+grips03 Posted December 17, 2016 Share Posted December 17, 2016 Bought O2. Has bad cartridge connector. Any one know of source for them? 2 x 15 / 30 pin 3.96mm pin spacing aka pitch 5.08mm row spacing body is 11mm tall body is 67.30mm long then extends out to 80.81mm including the part for the rivet holes body is 8.63mm wide through-hole pins are 5.3mm long Does O2 do anything without a cartridge inserted, i.e. Splash screen or something? edit: EDAC 307-030-520-208 <---fits perfect Digikey sells them, to be used with short 4-40 screw in lieu of rivet If you still want to use rivet then use EDAC 307-030-520-202 Thanks Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted December 17, 2016 Share Posted December 17, 2016 I think this one might be the right one. Can someone else confirm? Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted December 17, 2016 Share Posted December 17, 2016 Dupe post deleted. Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted December 17, 2016 Share Posted December 17, 2016 Does O2 do anything without a cartridge inserted, i.e. Splash screen or something? No, it requires a cartridge. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 17, 2016 Author Share Posted December 17, 2016 I think this one might be the right one. Can someone else confirm? this won't fit as row spacing is too narrow. Quote Link to comment Share on other sites More sharing options...
metarog Posted December 17, 2016 Share Posted December 17, 2016 What comes up when you power on the O2? Is it a black screen or a grayish one with random characters? If black then you have a bad chip or other component on the board. I have a couple dead boards so I can send you a cart connector or the whole board (with bad chips)for cheap. That is assuming you are sure it is the connector. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 17, 2016 Author Share Posted December 17, 2016 What comes up when you power on the O2? Is it a black screen or a grayish one with random characters? If black then you have a bad chip or other component on the board. I have a couple dead boards so I can send you a cart connector or the whole board (with bad chips)for cheap. That is assuming you are sure it is the connector. gray with random characters. connector on this O2 has 29 pins, not 30 ordering from digikey, if it does not work I'll circle back. Thanks for the offer. Quote Link to comment Share on other sites More sharing options...
metarog Posted December 17, 2016 Share Posted December 17, 2016 Ok great... just wanted to be sure your chips were good. Be careful when removing the pin connector as those rivets on the ends are a bear to get out. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2016 Author Share Posted December 21, 2016 EDAC 307-030-520-208 <---.200 inch / 5.08mm row spacing. Fits perfect in O2. Order from Digikey. Use with short 4-40 screw in lieu of rivet. Towerhobbies sells short 4-40 screws. If you still want to use rivet then use EDAC 307-030-520-202 EDAC 305-030-520-202 <--row spacing is too narrow. Its .140 inch / 3.56mm <---this won't fit 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2016 Author Share Posted December 21, 2016 With cart I get gray screen. Tried two carts, same results. Without cart I get screen with random numbers. I re-seated the two socketed ICs, same results. Power to ICs looks good. No audio. Any ideas? Quote Link to comment Share on other sites More sharing options...
metarog Posted December 21, 2016 Share Posted December 21, 2016 If you haven't already check the continuity of each connector pin to the chips, power and ground. Clean the pins on the game carts as i doubt both are bad but dirty pins can cause solid screens. You can also try to pull and push the cart in the slot when you power on as maybe the connector is not making good contact on the cart. If all that fails I will check and see if I have any good ICs... I know I have an 8244 but I will have to test my 8048s as they may all be bad. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2016 Author Share Posted December 21, 2016 Checked continuity of each connector pin to the chips, power and ground Cleaned game cart, tried pulling & pushing cart in slot, same results When I got this console, cartridge pin R (A8) and 15 (A9) where shorted due to bent pin on the connector. A8 and A9 go to P8048 and to 74LS156N in lower right corner. Perhaps the short caused damage to those two ICs? Quote Link to comment Share on other sites More sharing options...
metarog Posted December 21, 2016 Share Posted December 21, 2016 Most likely fried the 8048 microprocessor chip. I am sending you a pm for some parts that may help. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 27, 2016 Author Share Posted December 27, 2016 It was the 8048. Thanks Metarog. Quote Link to comment Share on other sites More sharing options...
metarog Posted December 27, 2016 Share Posted December 27, 2016 Good to hear... it seemed likely based on all you posted. It seems to be a sensitive chip as I have bought 4 O2s that had bad 8048s. Quote Link to comment Share on other sites More sharing options...
