New MAME release
186 replies to this topic
#176 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,861 posts
  • Technology Samurai
Posted Tue Sep 18, 2018 7:41 PM
It's totally true. I got back into the Amiga 2000 after nearly 20 years away, and not just the performance, but how primitive the UI felt really struck me. We're very spoiled. ;)
I... um, no sir!
#177 Tursi OFFLINE
Tursi
  • 5,418 posts
  • HarmlessLion
Posted Tue Sep 18, 2018 11:21 PM
I... um, no sir!
Sorry, but I want my right-click context-sensitive pop up menus. Moving the mouse in Directory Opus felt so old fashioned. ;)
Still remembering the tricks though... going to take time for it all to come back.
#178 Casey OFFLINE
Casey
    Moonsweeper
  • 318 posts
Posted Mon Oct 29, 2018 3:56 PM
Just more of a curiosity question than anything else - but what's left in the TI-99 family to emulate that hasn't been?  99/4B and 99/5 ?  Or is the 99/4B = 99/5 ?  I had a look over at Fabrice's site and it looks like the OS in the 99/4B (or 99/5) is a bit unique as well.  What about the 99/7 - did that even make it far enough that one exists that could be emulated?
#179 mizapf ONLINE
mizapf
  • 3,472 posts
Posted Mon Oct 29, 2018 4:05 PM
99/4B and 99/5 are on my list, now that the Hexbus is working. The only challenge is that TI packed a lot into custom chips so that I will have to analyse the ROMs to find out the relevant CRU ports and mapped addresses, i.e. it will become a behavioral-based emulation rather than a circuit-based emulation. I don't want to give a date when this will be done, though.
#180 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Fri Nov 2, 2018 2:00 PM
OK,
Some people have seen the TIPI in action using a card to communicate with a Raspberry PI.
Is there some way the TIPI can be emulated in MAME and then use TIIMAGETOOL to interface the TIPI to a socket specifically for TCP access?  Obviously, it does not make sense and is highly unlikely an emulated system could be used to talk to a secondary (RPI) system, so what I am wondering is if there some other application the TIPI interface can communicate to accomplish the TCP access?
If there is no tool for the final communication piece from TIIMAGETOOL to some other tool say under a Windows system, then it all meaningless anyway.
This assumes we have Matt's blessing for TIPI emulation, etc.  Just trying to think how we can expedite application development.
Beery
#181 arcadeshopper OFFLINE
arcadeshopper
  • 4,056 posts
Posted Fri Nov 2, 2018 3:21 PM
OK,
Beery
Basically.. you don't need the pi at all.. everything on the pi side is python which can run on the PEECEE running mame..  we just need the socket emulation and dsr to pipe to a python engine
Greg
#182 Asmusr OFFLINE
Asmusr
  • 2,997 posts
Posted Fri Nov 9, 2018 12:57 PM
Greg
Sorry for hijacking this thread, but I have been pondering how to do this in JS99'er. I don't think running the python code within the browser is going to work without major changes, even though implementations of python exist, e.g. http://www.skulpt.org/. So the python code would have to run separately, either on the user's local machine, which would permit it to access the file system, or on the server with some kind of cloud storage, which again would require changes.
The main problem is that exposing the raw socket interface over HTTP is probably going to be way too slow since it had to be coded in c on the PPi to keep up with the TI. So instead of sending individual bytes JS99'er would probably need to send full messages over the wire, but that might not even be fast enough and I'm not sure if that would work for all purposes.
I imagine it would also be difficult to fit something very bespoke like this into the MAME code. Tursi would probably have the best chance of emulating the TIPI since he could use a native interface between Classic99's c code and the python code.
#183 ralphb OFFLINE
ralphb
    Dragonstomper
  • 598 posts
Posted Sun Dec 9, 2018 11:29 AM
How on earth do I set the window size on the command line in version 204?  There are options for fullscreen (laaarge) and -no-max (the size of a stamp).  The -prescale option has no effect at all, and -window-resolution seems to be retired.  The venerable -display option is also not known.
It seems that the internet also doesn't know how to get decently sized windows.
#184 mizapf ONLINE
mizapf
  • 3,472 posts
Posted Sun Dec 9, 2018 3:54 PM
I'm using the resolution switch in mame.ini, setting it to e.g. 960x720. It is located in the section "OSD PER-WINDOW VIDEO OPTIONS".
If you want to set in on the command line:
./mame64 ti99_4ae -window -resolution 960x720
I don't know the switches -no-max and -window-resolution you mentioned, though. Mind that there is a blank between -window and -resolution.
#185 ralphb OFFLINE
ralphb
    Dragonstomper
  • 598 posts
Posted Thu Dec 20, 2018 11:16 AM
I have a new feature request.  :)
It's not TI 99-specific, but is there a way to enable the memory window (and possible others) to allow copying?  It's no fun typing >80 bytes into my editor.  :)
You could also have an option to save the displayed data, but this is less versatile, and probably more work.
#186 ralphb OFFLINE
ralphb
    Dragonstomper
  • 598 posts
Posted Fri Dec 21, 2018 7:27 AM
And what happens if I modify one of the system ROMs?  MAME says "WRONG CHECKSUMS. The machine might not run correctly."  But is this ROM still used, or ignored entirely?
If it's ignored, how can I convince MAME to still use it (i.e., which file do I have to edit   :) )?
#187 mizapf ONLINE
mizapf
  • 3,472 posts
Posted Fri Dec 21, 2018 12:55 PM
This is just a warning (it says it "might not run correctly"). The checksums are contained in the respective components - drivers/ti99_4x.cpp contains the checksums of its ROMs and GROMs, the checksums of cartridges are contained in hash/ti99_cart.xml, and each PEB card has its own checksums.
