Aardvark for Atari VCS/2600
275 replies to this topic
#26 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 24,085 posts
  • Always left from right here!
Posted Tue Dec 13, 2016 7:00 AM
Most likely in his blog.
#27 iesposta OFFLINE
iesposta
  • 3,916 posts
  • Retro-gaming w/my VCS
Posted Tue Dec 13, 2016 8:29 AM
Good idea! :) made me to think in reusing the 48-pixel score routine for displaying the aardvark :) Added to TODO list.
It doesn't have to be that complicated.
There's a Tool to design HMOVE double wide shifted sprites! (Thomas was correct.)
http://atariage.com/...or-sprite-tool/
#28 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Tue Dec 13, 2016 10:18 AM
The above links to the single player version of the tool.
This version is the one I used for the dragon in Medieval Mayhem, it uses both players for a two-color image.
Do note that's still using my old graphics.h file where the binary notation is done using _ for 0 and X for 1. To convert to standard binary do a find/replace of:
  • zz/%
  • _/0
  • X/1
Let me know if you plan to use the two-color converter and I'll update it to use standard binary notation.
#29 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Tue Dec 13, 2016 10:40 AM
I have a few other converters here in the Utility listing.
I do have more, such as a 128 pixel converter on my local machine that I'm using for the bus stuffing demos.  So if you don't see a converter you need just ask, it's probable that I have it on my local drive and just need to upload it to my site.
The images need to be somewhere online.  You can post an image on AtariAge and use it, such as this one:
which has a URL of http://atariage.com/...-1481647049.gif
#30 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,898 posts
  • Coding something good
Posted Tue Dec 13, 2016 3:35 PM
Wow! Thanks :) I'm sure these will be useful
#31 iesposta OFFLINE
iesposta
  • 3,916 posts
Posted Tue Dec 13, 2016 11:12 PM
If you want to try, here's my results from using SpiceWare's Graphic Tools.
It seems to have turned out longer than I was planning? Maybe not.
It is colored so the tool makes Player0 and Player1.
You don't have to use different colors.
It is still 2 double-wide size sprites, just HMOVED around to appear more high resolution.
You already are using P0 & P1 for the aardvark.
I don't have a clue about ShiftLtoR and ShiftRtoL code :D
Used (very small): AardvarkGreen80a.gif
Output:
Adjusting data for Sprite 0
B4 y =0
Image = XXXXX___
xpos = 8
shift = -1
y =0
Image = _XXXXX__
xpos = 6
shift = 1
Adjusting data for Sprite 1
B4 y =2
Image = XXX_____
xpos = 8
shift = -1
y =2
Image = _XXX____
xpos = 6
shift = 1
Note: these graphics use graphics.h
ImageA1
ImageA1
 .byte zz_XXXXX__ ; 0
 .byte zzXXXXXX__ ; 1
 .byte zzX___XXX_ ; 2
 .byte zzX____XXX ; 3
 .byte zzXXX____X ; 4
 .byte zzXX___XXX ; 5
 .byte zzXXX__X__ ; 6
 .byte zzXXXX_X__ ; 7
 .byte zzXXXXXXX_ ; 8
 .byte zzXXXXXXX_ ; 9
 .byte zzXXXXX_X_ ; 10
 .byte zzXXXXXX_X ; 11
 .byte zzXXXXXXXX ; 12
 .byte zzXXXXXXXX ; 13
 .byte zzXX__XXXX ; 14
 .byte zzX___XXXX ; 15
 .byte zzX____XXX ; 16
 .byte zzX____XXX ; 17
 .byte zzXX____XX ; 18
 .byte zzXX____XX ; 19 ImageB1
 .byte zz________ ; 0
 .byte zz________ ; 1
 .byte zz_XXX____ ; 2
 .byte zzXXXX____ ; 3
 .byte zzXXXXXX__ ; 4
 .byte zzXXXXXXX_ ; 5
 .byte zzXXXXX_X_ ; 6
 .byte zzXXXXX___ ; 7
 .byte zzX_XXXXXX ; 10
 .byte zzX___XXXX ; 11
 .byte zzX___XXXX ; 12
 .byte zzX__XXXX_ ; 13
 .byte zzX_XXXX__ ; 14
 .byte zzXXXX__X_ ; 15
 .byte zzXX____X_ ; 16
 .byte zzXX____X_ ; 17
 .byte zzXX____X_ ; 18
 .byte zzXX____X_ ; 19 Shift1LtoR
 .byte HMOVE_R6 | HMOVE_0 >> 4 ; 0 x0= 6 x1= 0
 .byte HMOVE_R1 | HMOVE_0 >> 4 ; 1 x0= 7 x1= 0
 .byte HMOVE_L1 | HMOVE_R6 >> 4 ; 2 x0= 6 x1= 6
 .byte HMOVE_R5 | HMOVE_R1 >> 4 ; 3 x0= 9 x1= 7
 .byte HMOVE_R7 | HMOVE_L3 >> 4 ; 4 x0=16 x1= 4
 .byte HMOVE_R2 | HMOVE_0 >> 4 ; 5 x0=18 x1= 4
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 6 x0=17 x1= 3
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 7 x0=16 x1= 2
 .byte HMOVE_0 | HMOVE_L1 >> 4 ; 8 x0=16 x1= 1
 .byte HMOVE_R1 | HMOVE_0 >> 4 ; 9 x0=17 x1= 1
 .byte HMOVE_R1 | HMOVE_0 >> 4 ; 10 x0=18 x1= 1
 .byte HMOVE_L2 | HMOVE_L1 >> 4 ; 11 x0=16 x1= 0
 .byte HMOVE_R1 | HMOVE_0 >> 4 ; 12 x0=17 x1= 0
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 13 x0=18 x1= 1
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 14 x0=19 x1= 2
 .byte HMOVE_R1 | HMOVE_R4 >> 4 ; 15 x0=20 x1= 6
 .byte HMOVE_0 | HMOVE_0 >> 4 ; 16 x0=20 x1= 6
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 17 x0=21 x1= 7
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 18 x0=22 x1= 8
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 19 x0=23 x1= 9 Shift1RtoL
 .byte HMOVE_L6 | HMOVE_0 >> 4 ; 0
 .byte HMOVE_L1 | HMOVE_0 >> 4 ; 1
 .byte HMOVE_R1 | HMOVE_L6 >> 4 ; 2
 .byte HMOVE_L5 | HMOVE_L1 >> 4 ; 3
 .byte HMOVE_L7 | HMOVE_R3 >> 4 ; 4
 .byte HMOVE_L2 | HMOVE_0 >> 4 ; 5
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 6
 .byte HMOVE_R1 | HMOVE_R1 >> 4 ; 7
 .byte HMOVE_0 | HMOVE_R1 >> 4 ; 8
 .byte HMOVE_L1 | HMOVE_0 >> 4 ; 9
 .byte HMOVE_L1 | HMOVE_0 >> 4 ; 10
 .byte HMOVE_R2 | HMOVE_R1 >> 4 ; 11
 .byte HMOVE_L1 | HMOVE_0 >> 4 ; 12
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 13
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 14
 .byte HMOVE_L1 | HMOVE_L4 >> 4 ; 15
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 17
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 18
 .byte HMOVE_L1 | HMOVE_L1 >> 4 ; 19 ;
End
Edited. What I posted before did not make sense
Edited by iesposta, Wed Dec 14, 2016 4:29 AM.
#32 Kosmic Stardust OFFLINE
Kosmic Stardust
    Cyborg Bounty Hunter
  • 18,462 posts
  • Alita Jean
Posted Wed Dec 14, 2016 1:04 AM
Neato. Do the "bus stuffing demo" work on Harmony?
#33 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Wed Dec 14, 2016 9:10 AM
Nicely done!
I don't have a clue about ShiftLtoR and ShiftRtoL code :D !
When the dragon enters the screen she starts out moving Left-to-Right, then turns around and moves Right-to-Left. REFPx is used, so the graphic data is the same for both directions, but the HMOVE values to shift the players are different.
#34 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Wed Dec 14, 2016 9:17 AM
Yes, that link has 5 demos so far and they all work on the Harmony. While we are working on support in Stella, the features of the Bus Stuffing Driver are undergoing major changes which require Stella to be updated as well. As such we won't release Stella support until we've finalize the Bus Stuffing Driver, which will hopefully be in the first half of 2017.
#35 Kosmic Stardust OFFLINE
Kosmic Stardust
  • 18,462 posts
  • Alita Jean
Posted Wed Dec 14, 2016 6:19 PM
Sounds awesome. My Harmony is the older model purchased in 2012, v1.05 firmware. Do I need to upgrade to v1.06, or is that only for the compatibility fix affecting Encore models?
I'd love to be able to test out some of these. :grin:
#36 davidbrit2 OFFLINE
davidbrit2
    Dragonstomper
  • 516 posts
Posted Wed Dec 14, 2016 6:47 PM
I am 110% in favor of devaluing ROM hoarders' sacred prototypes. Awesome stuff; I'll have to try this on the Harmony.
#37 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Wed Dec 14, 2016 7:28 PM
v1.05 firmware
that's what mine's running.
#38 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,085 posts
Posted Mon Jan 16, 2017 2:36 PM
Any updates?
#39 nanochess OFFLINE
nanochess
  • 5,898 posts
Posted Mon Jan 16, 2017 5:57 PM
Any updates?
As soon as I have more time :) next time the aardvark should exit the screen when all points are eaten.
#40 nanochess OFFLINE
nanochess
  • 5,898 posts
Posted Thu Jan 19, 2017 5:03 PM
Aardvark now exits the level, and also has music and sound effects :grin:
Check post #1 ;)
Edit: just realized I forgot the tongue sound effects, well, for next version!
Edit 2: now I need to re-write the TODO list, less things missing!
#41 The Maxx OFFLINE
The Maxx
    Star Raider
  • 89 posts
Posted Thu Jan 19, 2017 8:30 PM
This is excellent.  I always thought this was a cool arcade game!  It has been awhile since I played the arcade, but you seem to be replicating the experience very well.  :)
Three things (admittedly, I did not read the rest of the thread, so maybe some of this has been mentioned)
1. Sometimes a worm will walk on top of (and in the same direction as) an ant.  This is deadly since you have to eat the ant or you will die, but if you eat the worm you will die.
2. In my opinion, the controls are a little too precise... It seems like if you are pushing down and left... and your tongue is over a hole, it should go down.  However, you'll miss it.  So I seem to spend more time just finding the hole than should be necessary.  I wouldn't be able to read your code, but I'm imagining from some of my own games that it might be remedied by changing the sequence of events - meaning, check if the joy0down/up and reposition the y coordinate before checking joy0right/left.  Just a guess.  ;)
3. I think I found a bug.  I had reached down into the bottom of the anthill when an ant spawned on top of my aardvark's tongue.  The death music kind of went into an infinite loop.  I know how vague this description is, so I took a small video to show the location of the ant (my aardvark's tongue had nearly, if not fully, reached the end of the tunnel) and for you to witness the music loop yourself.
Nice work!  This one is becoming so great!  :D  (My apologies if any of this has been mentioned before)
#42 Arenafoot OFFLINE
Arenafoot
  • 1,383 posts
  • videogamestores.net
Posted Thu Jan 19, 2017 8:42 PM
I agree. The game is fun, but lining up the tongue right over the hole doesn't seem to work later on in the game - especially after the first bottom ant has been eaten.
#43 nanochess OFFLINE
nanochess
  • 5,898 posts
Posted Thu Jan 19, 2017 9:13 PM
Thanks for the bug report, I'll address it in the next release. The interface handling also surely will be addressed but not so soon.
#44 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,085 posts
Posted Fri Jan 20, 2017 1:16 AM
That and/or joystick direction priority should help. E.g. if you press left and down, down is always checked first.
#45 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,085 posts
Posted Fri Jan 20, 2017 11:52 AM
How about a death (or stunned) animation for the Aardvark? E.g. it could collapse or tilt to one side.
#46 nanochess OFFLINE
nanochess
  • 5,898 posts
Posted Fri Jan 20, 2017 9:43 PM
It's in my TODO list :)
#47 JohnH OFFLINE
JohnH
    Combat Commando
  • 5 posts
Posted Tue Jan 24, 2017 3:59 AM
Responding to something from earlier:
I only found that the days become shorter, so the spider appears sooner and sooner. Eventually the spider will appear so soon, that the player has no chance to clear the screen before. That's pretty lame and IMO should be changed.
Spider management is an important part of late game strategy.  The spider doesn't kill you until it reaches the tip of your tongue (traveling from the base), and is cleared from the screen when you eat a Queen Ant like all the other bugs (it immediately respawns from its starting point).  The appearance of the spider is by no means the end of your game.
Edited by JohnH, Tue Jan 24, 2017 4:00 AM.
#48 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,085 posts
Posted Tue Jan 24, 2017 6:41 AM
That was me. :)  I know about the Queen Ants and how to use them as part of the strategy.
But have a look at this video. Here you can see:
  • around hill #15, the spider arrives very soon and the player hardly makes any significant score progress anymore
  • around hill #20, the sun starts at the very left, so there is zero chance to clear the screen
This may have been acceptable for an Arcade, where long plays were not wanted. But for a homebrew, the game shouldn't become unfair.
#49 JohnH OFFLINE
JohnH
    Combat Commando
  • 5 posts
Posted Tue Jan 24, 2017 7:53 AM
Hill 15 is a very advanced level in the arcade, let alone 20.
I make no judgement on the difficulty of a homebrew game over an arcade game.  I think the game should probably have the same difficulty advancement in both versions.  Anyway, it's hard enough to write homebrew without imposing additional game design standards besides.
#50 Tarzilla OFFLINE
Tarzilla
  • 2,107 posts
  • Huh?
Posted Tue Jan 24, 2017 8:47 AM
That's why the 2600 has a Difficuty switch...so games could be enjoyed by different ages and skill levels.
