, 2017 Aardvark is a homebrew in development which just I've made compatible with AFP http://atariage.com/forums/topic/259694-aardvark-for-atari-vcs2600/ Also I've confirmed that Space Raid also works with AFP. http://nanochess.org/space_raid.html And 1K Atomchess also fully functional http://atariage.com/forums/topic/260741-1k-atomchess-for-atari-vcs2600/ 3 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 28, 2017 Share Posted May 28, 2017 I think Space Raid is already in the list. Pretty sure I saw it 1 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted May 31, 2017 Share Posted May 31, 2017 The Elk Attack hack Electric Yo-yo works, and since the only thing the hack changed is the title screen, Elk Attack should work too, on the Flashback Portable. Stampede seems to run fine though it's my first few times playing it so I'm not terribly sure how it's supposed to be. Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted June 1, 2017 Share Posted June 1, 2017 All caught up with your updates listed above! 2 Quote Link to comment Share on other sites More sharing options...
Tangentg Posted June 3, 2017 Share Posted June 3, 2017 Say, I noticed how it's technically the Atari Flashback - Portable Game Player so it might make sense to call it the PGP but everyone just says (Atari) Flashback Portable and abbreviate it as AFP or FBP. Quote Link to comment Share on other sites More sharing options...
