Place Logo Here Posted November 16, 2016 Share Posted November 16, 2016 Received a Madtronix imager today (yay!). Fired up the Vectrex with it plugged into port 2. From my Veccmulti, repeatedly tried to load any 3D games. Title screen comes up, wheel starts spinning and...black. Nothing. Funny thing is, if I don't plug in the imager, the (rather unplayable) game comes up. Anyone else had this problem? Any recommendations? Quote Link to comment Share on other sites More sharing options...
Mayhem Posted November 16, 2016 Share Posted November 16, 2016 Have you checked the ROMs for the 3D games, and whether they needed patching for flash use? Although given you get something when trying to run the game without the imager plugged in, suggests something maybe up with your port two. You shouldn't get anything without the imager plugged in, just a blank screen. 1 Quote Link to comment Share on other sites More sharing options...
Vectrexer Posted November 16, 2016 Share Posted November 16, 2016 Agree with Mayhem. Perhaps have a look at Port 2's pins to see if any are bent? Quote Link to comment Share on other sites More sharing options...
Place Logo Here Posted November 16, 2016 Author Share Posted November 16, 2016 Thanks for the suggestions. 2nd controller works in port #2. Ran the ROM Patcher utility on the Vecmulti and it said no errors found so ROM would not be patched. Also, lightpen is working in port #2. What else can I check? Quote Link to comment Share on other sites More sharing options...
funknflow5200 Posted November 16, 2016 Share Posted November 16, 2016 you have to make sure the sticker on the wheel is facing the vectrex. Quote Link to comment Share on other sites More sharing options...
Place Logo Here Posted November 16, 2016 Author Share Posted November 16, 2016 you have to make sure the sticker on the wheel is facing the vectrex. Ha! Go figure--I had the sticker facing me [facepalm]. I will try again when I get home Probably would have helped if there were instructions with it. Ironically, there is text on the device saying "READ MANUAL BEFORE USING". Anybody seen instructions online? Quote Link to comment Share on other sites More sharing options...
Mayhem Posted November 16, 2016 Share Posted November 16, 2016 That's another good point, about the side of the colour wheel. John mentioned recently that he knows the manual is now gone, he had it on his old website. Getting started:-The color wheel's white index strip is always faced towards the Vectrex.-The white calibration wheel may be installed between imager and wheel on or top of the wheel (usually works best)-The imager is to be plugged into port two of the Vectrex-Enjoy your games. If the wheel is starting up and then stopping, then it does suggest to me you've got it the wrong way around and the device is halting because it can't calibrate properly as it begins. Quote Link to comment Share on other sites More sharing options...
Place Logo Here Posted November 17, 2016 Author Share Posted November 17, 2016 Thanks, everybody. It worked once I had the wheel facing the right way. Amazing device and I am so happy to have one. Madtronix deserves some sort of Vectrex Medal of Honor or something. Quote Link to comment Share on other sites More sharing options...
cubelindo Posted November 29, 2016 Share Posted November 29, 2016 Well I had the same problem with 3D games!! Blank screen. I'm going to try to reverse the wheel. I had like ten people wanting to try the 3D viewer Hope this works! Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
Gilles_B Posted October 8, 2019 Share Posted October 8, 2019 wow. Years later, this thread saved me. I thought I had a big problem. Pfew... Now the original 3D games work, but 3DLOTR doesn't. I need to take apart my VecMulti and see if this fix will help. Quote Link to comment Share on other sites More sharing options...
Vectrexer Posted October 12, 2019 Share Posted October 12, 2019 (edited) On 10/8/2019 at 1:29 PM, Gilles_B said: wow. Years later, this thread saved me. I thought I had a big problem. Pfew... Now the original 3D games work, but 3DLOTR doesn't. I need to take apart my VecMulti and see if this fix will help. In your usage of 3D LOTR with either the Madtronix or GCE 3D Imager, consider that this game can use either the Minestorm color wheel for 3D operation, the Narrow Escape/Crazy Coaster color wheel for 3D operation, or no wheel for 2D only operation. However, the color wheel (disc) used must still be matched to the menu choice made. The color wheel choice is selected in the game's main menu using controller buttons. Button 1 for Wheel 1 uses the Minestorm Wheel. Button 2 for Wheel 2 uses the Narrow Escape/Crazy Coaster Wheel. Button 3 for 2D only does not use any wheel. Button 4 starts the game with the selected color wheel / 2D choice, Edited October 12, 2019 by Vectrexer 1 Quote Link to comment Share on other sites More sharing options...
Gilles_B Posted October 30, 2019 Share Posted October 30, 2019 (edited) yep, yep, finally got to it. Patching solves it. Now I need to read the manual to understand what *all* the controls are doing ? Strike that, it's in the pic above ?? Edited October 30, 2019 by Gilles_B Quote Link to comment Share on other sites More sharing options...
