Sega Genesis 3 and 6 button controller project.
32 replies to this topic
#26 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Tue Sep 5, 2017 6:48 PM
This is what I wound up with last night before I went to bed.
Genesis VS 800 XL...
Aside from a 1.4 volt difference due to some trickery with a resistor, it's pretty dang close. I got it to within 0.5 microseconds of the Genesis timing.
Here's the code thus far:
10 ; Sega Genesis 6 Button Controller
20 ; Driver v0.1
30 .OPT OBJ
40 PACTL = $D302
50 PORTA = $D300
60 *= $0600
70 INIT PLA
80 LDY # <VBI
90 LDX # >VBI
0100 LDA #$07
0110 JSR $E45C
0120 LDA #$38
0130 STA PACTL
0140 LDA #$FF
0150 STA PORTA
0160 LDA #$3C
0170 STA PACTL
0180 RTS
0190 VBI
0200 LDX #$00
0210 LDY #$FF
0220 STX PORTA
0230 JSR WAIT
0240 STY PORTA
0250 NOP
0260 NOP
0270 NOP
0280 NOP
0290 STX PORTA
0300 JSR WAIT2
0310 STY PORTA
0320 NOP
0330 NOP
0340 NOP
0350 NOP
0360 STX PORTA
0370 JSR WAIT2
0380 STY PORTA
0390 NOP
0400 NOP
0410 NOP
0420 NOP
0430 STX PORTA
0440 JSR WAIT
0450 STY PORTA
0460 JMP $E462
0470 WAIT LDA DELAY
0480 STA LOOP
0490 COUNT DEC LOOP
0500 BNE COUNT
0510 RTS
0520 WAIT2 RTS
0550 LOOP
0560 *= *+1
0570 DELAY .BYTE $01
It's ugly and unrefined, but it was only to get the timing as close as possible to the Genesis.
I don't know what happened to it, but I had a more advanced driver than this somewhere and misplaced the ATR file since I worked on this last.
Oh well, not the first time I've started over. :(
#27 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Tue Sep 5, 2017 10:09 PM
Tonight's' progress report: Rewrote the section that gets the status of the Start and A buttons. I decided that instead of using a memory location somewhere inside my program space, I would just stuff the values into the shadow registers for STRIG2 and PADDL4 since they are unused on the XL/XE, and it has the added bonus of working with STRIG(2) and PADDLE(4) commands in BASIC for quick testing.
And I remember now why I said this....
I tweaked the handler just a tad and now instead of reading the start button 30x/sec (every other vblank), it reads it every single one. But, if it *thinks* the start button is pressed, it waits an extra vbi cycle to verify that it is indeed the start button before it updates the register.
I need to draw out the circuit so other people can build it if interested. The whole thing is about $10.00 worth of parts, depending on where you purchase them.
I'll have to redo that part tomorrow. Time for bed.
#28 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Wed Sep 6, 2017 11:41 PM
My mom made a surprise visit tonight, so didn't get very much done. I restored full 3btn function to my driver and realized that I'm an idiot in the process. No point in using PADDL4 as a register for the start button when I can use PADDL1, since it's on the same damn joystick port... :/
Cleaned up the code a bit & temporarily removed 6btn polling from the PWM output driver until I polish the 3btn function to perfection. Sadly, my AspeQt machine seems to have died this evening. Was going to post the current code until that happened.
Also, I acquired an MIO and SCSI2SD since the last time I was messing with this and I absolutely love it. Soooooo much faster.
Edited by undeadmechanic, Wed Sep 6, 2017 11:52 PM.
#29 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Sun Sep 10, 2017 6:20 PM
Ok, here is the first version that is 100% functional with 3 btn controllers. It does not have any functions in it for 6 btn though. That's still to come.
This ATR has MyDOS, the Mac/65 Source and binary, and "BTNREAD.BAS".  The BASIC program just displays the button values for testing purposes.
Now I've got to draw up the circuit diagrams to share.
I'm getting there, guys! :)
Attached File  Genesis Controller.atr   90.02KB   14 downloads
Attached File  Genesis Controller Driver Source.txt   1.7KB   19 downloads
#30 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Sun Sep 10, 2017 9:24 PM
Here is the basic diagram for 3 button controllers. The only things in this circuit are a 74LS32 OR gate, 4 diodes, and a male and female DB9 jack.
This will also work with a 6 btn, but it will only be able to read it as a 3 btn.
Feel free to laugh at my diagram, this is my first attempt at drawing out a circuit. I laid this out in a mental image when I built the first one. I've got to draw out the V2 interface, but I'm not done with the driver yet, so no hurry.
Also, please remember that I am a mechanic with LOADS of experience with electronics (and releasing magic smoke), but I am most definitely not an engineer. :( I've just been tinkering with Ataris since I was about 6 years old.
#31 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Tue Sep 12, 2017 7:41 PM
Just had my eureka moment with the oscilloscope! I finally found my second lead for it and was able to monitor the select line and the UP/Z line at the same time to see exactly what was happening.
This is with nothing pressed.
One long low pulse gets the state of the A and Start buttons, followed by two quick low pulses. On the third low pulse, the UP line goes low as the controller acknowledges the "secret knock". Then, the select line is set high. Since nothing is pressed, the UP line goes high the instant the select line goes high.
Now, this is with Z pressed.
Same thing as before, but on the third low pulse, the UP line stays low when the select line goes high. It stays low until the select line is pulled low one last time to return the controller to it's normal state. THAT is the instant the controller reports the state of X/Y/Z/M!
Now to bang it out.
Edited by undeadmechanic, Tue Sep 12, 2017 7:41 PM.
#32 mykgerard OFFLINE
mykgerard
    Space Invader
  • 40 posts
Posted Wed Sep 13, 2017 12:58 AM
now to create hacks for every game that ever used a spacebar for a second button.. lol
#33 undeadmechanic OFFLINE
undeadmechanic
    Star Raider
  • 51 posts
Posted Wed Sep 13, 2017 6:53 AM
Not quite, lol. I have some ideas regarding that.
While I was playing around with it last night, I discovered that I'm still facing the same problem as before... my select pulses perfectly match the output of a real Genesis, but original 6btns refuse to respond. I have a cheap YOBO knockoff that works perfectly for some reason. This requires more investigation.
So close...
