Testing the new Stella TIA core
stella tia core testers
386 replies to this topic
#376 stephena ONLINE
stephena
  • 3,355 posts
  • Stella maintainer
Posted Tue Jul 25, 2017 1:40 PM
It has to do with the fact that the display is shifted somewhat.  It seems to be inherent in how an NTSC signal is encoded, so I'm not sure it would even make sense to disable them, even if we could.
#377 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,937 posts
  • Always left from right here!
Posted Tue Jul 25, 2017 2:34 PM
I didn't want to criticize the lines at all, only wanted to state that they are not depending any of the parameters.
BTW: PAL shows them too.
#378 stephena ONLINE
stephena
  • 3,355 posts
  • Stella maintainer
Posted Tue Jul 25, 2017 4:08 PM
Yes, this is an idiosyncrasy of the TV effects.  Technically they're only defined for NTSC modes, but we apply them for PAL too.  This is mostly because I've never seen a PAL TV before, and I don't know what the output should look like.
#379 DirtyHairy OFFLINE
DirtyHairy
    Moonsweeper
  • 496 posts
Posted Tue Jul 25, 2017 4:27 PM
I am curious about the actual origin of those lines, too. My theory is that this is an artifact caused by the shadowing that occurs at vertical high-contrast edges, both with Blargg and with actual TV signals. The Draconian logo uses flickerblinds, so each single frame shows a pattern of eight colored pixels alternating with eight blank pixels. This produces edges, and my suspicion is that the shadowing caused by these edges creates the dark lines that can be observed ;) The same effect can be seen with other ROMs that use flickerblinds.
Edited by DirtyHairy, Tue Jul 25, 2017 4:29 PM.
#380 RevEng OFFLINE
RevEng
    Bit Player
  • 5,105 posts
Posted Tue Jul 25, 2017 5:19 PM
In terms of the non-emulated effect, the edges are just real-world square waves (luma) taking a slower aount of time to rise vs fall. Flickerblinds relies on signal edges to line up...
       ______
______|      |______  odd frame
______        ______
      |______|        even frame
But in the real world, we get something like...
        _____
_______/     |______  odd frame
_______       ______
       |_____/        even frame
When I created my first flickerblinds display I was a bit bummed over the black gaps. But I suspect most people don't get as distracted by them as programmers do.
#381 DirtyHairy OFFLINE
DirtyHairy
    Moonsweeper
  • 496 posts
Posted Wed Jul 26, 2017 1:30 AM
Interesting, thanks alot. So is the effect that I described as "shadowing" around edges actually the finite raise time of the luma edges?
#382 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,937 posts
Posted Wed Jul 26, 2017 1:53 AM
In terms of the non-emulated effect, the edges are just real-world square waves (luma) taking a slower amount of time to rise vs fall.
Vice versa, isn't it?
Both are not immediate, but because the lines are dark, the fall must be faster than the raise. And depending on the difference, the lines are more or less visible.
BTW: I wonder if phosphor plays a role here too.
Edited by Thomas Jentzsch, Wed Jul 26, 2017 1:54 AM.
#383 RevEng OFFLINE
RevEng
    Bit Player
  • 5,105 posts
Posted Wed Jul 26, 2017 5:54 AM
I believe I have it the right way around. If the fall were slower than rise, we'd have brighter overlap between the lined up regions. If it's easier, consider which scenario has more average high, or more average low.
I was originally going to comment on phosphor - I'm not sure how much it contributes, because I haven't checked to see if the effect is present on LCD. Whenever we talk about CRT phosphor, it also involves persistence of vision too. So square waves here has to mean everything from electrons in TIA to nerve impulses. Confirmation of the effect on LCD would put the reason for the effect back to signal, since LCD doesn't strongly trigger persistence of vision like CRT does, and has no phosphor.
#384 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,937 posts
Posted Wed Jul 26, 2017 5:58 AM
Agreed. I got you the wrong way, probably just my non-perfect English. icon_smile.gif
#385 RevEng OFFLINE
RevEng
    Bit Player
  • 5,105 posts
Posted Wed Jul 26, 2017 6:19 AM
Looking at my original non-perfectly worded English, I see where the confusion occurred. The blame is all mine. :)
#386 devwebcl OFFLINE
devwebcl
  • 1,238 posts
Posted Sat Nov 25, 2017 8:05 AM
is there a way to run faster Stella emulator ?
(1000% etc, depending on the host machine's speed)
I found that feature in other emu's but I can't find that option in Stella
#387 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,937 posts
Posted Sat Nov 25, 2017 10:03 AM
In Video Settings you can set the Framerate to 300 and disable VSYNC.
Also tagged with one or more of these keywords: stella, tia core, testers
