Flashback Portable: Needed Controller Hacks
371 replies to this topic
#101 doctorclu ONLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,734 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Sun Jan 8, 2017 10:19 AM
It does start up on the portable.  However the player two functions do not work on any of the portable (i.e. smart bombs).
Game does start and as mentioned by Nukey and Atarifan88 the other function buttons don't yet work.
#102 DEBRO OFFLINE
DEBRO
  • 1,957 posts
Posted Sun Jan 8, 2017 9:15 PM
Here is an updated Pacman4K for the Flashback Portable.
The unit has an issue with me hitting HMOVE at cycle 74. I did this because I was planning to expand this at one time to do variable flicker. Since I never did this there was no need to avoid the HMOVE lines.
Enjoy...
#103 Arenafoot OFFLINE
Arenafoot
  • 1,369 posts
  • videogamestores.net
Posted Sun Jan 8, 2017 9:22 PM
Enjoy...
Excellent conversion Debro! Thanks!
#104 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,890 posts
Posted Mon Jan 9, 2017 4:25 AM
Correct...I need to track down 2 bits of ram memory to hold the previous state of the difficulty switches, to detect when either of them have changed from the previous frame.  But here's a temporary version that skips those and just uses the game select switch for smart bombs.  Should work on the portable.
#105 doctorclu ONLINE
doctorclu
  • 7,734 posts
Posted Mon Jan 9, 2017 6:36 AM
Enjoy...
Looks a lot cleaner, thank you!  :D
Kablam!!!   (Smart bomb works).  :P
#106 iesposta OFFLINE
iesposta
  • 3,894 posts
  • Retro-gaming w/my VCS
Posted Mon Jan 9, 2017 8:55 AM
Thank you for this!
Since "Game Select" and "Color" are momentary switches (on the FB Portable & the 7800) that makes them perfect to use as an extra button!
#107 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
  • Enjoying 8 bit gaming in HD!
Posted Mon Jan 9, 2017 12:43 PM
Thanks Nukey!  As doctorclu reported earlier, the smart bomb works!  Nice idea using the game select button as it has an "S" on the portable, which now stands for "smart bomb."  :grin:
#108 JeffIrok OFFLINE
JeffIrok
    Space Invader
  • 30 posts
Posted Mon Jan 9, 2017 5:01 PM
Enjoy...
You guys are Saints....
THANK YOU!!!!
Edited by JeffIrok, Mon Jan 9, 2017 5:36 PM.
#109 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,890 posts
Posted Wed Jan 11, 2017 2:54 AM
Looks like the MSB's of the print score vectors are always set to page F8...I used the upper bits there (top 3 bits of addresses are irrelevant to the console).  Works in Stella.  Was the original game's screen pushed down?  If not, the VBLANKs can be put back so it'll work on anything.
#110 doctorclu ONLINE
doctorclu
  • 7,734 posts
Posted Wed Jan 11, 2017 9:50 AM
Honestly the original version doesn't look like it was suffering from the VBLANK problem.  The new version you posted looks and works great.
#111 Inky OFFLINE
Inky
    Gobs of money!
  • 25,915 posts
  • Meh
Posted Wed Jan 11, 2017 10:24 AM
Just for sake of ease, could someone put links to the final versions of these hacs on the first post of this thread?
#112 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 969 posts
Posted Wed Jan 11, 2017 11:23 AM
What is the difference between this and the previous version of Defender 2 with the smart bombs changed to the game select button?
#113 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,890 posts
Posted Wed Jan 11, 2017 12:02 PM
The difficulty switches should work now for the other two functions (inviso and hyperspace).
#114 doctorclu ONLINE
doctorclu
  • 7,734 posts
Posted Wed Jan 11, 2017 3:45 PM
Good idea.  Done!
Tested out the other buttons and inviso and hyperspace do work.  Now that is cool.  Always liked the hyperspace option.
#115 Inky OFFLINE
Inky
    Gobs of money!
  • 25,915 posts
  • Meh
Posted Thu Jan 12, 2017 8:59 AM
Just tried out all the hacks..  THANK YOU EVERYONE!  Tapper, Stargate (Defender II,) and Star Raiders are key games in the 2600 library, and it's awesom that I can play them on the portable!
Edited by Inky, Thu Jan 12, 2017 8:59 AM.
#116 doug0909 OFFLINE
doug0909
    Chopper Commander
  • 242 posts
Posted Thu Jan 12, 2017 4:21 PM
For Circus Atari, Super Breakout, Demons to Diamonds, and other paddle games, would it work if there were hacks for joystick control, maybe just slowing down movement to 1/2, but speeding it up to max if you press a button....
#117 Keatah ONLINE
Keatah
    Missile Commander
  • 21,948 posts
Posted Thu Jan 12, 2017 4:29 PM
Weren't most VCS games designed around speed and timing and accuracy? That means you need to put the paddle where it needs to go in an instant. That's while MIssile Command trackball & mouse hack adds real value to the game.
#118 doug0909 OFFLINE
doug0909
    Chopper Commander
  • 242 posts
Posted Thu Jan 12, 2017 4:52 PM
Yup, those games will never be as good as with analog controls.  The question is what's the best option for digital controls....  Another option might be speed increase while button is held, which stops when button is released (with reversion to slowest speed when joystick centers?)
#119 doug0909 OFFLINE
doug0909
    Chopper Commander
  • 242 posts
Posted Thu Jan 12, 2017 4:55 PM
Alternatively maybe keep full speed and button slows movement?  or three speeds, fastest with upper diagonals, slowest with lower diagonals, average speed with left-right....
#120 doctorclu ONLINE
doctorclu
  • 7,734 posts
Posted Thu Jan 12, 2017 11:58 PM
Here is a video for those that haven't had a chance to try the latest hacks for the Atari Flashback Portable.
#121 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,890 posts
Posted Fri Jan 13, 2017 4:34 AM
Raiders of the Lost Ark:  The left stick only uses 3 actions, so I used select and reset to move the marker and the color switch to drop.  To reset a new game when one is in progress, you can use the right difficulty for now (it'll freeze if you leave it there).  Gripes / suggestions?
#122 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,890 posts
Posted Fri Jan 13, 2017 4:58 AM
Yikes!  Does Tapper's screen jitter like that, or is this a bad video?
#123 doctorclu ONLINE
doctorclu
  • 7,734 posts
Posted Fri Jan 13, 2017 8:06 AM
Looks like I got another video to make when I get off work.  :)
I'll also cover Tapper/BudTapper.  The one I played was a older copy of the game.
#124 Asaki OFFLINE
Asaki
  • 2,369 posts
Posted Fri Jan 13, 2017 8:11 AM
For Circus Atari... would it work if there were hacks for joystick control...
There's a ROM floating around...: http://atariage.com/...with-joysticks/
#125 ls650 OFFLINE
ls650
  • 7,445 posts
  • Atari rocks!
Posted Fri Jan 13, 2017 9:03 AM
Ive played the Tapper Portable rom a few times. Works great!
