800XL power supply loose connection questions
Xl Power Ps Connector
10 replies to this topic
#1 eegad OFFLINE
eegad
    Moonsweeper
  • 372 posts
Posted Sun Nov 27, 2016 8:24 AM
While messing around on my 800xl yesterday, the colors on screen were sometimes strange. Turn off and on, wiggle cables, the colors would return to the correct colors...but change after a while. Then while in Basic, I watched as the background color drifted from blue to green over a 30 second span of time. At first I thought it was the monitor cable connector, but ended up discovering that I could make the colors change by slowly wiggling the cable of the power connection where it attaches to the connector plug. If it were an "ingot" I'd probably just toss it. But it is a black brick, so I'd prefer to keep it if it's easy to fix. A couple questions...
- I've seen the pin outs for the plug. 3 +5 and 3 grounds. Are there actually 6 wires inside that power cable, or is it just 2 wires, each attached to 3 pins?
- out of curiosity, I've wondered a few times through the years why Atari used a power connector with so many pins. Are those 3 "pairs" of pins connected to different parts of the circuit board, or are the 3 +5v pins tied together and just connected at one point on the board. If tied together, what was the point of having 3 separate pins?
- back in the day I was into programming...the software side of things, not the hardware, so I never bothered to learn much about circuits, etc. But again, out of curiousity, how would a loose connection in that cable cause the odd color shifting I was seeing? I would expect a bad connection to cause the power to just cut out completely, not shift screen colors but otherwise keep functioning. Unless the 3 pins do have separate connections and just the pin going to the video circuit has a loose connection?
- and lastly, the most obvious question.... What's my best source for getting a replacement connector? And possibly with wiring already soldered to the pins so that I can skip that somewhat difficult (for me) step and just splice the wires.
Much thanks for any replies.
#2 tjlazer OFFLINE
tjlazer
  • 2,148 posts
  • Retro Atari Addict
Posted Sun Nov 27, 2016 8:03 PM
You can get a new one from B&C Computervisions.  I bought one and it works great.
http://www.ebay.com/...sd=140966936256
Here are all the ones you can buy
Stay away from the top middle one
Edited by tjlazer, Sun Nov 27, 2016 8:05 PM.
#3 tjlazer OFFLINE
tjlazer
  • 2,148 posts
Posted Sun Nov 27, 2016 8:09 PM
http://atariage.com/...th-atari-800xl/
#4 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,089 posts
Posted Sun Nov 27, 2016 9:34 PM
The colour change is probably because it's broken sufficiently that not enough current can get through.
Mine went bad too, I just resoldered it and reinforced with a bit of silicone heat glue.  There's only 2 pins actually involved in the power process so it's an easy fix.
#5 BillC OFFLINE
BillC
  • 1,910 posts
Posted Sun Nov 27, 2016 9:52 PM
I believe one  of the reasons Atari used the 7-pin DIN plug for power may have been so it couldn't be mistakenly plugged into the monitor jack.
#6 ryanmercer OFFLINE
ryanmercer
    Moonsweeper
  • 433 posts
Posted Wed Nov 30, 2016 9:21 AM
Good god he wants more to ship it than he sellsit for. California to Indiana isn't 15.45 in shipping, especially with the delivery estimate of December 12th ordered on november 30th.
#7 MVladimir OFFLINE
MVladimir
    Combat Commando
  • 9 posts
Posted Sun Dec 4, 2016 3:33 PM
You can use any +5v PSU for 1.5A or more current. Only need to desolder/solder old / new connector.
#8 brenski OFFLINE
brenski
  • 1,841 posts
  • How should we f**k off, oh Lord ?
Posted Sun Dec 4, 2016 4:59 PM
or, alternatively,
1] cut the cable of new 5v psu (near to connector end)
2] cut cable of Atari PSU (approx 10" from 7-pin end)
join two together - no soldering required
#9 Larry OFFLINE
Larry
  • 4,102 posts
Posted Sun Dec 4, 2016 10:12 PM
Are you sure it is the plug and not the mobo jack/connector? Ive had to replace two xl jacks for the exact conditions you mention. In a perfect world, you might replace both.
Long time ago when the original MyIDE plus flash came out, I tried an IBM microdrive in place of the CF card. The microdrive took additional current when writing, and the colors went funky during writes. Also, if you have oxidation on the pbi contacts of a Black Box, you can also get similar shift. BB has tin contacts.
Larry
#10 eegad OFFLINE
eegad
    Moonsweeper
  • 372 posts
Posted Mon Dec 5, 2016 7:45 AM
Definitely in the power supply plug. Using another power supply works fine (can wiggle the cord/connector all around with no color shifting or other anomalies).
#11 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,743 posts
Posted Tue Dec 6, 2016 7:55 PM
if that's the case just order a new din plug solder it up your good to go
Also tagged with one or more of these keywords: Xl, Power, Ps, Connector
