O2 RGB mod
44 replies to this topic
#1 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 5:41 AM
Has anyone tried this O2 mod?
http://videopac.nl
The RGB output circuit has been copied from the Videopac G7200 console.
It's the circuit that is enclosed in the red line in the schematic below.
The signals of this circuit with the numbered red dots should be connected to the corresponding numbered red dots in the schematic of the Odyssey2 console below. For dots 5 and 6 an inverter should be inserted before connecting them (74LS04).
http://ozyr.com/rene...d/G7200_rgb.jpg
http://ozyr.com/rene...hematic_rgb.jpg
If yes, can you help answer the questions below.
Between IC653 and IC652 there is a vertical black line.  Is this to denote a header to G7200's CRT and hence is not needed for O2 RGB board?
Does IC653 pin 11 connect to IC652 pin 9 and pin 13?
Does IC653 pin 8 connect to IC652 pin 3
What does "&" mean inside of IC653?
What does "1" mean inside IC652?
I assume IC656 is not needed as its not in the red area, does that sound right?
I think these two are related to SCART pin 8/select and pin 16/blanking.  Do you agree?
Are D698 and R749 needed?  If it is needed where does one pick up +2v.  Signal name is Status CVBS.  Perhaps this is optional.
Is R723 needed, this appears to be a resistor connected to +5v, signal name is Status RGB.  Perhaps this is optional.
IC652 is 7407
IC653 is 74LS08
IC656 is 74LS08
#2 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 7:13 AM
Parts list:
R751  100 ohm
R774  180 ohm
R738  470 ohm
R736  560 ohm
R737  560 ohm
R735  560 ohm
R773  680 ohm
R747  1k5  aka 1.5K ohm
R746  1k5
R748  1k5
R733  4k7  aka 4.7K ohm
R772  4k7
C854  10nf  aka 10000pf or .01uf   .1 or 2.54mm spaced
C852  10nf
D696  1N4148  DO-35
D693  1N4148
D694  1N4148
D695  1N4148
D692  1N4148
D697  1N4148
74LS04 to invert points 5 and 6
IC652  7407   DIP14
IC653  74LS08    DIP14
TS681  BC548B  TO-92
DIN - 8 pin female / panel mount  SD-80LS (Digikey)
6 foot DIN 8 male cables assembly 10-00438 (Digikey)
#3 5-11under ONLINE
5-11under
  • 3,396 posts
Posted Fri Dec 23, 2016 9:13 AM
I haven't done the mod, but here's my thoughts:
The vertical black line is the 4 signals, shown as a bus, LGBR - similar as shown in the RAM above it.
Does IC653 pin 11 connect to IC652 pin 9 and pin 13? - Yes
Does IC653 pin 8 connect to IC652 pin 3 - Yes
What does "&" mean inside of IC653? - AND gate? If not, doesn't matter?
What does "1" mean inside IC652? - Buffer? If not, doesn't matter?
I assume IC656 is not needed as its not in the red area, does that sound right? - I think you'll need that if it's not already there.
I think these two are related to SCART pin 8/select and pin 16/blanking.  Do you agree? - Probably agree = don't need.
#4 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 10:04 AM
For the first rev of the pcb I'm going to leave out the bus as I can't figure out why one would mix the RGB colors before sending to 7407 buffer.
Yes, you got it "&" for AND gate, then "1" Buffer, on OR gate they did "> =  (vertically) 1" .  Think this is the first time I saw that on a schematic.  Kind of a cool little short hand.
I was able to confirm these signals are for SCART pin8 and PIN 16, so will leave off as I plan to use with XRGB and PVM.
#5 KylJoy OFFLINE
KylJoy
  • 1,093 posts
  • Intellibeardist
Posted Fri Dec 23, 2016 10:35 AM
That vertical "bus" line is just a representation of all separate signals. It is not showing that they should be mixed together. I am not a fan of showing multiple signals as a single bus as it adds confusion. It confused me when I built this mod for my O2.
#6 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 10:54 AM
That verrical "bus" line is just a representation of all separate signals. It is not showing that they should be mixed together. I am not a fan of showing multiple signals as a single bus as it adds confusion. It confused me when I built this mod for my O2.
edit: I found the diodes under the masking tape.
#7 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 11:10 AM
Inputs to RGB PCB  Going to use 2x5 / 10 pin IDC header
Sync -  612160 pin 8  or  P8244  pin 5
Blank -  612160  pin 9
Red - 612160 pin 10  or   P8244  pin 18
Video / [L]uma - 612160 pin  11
Blue - 612160 pin 12  or  P8244  pin 20
Green - 612160 pin 13  or  P8244  pin 19
Audio - P8244  pin 27
+5v = various spots
GND = various spots
612160 Color Encoder is labeled IC1 on O2 system board
P8244 is labeled IC5 on O2 system board
Outputs from RGB PCB   Going to use 2x5 / 10 pin IDC header connected to DIN 8
Red - DIN pin 5
Green - DIN pin 8
Blue - DIN pin 3
Audio - DIN pin 7
Sync - DIN pin 4
GND - DIN pin 2
#8 grips03 ONLINE
grips03
  • 3,830 posts
Posted Fri Dec 23, 2016 6:36 PM
Would be great if someone could compare to the original schematic to see if I made any errors.
#9 KylJoy OFFLINE
KylJoy
  • 1,093 posts
  • Intellibeardist
Posted Sat Dec 24, 2016 11:06 PM
Yup, they are there!  :)
#10 grips03 ONLINE
grips03
  • 3,830 posts
Posted Mon Dec 26, 2016 9:27 PM
Updated audio section.  Added Status RGB in case its needed.
#11 KylJoy OFFLINE
KylJoy
  • 1,093 posts
  • Intellibeardist
Posted Tue Dec 27, 2016 12:21 AM
This will be great!
#12 SSG OFFLINE
SSG
    Dragonstomper
  • 758 posts
  • Live Long, And Prosper.
Posted Tue Dec 27, 2016 12:26 AM
Interesting. I wouldn't mod mine though. I don't have any issued with simple RF + Coaxial Adapter.
#13 grips03 ONLINE
grips03
  • 3,830 posts
Posted Thu Jan 12, 2017 7:45 PM
RGB board works.  Need to wire to DIN and test audio next.
#14 grips03 ONLINE
grips03
  • 3,830 posts
Posted Sat Jan 14, 2017 8:14 PM
RGB mod pcb works perfect.  Video and audio tested. Uses composite sync.  Very happy with results.
I would install the DIN 8 near the X and not near the spot I picked as it can rub against the system board.
#15 metarog OFFLINE
metarog
    Moonsweeper
  • 280 posts
Posted Sat Jan 14, 2017 9:52 PM
Very nice... the picture quality looks awesome.
#16 grips03 ONLINE
grips03
  • 3,830 posts
Posted Sat Jan 14, 2017 9:56 PM
Thanks.  Pictures are of 52 inch LCD TV
O2--->RGB --->XRGB2--->VGA--->TV
Edited by grips03, Sun Jan 15, 2017 9:50 PM.
#17 grips03 ONLINE
grips03
  • 3,830 posts
Posted Sat Jan 14, 2017 10:19 PM
Updated pin names.   Inputs to RGB PCB  2x5 / 10 pin IDC header
IDC Pin 1 / VCC = +5v
IDC Pin 2 / Composite Sync -  612160 pin 8  or  P8244  pin 5
IDC Pin 3 / Blank -  612160  pin 9
IDC Pin 4 / Red - 612160 pin 10  or   P8244  pin 18
IDC Pin 5 / Luma - 612160 pin  11   - currently labeled VID on rev 2 pcb
IDC Pin 6 / Blue - 612160 pin 12  or  P8244  pin 20
IDC Pin 7 / Green - 612160 pin 13  or  P8244  pin 19
IDC Pin 8 / Audio - P8244  pin 27
IDC Pin 9 / GND
IDC Pin 10 / GND
#18 grips03 ONLINE
grips03
  • 3,830 posts
Posted Sun Feb 5, 2017 5:14 PM
I'm selling bare Odyssey 2 RGB  PCB for $20 +$5 shipping in the US.  This is for pcb only, you will need to add electronics / wiring.  Also works with Videopac G7000
edit:
Send me a PM with your email address to order.  I'll send you paypal.com invoice.
#19 CatPix OFFLINE
CatPix
  • 4,156 posts
Posted Mon Feb 6, 2017 7:54 AM
Status RGB is very needed for SCART TVs.
Only a handful of TV offer the option to select between AV and RGB on the SCART input, so without the RGB status line, the TV will default to composite.
#20 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,651 posts
Posted Mon Feb 6, 2017 1:01 PM
^^ 100% agree with CatPix. At the retro gaming expo I was arranging last weekend, we had several computers outputting RGB through a SCART cable where the RGB select signal was not enabled. Only a few of the CRT TV's we had brought had the option to manually select RGB mode, which meant some careful mixing and matching to get as many systems as possible running.
Edited by carlsson, Mon Feb 6, 2017 1:02 PM.
#21 mutterminder OFFLINE
mutterminder
    Star Raider
  • 99 posts
Posted Sun Feb 12, 2017 6:01 PM
I would be interested in one of the PCB's.  How to we order one?
#22 grips03 ONLINE
grips03
  • 3,830 posts
Posted Mon Feb 13, 2017 7:11 AM
In post #13 I have RGB board installed on the system board.  It fits ok, however it would have been better if I lined up the corners.
#23 grips03 ONLINE
grips03
  • 3,830 posts
Posted Thu Feb 23, 2017 11:35 AM
Updated Parts list to buy from Digikey, Mouser, etc.
All resistors are 1/4watt  axial 1%.
R723 47 ohm  (not usually needed, RGB status only)
R751  100 ohm
R774  180 ohm
R738  470 ohm
Qty 3 R735, R736, R737  560 ohm
R773  680 ohm
Qty 3 R746 (labeled R745 on pcb), R747, R748  1k5  aka 1.5K ohm
Qty 2 R772, R733  4k7  aka 4.7K ohm
Qty 2 C852, C854  10nf  aka 10000pf or .01uf   .1 or 2.54mm spaced
Qty 6  D692-D697  1N4148  DO-35
74LS04      (to invert points 5 and 6)  - labeled IC3 on the RGB PCB.
IC652  7407   DIP14
IC653  74LS08    DIP14
TS681  BC548B  TO-92
Qty 1    H3CCS-1036M (Digikey)  <-- this is 10 position ribbon cable with connector on it
Qty 2    302-S101  (Digikey)     <--this is 4 wall shrouded header that accepts the cable above
Qty 1    SCART plug 21 pin male connector (Console5.com)
#24 save2600 OFFLINE
save2600
  • 15,594 posts
Posted Thu Feb 23, 2017 11:59 AM
RGB out of the O2 - man, you guys are hardcore! What's next, HDMI out of the original Odyssey?    :rolling:
#25 grips03 ONLINE
grips03
  • 3,830 posts
Posted Sun Feb 26, 2017 10:48 PM
Inputs to RGB PCB  2x5 / 10 pin IDC header (updated 2/26/2017)
Best to use IC1/612160 for the inputs, except for audio.
IDC Pin 1 / VCC +5v / 612160 Pin 1
IDC Pin 5 / Luma - 612160 pin  11   - Labeled VID on rev 2 and LUM on rev 2a pcb
IDC Pin 9 / GND / 612160 Pin 15 or 16
IDC Pin 10 / GND  - Normally not connected (spare)
Outputs from RGB PCB towards DIN 8 connector.
IDC Pin 1 = RED
IDC pin 2 = GRN / Green
IDC Pin 3 = BLU / Blue
IDC Pin 4 = SC / Composite Sync
IDC Pin 5 = AUD / Audio
IDC Pin 6 = SR / Status RGB - not used for XRGB
IDC Pin 7 = NC
IDC Pin 8 = NC
IDC Pin 9 = NC
IDC Pin 10 = GND
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
