+DZ-Jay Posted January 23, 2017 Share Posted January 23, 2017 P.S. Constants.bas has a nice macro that does the calculations automatically: #where = screenadrs(10,11) The first number is the column and the second number is the row.. I was just about to point this out. Perhaps it'll be useful if you update your example to take full advantage of the constants and macros in Constants.bas. That way, people can think at a higher cognitive level when trying to understand the example, and also to illustrate how to use those constructs. Remember, in the SDK, we're sort of pushing bossing forcing beating-over-the-head encouraging people to use Constants.bas as their basic toolkit in all their programs. -dZ. Quote Link to comment Share on other sites More sharing options...
catsfolly Posted January 24, 2017 Share Posted January 24, 2017 I was just about to point this out. Perhaps it'll be useful if you update your example to take full advantage of the constants and macros in Constants.bas. That way, people can think at a higher cognitive level when trying to understand the example, and also to illustrate how to use those constructs. Remember, in the SDK, we're sort of pushing bossing forcing beating-over-the-head encouraging people to use Constants.bas as their basic toolkit in all their programs. -dZ. You have a good point, but sometimes I think it is better to get an example program done quickly (to answer someone's question), rather than wait until the example code is "perfect". In this case, I didn't know if an IntyBasic routine could scroll half the screen fast enough to beat the STIC chip's display update. I thought maybe an assembly language routine would be necessary. So after I did a quick test and found that it could work. I wanted to get that information out. So as a result, I now find myself answering questions about non-obvious parts of my code... For myself, it is faster to type (BACKTAB_ADDR + 20 * 3 + 5) than to lookup the screenadrs macro and check whether the row or column comes first. I think that at some point, IntyBasic programmers have to "GROK" that the screen is a 20 column wide by 12 rows high block of continuous memory, and that writing past the end of the screen can crash the system. Otherwise, they are not going to have much success printing on the Intellivision... Catsfolly Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted January 24, 2017 Share Posted January 24, 2017 You have a good point, but sometimes I think it is better to get an example program done quickly (to answer someone's question), rather than wait until the example code is "perfect". In this case, I didn't know if an IntyBasic routine could scroll half the screen fast enough to beat the STIC chip's display update. I thought maybe an assembly language routine would be necessary. So after I did a quick test and found that it could work. I wanted to get that information out. So as a result, I now find myself answering questions about non-obvious parts of my code... For myself, it is faster to type (BACKTAB_ADDR + 20 * 3 + 5) than to lookup the screenadrs macro and check whether the row or column comes first. I think that at some point, IntyBasic programmers have to "GROK" that the screen is a 20 column wide by 12 rows high block of continuous memory, and that writing past the end of the screen can crash the system. Otherwise, they are not going to have much success printing on the Intellivision... Catsfolly So... You won't be updating it then? 1 Quote Link to comment Share on other sites More sharing options...
First Spear Posted September 27, 2019 Share Posted September 27, 2019 On 12/15/2016 at 1:58 PM, GroovyBee said: Solved the problem just using IntyBASIC commands :- ArrayOfStrings.bas 3.26 kB · 49 downloads I made a simple change to make "HELLO WORLD" "Hello World" (using lower case) and got garbled output. I am unable to see why that is happening. Could you help me get a clue? Thanks! Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted September 27, 2019 Share Posted September 27, 2019 Could you be in Foreground/Background mode instead of Color Stack mode? FG/BG mode is limited to only the 1st 64 GROM characters which are numbers, most symbols, and upper case letters (no lower case). Quote Link to comment Share on other sites More sharing options...
