up2knowgood Posted November 14, 2016 Share Posted November 14, 2016 I just purchased an Atari Space Age Joystick, but the red trigger fire button doesn't work. Everything else works fine, and is super smooth, but only button won't work. Can anyone make any suggestions as to how to fix it cause I'm at a loss as it is very different from a standard joystick. Quote Link to comment Share on other sites More sharing options...
chas10e Posted November 14, 2016 Share Posted November 14, 2016 try some conductive paint on the flex circuit if you see an obvious break in it it could also be the end of the cable that plugs into the console , but more likely a break in the flex circuit Quote Link to comment Share on other sites More sharing options...
chas10e Posted November 15, 2016 Share Posted November 15, 2016 (edited) the broken stuff was how I received the item , hotmelt glue & some paperclips works ok, just try and not to break yours I could not remove joystick handle from top and didn't seem to need to I did remove halves from under it to pull flex circuit around to examine Edited November 15, 2016 by chas10e Quote Link to comment Share on other sites More sharing options...
