Atari Flashback Portable FAQ and Compatibility List
Atari Flashback Portable FAQ Compatibility List
745 replies to this topic
#151 SS OFFLINE
SS
  • 6,263 posts
Posted Sun Dec 4, 2016 8:07 AM
By the way, what brand/size SD card are you using?
Ha ha! I actually found an almost 10 year old 512mb Kodak card in the back of a drawer the other week. I joked "This will come in handy" at the time but, whatta you know, it actually did! :)
#152 Inky OFFLINE
Inky
    Gobs of money!
  • 25,879 posts
  • Meh
Posted Sun Dec 4, 2016 12:43 PM
I was playing Tapper earlier, and the full bottom bar was missing from the screen.
#153 JeffIrok OFFLINE
JeffIrok
    Space Invader
  • 30 posts
Posted Sun Dec 4, 2016 2:03 PM
Thanks FlojoMojo for the updated zip file!  I just got my portable today and this came in handy!
I ran into the same luck as SS - I had an old 512MB card hanging around from a digital audio recorder I bought years ago (I replaced it with a 4GB immediately so never used the 512GB!)  It worked like a charm!
#154 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Sun Dec 4, 2016 4:56 PM
Yes, it was the folder Willie uploaded with 516 games. It doesn't show those "extra" files on my mac, but they appear when I load up the SD card. I tried dot clean, and nothing happened. Do you have to specify the directory path if you are already in the 'GAME' folder directory? I loaded up TERMINAL in OSX 10.7.5 and found the GAME directory, and just typed dot_clean.After erasing the SD, and copying from computer, the files were still the same.
I know nothing, and these UNIX commands were very helpful:
pwd- tells what directory you are in
ls- lists your files
#155 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Sun Dec 4, 2016 5:18 PM
ATARI Flashback Portable BOX
Edited by orion1052003, Sun Dec 4, 2016 5:24 PM.
#156 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Sun Dec 4, 2016 5:27 PM
ATARI Flashback Portable MANUAL
Edited by orion1052003, Sun Dec 4, 2016 5:29 PM.
#157 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Sun Dec 4, 2016 5:43 PM
I noticed in TURMOIL you can't grab the eggs on the left side of the screen, but you can get them on the right side of the screen. Can't say the game works right in the portable, although it appears to at first. In "Bobby Goes Home", or "Bobby Gehts Heim", there are jacked up artifacts, including an aurora borealis of junk when he reaches the home at the end of a level.
There are 60 games, and 8 paddle games and 4 trackball games included in the Flashback Menu. If they took these out of the menu, they would appear more to know what they are doing. That leaves you with 48 games. The trackball games are typically played with a joystick on a real Atari, but it is pretty bad, at least debatable. but no room for paddle games, they are terrible and unplayable with the d-pad!!
Tempest is a proto that is pretty bad as it was unfinished, and used a joystick, but should have used paddles, of course.
Paddle games on Atari Flashback Portable (and 7?) 1.Astroblast 2. Pong Sports 3. circus atari 4. demons to diamonds 5.Breakout 6.super breakout 7. blackjack 8.night driver
Trackball games (Joystick games that worked when I plugged in the Atari trackball) 1. Centipede 2.Millipede 3.Crystal Castles 4. Missile Command
It supports 103 pages of SD card menu, I think the same as the brother system SEGA ARCADE ULTIMATE. (They should have made the top and bottom plastic brown instead of gray)
(The manual I scanned it for you all myself, I sure get tired of uploading everything in .bmp, and having to delete it all, change it to .jpg, and re-upload it. support for .BMP images on here would be convenient.)
The Flashback Portable comes with the box, 16 page manual, USB charging cable, and the unit. It does not have a charger plug for the wall, so you have to buy a chager head for the usb cable or charge from a computer. It does not come with an A/V cable, and I assume that it does not work like on the SEGA portable. (meaning you can only connect to old CRT tvs with RCA jacks, but not new TVs with RCA jacks or old or new projectors with RCA jacks.
Edited by orion1052003, Sun Dec 4, 2016 5:51 PM.
#158 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Sun Dec 4, 2016 5:58 PM
So if the thing is limited to 103 pages of menu, does anybody know how much memory the system allocates or is usable out of an 8 gigabyte card? Willie's Folder is about 3.3 megabytes and goes to 103 pages. My folder was 21.6 megabytes with 1,900 ROMS and the FIRECORE system went to the letter 'E' and ended at 103 pages. Maybe somebody should post what SD cards not to buy. The older cheap $5 ones seem to work so afr, and I think when I tried newer ones on the SEGA they did not work.
#159 garyd97 OFFLINE
garyd97
    Chopper Commander
  • 132 posts
Posted Sun Dec 4, 2016 6:50 PM
Has anybody gotten squeezebox to work? Mine loads with a blank screen.
#160 Asaki OFFLINE
Asaki
  • 2,369 posts
Posted Mon Dec 5, 2016 8:40 AM
9*103=927
I try to stick with Sandisk or maybe Kingston, I rarely have issues.
For a lot of devices, unless they explicitly state that they support SDHC, I'll use something 2GB or smaller. It doesn't seem like stores sell those anymore though, and getting them from eBay seems like a bit of a gamble.
Edited by Asaki, Mon Dec 5, 2016 8:43 AM.
#161 ls650 OFFLINE
ls650
  • 7,393 posts
  • Atari rocks!
Posted Mon Dec 5, 2016 9:21 AM
Thanks to everyone working on these lists....
#162 Flojomojo OFFLINE
Flojomojo
    [EXPLETIVE DELETED]
  • 15,443 posts
Posted Mon Dec 5, 2016 9:58 AM
The folder I posted is 52 pages, many fewer ROMs, and way smaller in size. You might want to format that card, download the romset again, and load it up anew. After writing files to the card, be sure you eject it safely. If you're on a Mac you might want to run dotclean on the directory in the SD card before loading it up. If it still looks weird, zip it up and PM it to me, and I'll try to test it for you. I'll share what I see, and clean out dotfiles if necessary.
#163 Flojomojo OFFLINE
Flojomojo
    [EXPLETIVE DELETED]
  • 15,443 posts
Posted Mon Dec 5, 2016 10:02 AM
Did you leave Berserk in there? The reason I ask is I found a workaround to get the bullets to fire. I posted this fix in the compatability thread.
I just pulled the card out to fix that mistake, and I noticed that Berzerk actually is in there. I guess I like that game too much to leave it out, even with a flaw. The "no fire zone" is not a dealbreaker for me. That is such an iconic Atari VCS game and it needs to be on everything. I can zone out and play this for ages.
Nope but you can put it back. :-)
Bunny Berzerk is in there though.
One of these statements is a lie, and two others are true.
#164 TheEditor OFFLINE
TheEditor
    Chopper Commander
  • 162 posts
Posted Mon Dec 5, 2016 10:41 AM
I am using a 128mb Lexar in one unit and 128mb PNY in another, same ROMs on both.  I has one unit and a friend has the other.  No issue with it displaying the game list, 98 pages but it does not show them alphabetically which is odd.  I may format the card and reload it as I had games in the folder then added more.
#165 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 958 posts
  • Enjoying 8 bit gaming in HD!
Posted Mon Dec 5, 2016 11:05 AM
I agree and feel the same way about Asteroids, although I must say, I am playing the Asteroids DC+ hack on my SD card because I love how much more challenging it is!
#166 SS OFFLINE
SS
  • 6,263 posts
Posted Mon Dec 5, 2016 8:13 PM
I have been playing "Asteroids DC+" rather than the built in version too.  It plays *so* much more like the arcade version.  I bought a cart of it years ago too.
#167 orion1052003 OFFLINE
orion1052003
    Moonsweeper
  • 272 posts
Posted Mon Dec 5, 2016 11:34 PM
@ Flojomojo, (The folder I posted is 52 pages, many fewer ROMs, and way smaller in size.) Although I got 103 pages, when I ran Dot_clean in the 'Terminal' app in macosx, It reduced down to 52 pages like yours.  There were all these 'extra' files showing up, only on the flashdrive, after being copied without them visible on the hard drive. Like ._space.bin, ._space.bin, and space.bin. THe menu list looked ugly and was quadrupled or whatever in size. So I learned a few Unix command line commands.The menu looks way nicer now.
#168 Dan Iacovelli OFFLINE
Dan Iacovelli
  • 6,071 posts
Posted Wed Dec 7, 2016 11:10 AM
saw that keystone kapers works have anybody tried my hack of it laserman 2k3 on the portable, haven't brought mine yet maybe after xmas
#169 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,626 posts
  • Medieval Mayhem
Posted Wed Dec 7, 2016 3:45 PM
Does the original Stay Frosty (from Stella's Stocking) work on it? Standalone ROM's here.
#170 Arenafoot OFFLINE
Arenafoot
  • 1,344 posts
  • videogamestores.net
Posted Wed Dec 7, 2016 6:17 PM
I just bought mine today.....and was wondering the same thing............... will have to try it.
#171 sramirez2008 ONLINE
sramirez2008
  • 2,724 posts
  • Stella Foreva
Posted Wed Dec 7, 2016 6:34 PM
Finally pulled the trigger.  $34.23 including tax after 20% off at Bed Bath & Beyond.  I'm in the Atlanta area for work this week and found mine at a location near the Lithonia Mall (if anyone is interested).  They also had several Flashback 6 and 7's for sale.
#172 sramirez2008 ONLINE
sramirez2008
  • 2,724 posts
  • Stella Foreva
Posted Wed Dec 7, 2016 7:18 PM
Man I hope this game works.  -Thanks Darrell.
#173 mmervine OFFLINE
mmervine
    Moonsweeper
  • 454 posts
Posted Wed Dec 7, 2016 8:00 PM
Just tried it.  No, it does not work.
#174 sramirez2008 ONLINE
sramirez2008
  • 2,724 posts
  • Stella Foreva
Posted Wed Dec 7, 2016 8:04 PM
#175 Arenafoot OFFLINE
Arenafoot
  • 1,344 posts
Posted Wed Dec 7, 2016 8:13 PM
just tried it.....it doesn't load at all :-(
other homebrews I've tried:
21Blue - works perfect
2003 AA Greeting Card - works perfectly
2005 Mini Game Cart - all games work
Alien Pinball - will not load
D.K. VCS - will not load
DK Arcade 2600 - will not load
Doom Patrol - will not load
Laserman 88 - plays but can't control the ship
Laserman 2K3 - works perfect
Spies in the Night - works but the clock is messed up
The Deep - will not load
Wall Jump Ninja - works perfect
Edited by Arenafoot, Wed Dec 7, 2016 8:57 PM.
Also tagged with one or more of these keywords: Atari Flashback Portable, FAQ, Compatibility List
