Flashback Portable: Needed Controller Hacks
371 replies to this topic
#76 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 2:04 AM
Guys...if you alter a ROM in any way, its profile checksum no longer matches.  So it cannot be identified as using a special chip.  The "Defender de-make" proves it.
More conversions I had disassemblies for...
To speed things along, I just altered the equate of VBLANK to be $2E instead of $01.  That should correct migration issues.  Custer's Revenge and Beat'Em & Eat'Em used VBLANK all over the place, no surprise those would not show up.
Jawbreaker and Marauder used $0288 for SWCHA, changed to be the normal $0280.  That should fix the dpad.
Edited by Nukey Shay, Sat Jan 21, 2017 11:31 PM.
#77 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 2:18 AM
Hmm...Acid Drop got clipped somehow.  Trying this again...
Both this one and Words Attack are using non-standard displays (too many lines even for PAL). Those are gonna need work to cut down the display. Words Attack probably isn't worth the effort. Getting closer to 262 for Acid Drop, tho. Will post if I get something stable for the credit sequence.
Edited by Nukey Shay, Sat Jan 21, 2017 11:32 PM.
#78 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,972 posts
  • Always left from right here!
Posted Sat Jan 7, 2017 4:48 AM
I created a NTSC conversion for Acid Drop which displays 270 lines. That should work.
Edited by Thomas Jentzsch, Sat Jan 7, 2017 4:48 AM.
#79 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 4:53 AM
Agh! Didn't see that. Just need to remove VBLANK stores if the screen is pushed down.
#80 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,728 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Sat Jan 7, 2017 5:11 AM
Edited by doctorclu, Sat Jan 7, 2017 5:41 AM.
#81 doctorclu OFFLINE
doctorclu
  • 7,728 posts
Posted Sat Jan 7, 2017 5:19 AM
While the opening screen is positioned down a bit more (and in blue, green was the pal color), the game screen is all framed within the display.
#82 Asaki OFFLINE
Asaki
  • 2,369 posts
Posted Sat Jan 7, 2017 5:29 AM
Wow, somebody's keeping busy =) Awesome work.
#83 doctorclu OFFLINE
doctorclu
  • 7,728 posts
Posted Sat Jan 7, 2017 5:34 AM
I've updated all these on the compatibility list.
https://docs.google....wYNI/edit#gid=0
BTW Nukey, dpad aside, nice work on getting Beat Em and Eat Em to display.
A lot of the Mystique games had that problem if I remember my lightning round of game testing when I first got my AFP.  So what did it take to correct that?   I remember on those games they would have a title screen maybe, and usually the action screen would have a frame with a score and then a nothing but black in the main action part.   Be curious to know what was going on there.
Edited by doctorclu, Sat Jan 7, 2017 5:39 AM.
#84 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 6:00 AM
The use of VBLANK. It would appear that the portable does not emulate it correctly...but it's not required to make a game visible using an emulator. Too bad about Beat'Em & Eat'Em...the checksum fail no longer registers it as using the paddles, so the Dpad defaults back to the joystick. It'll need a controller hack to make it playable.
#85 doctorclu OFFLINE
doctorclu
  • 7,728 posts
Posted Sat Jan 7, 2017 6:09 AM
I was impressed the game displayed at all.  Kinda cool.
Paddles on the AFP are interesting.  The emulation allows for this paddle emulation through the dpad.  I would say, for example, Warlords is approaching decent emulation.  On Breakout it is not as precise as you'd like.   And Kaboom is not as precise either.   But it does try to work with paddle routines to some degree.
As for Beat 'Em and Eat 'Em I honestly was not as familiar with this game, but figured it was a kaboom/paddle type game.   But then again, when we initially tested the games for the compatibility list the Mystique and Playaround games were generally all kinds of broken.  :P
#86 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
  • Enjoying 8 bit gaming in HD!
Posted Sat Jan 7, 2017 8:10 AM
Why did Enduro need fixed? I have it on my portable and didn't notice any issues...
#87 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 8:21 AM
According to the previous list entry, the screen was pushed down on the production model portable making the #cars passed unreadable.
#88 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
Posted Sat Jan 7, 2017 8:56 AM
Hmm, I didn't have this issue with my ROM. Everything was visible.
#89 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,688 posts
  • Medieval Mayhem
Posted Sat Jan 7, 2017 9:05 AM
Are you sure it uses a checksum? From cd-w's experiments it appears to use a detection routine as he was able to get Juno First to work by adding extra bankswitch instructions in unused space.
After testing a few more permutations, the problem appears to be the detection of F4 bankswitching in the FBP rather than the code itself.   It seems the FBP needs a lot of evidence of F4 bankswitching before it will select this method.   The attached code is identical to the previous one, but with the blank space filled with bankswitching ("sta $FFF4, etc.") instructions.
#90 cd-w OFFLINE
cd-w
  • 1,616 posts
  • Juno First!
Posted Sat Jan 7, 2017 9:50 AM
Juno first doesn't use extra RAM - the chacksum may just be for games that need SARA ram?
Chris
#91 Mr SQL OFFLINE
Mr SQL
  • 2,091 posts
Posted Sat Jan 7, 2017 10:15 AM
I think it's using something different than a checksum, like grabbing a specific block or expecting the header to be a certain way because  bB SARA games run fine and they all have different checksums but similar headers and code blocks in common that the emu could be grabbing as a way to identify the extra RAM.
#92 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sat Jan 7, 2017 10:32 AM
Change any single unused byte in a working original that requires a non-stick controller or non-standard bankswitching scheme or added ram. If it fails, it's using game profiles. Or maybe editing the 3rd-to-last byte of the ROM to be +/- $20 from the current value (the upper 3 bits of an 16-bit address are irrelevant to the 2600).
#93 doctorclu OFFLINE
doctorclu
  • 7,728 posts
Posted Sat Jan 7, 2017 11:02 AM
I would be curious to know what type of AFP you have, pre-production (with Space Invaders) or production (without Space Invaders).   Or where you got the Euduro rom image you used.
Here is Euduro standard rom that we at least had in our testing bunch, for the production model that most would have bought:
Here is Nukey's version:
Here is pre-production model, original rom
Here is pre-production with Nukey's version:
As you can see the screen position is a bit higher for the pre-production than the production models.    UNLESS, you have a non-Space Invader version, production model run that actually displayed games a bit higher than most that have tested Enduro.  I've been curious if some production of the production models might have been different.
Edited by doctorclu, Sat Jan 7, 2017 11:07 AM.
#94 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
Posted Sat Jan 7, 2017 11:45 AM
Thanks for the comparison! Will download the new version.
#95 Mr SQL OFFLINE
Mr SQL
  • 2,091 posts
Posted Sat Jan 7, 2017 11:51 AM
Got CBS RAM working - details here with a compatible version of Scrollout Follow the Ball! :)
#96 Asaki OFFLINE
Asaki
  • 2,369 posts
Posted Sun Jan 8, 2017 12:53 AM
It just blows my mind that we can speak of games like Beat 'em and Eat 'em as casually as if it were Castlevania III.
#97 doctorclu OFFLINE
doctorclu
  • 7,728 posts
Posted Sun Jan 8, 2017 2:32 AM
Yeh that and Custer's Revenge.  Yep yep.   For the sake of this thread just code being corrected to work for a slightly different emulator.  Nothing more.  :P
Edited by doctorclu, Sun Jan 8, 2017 2:33 AM.
#98 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sun Jan 8, 2017 4:28 AM
So if the emulator is using detection for the banking scheme, something with very little change should at least start up correctly?  With that in mind, here's a Defender 2 test.  The 3 functions of the second stick have been moved to game select and the 2 difficulties, VBLANK equate changed to $2E, and SC ram written as $FF's (as per Mr SQL's test).  Apart from an immediate hyperspace in Stella, those buttons do not function there (needs more work)...but does the game at least start in the portable?
#99 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Sun Jan 8, 2017 4:46 AM
BTW the type is F8+SC in Stella, and you can set both difficulties in the profile to A to avoid the hyperspace problem + be able to use your smart bombs via game select (this ability is killed if you set a switch to B).
#100 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
Posted Sun Jan 8, 2017 8:51 AM
It does start up on the portable.  However the player two functions do not work on any of the portable (i.e. smart bombs).
