piders7 Posted December 26, 2016 Share Posted December 26, 2016 How is it compared to the original 2600? Quote Link to comment Share on other sites More sharing options...
high voltage Posted December 26, 2016 Share Posted December 26, 2016 Smaller Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 26, 2016 Share Posted December 26, 2016 Not as good video output. And some units exhibit faint jailbars. But at least the colors can be enhanced by performing the 820ohm resistor mod across a couple of pins on the TIA chip. 1 Quote Link to comment Share on other sites More sharing options...
piders7 Posted December 26, 2016 Author Share Posted December 26, 2016 Is it better or worse than the original 2600? Quote Link to comment Share on other sites More sharing options...
Jumpman1981 Posted December 26, 2016 Share Posted December 26, 2016 (edited) I have one, but haven't fired it up in a while, from what I remember it did the job but had no video at one point, I would recommend it for people new to Atari 2600 or people who don't have a big budget. Edited December 26, 2016 by Jumpman1981 Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted December 26, 2016 Share Posted December 26, 2016 Not as good video output. And some units exhibit faint jailbars. But at least the colors can be enhanced by performing the 820ohm resistor mod across a couple of pins on the TIA chip. Which is weird since, as I stated in my jailbar thread, my junior is the one system that doesn't exhibit jailbars Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 26, 2016 Share Posted December 26, 2016 Which is weird since, as I stated in my jailbar thread, my junior is the one system that doesn't exhibit jailbars Yeah, you've got a good one then. I've had Jr.'s throughout the years that have had 'em. Should add that a nice feature of the Junior, is the fact you can add whatever RF cable you want to easily, since it's detachable. A good shielded true 75ohm cable can make all the difference in squashing interference, etc. Just making a general observation that the original Atari 6-switchers have better video circuitry/output than the cost reduced models that came later. 1 Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted December 26, 2016 Share Posted December 26, 2016 (edited) The 2600jr of similar design like the 7800 and more compact and electronically as robust as the older model. I base this on 2600jr I bought for fifty cents that went thru the "ringer". However, the older model has a much better cart slot, a very solid base for inserting game carts. Atari 2600 Jr Composite Mod - http://www.racketboy.com/forum/viewtopic.php?p=561814#p561814 In closing I have to comment on my beloved Atari 2600 Jr. A very robust machine, it has been thru a lot and still kicking. I won't melt any more solder on her, been thru too much and still working.1. Bought for 50¢ at the Swap Meet. Been dropped, abandoned overnight outside, rained on and covered with mud. Note the pic, there are still traces of dirt on the face buttons.2. Burned thru three mods and multiple disassembles including desoldering components, resoldering the same components, heating up the legs around the Stella Chip and drilling holes in the PCB.Reassembled and held together by only one screw (the other pegs snapped off) the Atari is still alive. If only other products could take this kind of punishment! This Atari has been thru a real Venture. Don't worry baby, you can now rest and function normally again. You still have the prettiest logo around! Edited December 26, 2016 by CRTGAMER Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted December 26, 2016 Share Posted December 26, 2016 Between all my 2600 consoles, the RF signal isn't appreciably worse with the 2600jr., IMO. Especially on an old CRT television.As far as I'm concerned, it's as good as any other version (unless you want to play Space Shuttle and you need the switch panel overlays ). In some ways, maybe even better; the later Atari Corp. carts with the fatter 7800-type shells don't always fit very well in the older 6- or 4-switch systems but fit perfectly fine in the 2600jr. Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted December 26, 2016 Share Posted December 26, 2016 Yeah, you've got a good one then. I've had Jr.'s throughout the years that have had 'em. Have you noticed on 4's and 6's you've owned too? Quote Link to comment Share on other sites More sharing options...
+LS650 Posted December 26, 2016 Share Posted December 26, 2016 I think the JRs are great machines, but I prefer my old 6-switcher because dammit, an Atari just doesn't look right without cheesy faux woodgrain! 1 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 26, 2016 Share Posted December 26, 2016 Have you noticed on 4's and 6's you've owned too? For a while, there were Sunnyvale 4-switchers (have one now)... forget the mobo revision, but has different top shell difficulty switch verbiage and yes, I'd say those are nicer quality than the Taiwan 4-switches. Don't currently recall seeing jailbars on the Sunnyvale models, think I've just observed that on the Taiwanese stuff. But obviously some Taiwanese made systems don't exhibit the jailbars, so who knows... with all the bastardized systems that were thrown together throughout the years, different mobo revisions, parts sourced that may be more susceptible to variances in tolerance, etc. appears anything is possible with Atari that way. It's why when you get a 'good' system, you might just want to hang on to it. 1 Quote Link to comment Share on other sites More sharing options...
rednakes1 Posted December 26, 2016 Share Posted December 26, 2016 Not as good video output. And some units exhibit faint jailbars. But at least the colors can be enhanced by performing the 820ohm resistor mod across a couple of pins on the TIA chip. This resistor mod is only for the Rev 14 and lower motherboards for the 4-switch woodgrain atari 2600s. Not the Jr, which has superior colour to the 4-switch. I haven't been able to compare to a 6-switcher however. 1 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 26, 2016 Share Posted December 26, 2016 This resistor mod is only for the Rev 14 and lower motherboards for the 4-switch woodgrain atari 2600s. Not the Jr, which has superior colour to the 4-switch. I haven't been able to compare to a 6-switcher however. Hmm... must be getting my systems cornfused then when it comes to that particular mod. Thanks for the correction. Can definitely confirm that all the stock Juniors I've had, not looking as good (vibrant color wise) as a stock Sunnyvale 6-switcher or my Sunnyvale 4-switcher. Junior fares much better than a 7800 that way though! And on overall clarity. At least I've been able to perform this resistor mod to my 7800's too - which greatly improves the colors of 2600 games. Better than a Junior, but not as vibrant or accurate as the old Sunnyvale models. Even after using the color bar generator and trying to dial them in. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted December 26, 2016 Share Posted December 26, 2016 My JR is crystal clear on a 4k tv also. Quote Link to comment Share on other sites More sharing options...
Dreamcast Gamer Posted December 26, 2016 Share Posted December 26, 2016 I suggest if you're looking for a cheap 2600, get the 1980 4 switch model. That's what I bought recently, and it works very well. It's seems to be the cheapest of the normal 2600s. Quote Link to comment Share on other sites More sharing options...
Dreamcast Gamer Posted December 26, 2016 Share Posted December 26, 2016 Not as good video output. And some units exhibit faint jailbars. But at least the colors can be enhanced by performing the 820ohm resistor mod across a couple of pins on the TIA chip. What exactly are jailbars? Is that the black bar I get on the left side of my screen when I'm using my 4 switch 2600? Quote Link to comment Share on other sites More sharing options...
Eltigro Posted January 3, 2017 Share Posted January 3, 2017 What exactly are jailbars? Is that the black bar I get on the left side of my screen when I'm using my 4 switch 2600? They are faint lines that can be seen running vertically on the screen. I see them on my NES top loader. You can see them in this screenshot (not my pic). 1 Quote Link to comment Share on other sites More sharing options...
Dreamcast Gamer Posted January 3, 2017 Share Posted January 3, 2017 They are faint lines that can be seen running vertically on the screen. I see them on my NES top loader. You can see them in this screenshot (not my pic). Does this mean my console is defective and/or dying? I get these but they don't bother me. It's better than the colored static bar on my last 2600. Quote Link to comment Share on other sites More sharing options...
Eltigro Posted January 3, 2017 Share Posted January 3, 2017 Does this mean my console is defective and/or dying? I get these but they don't bother me. It's better than the colored static bar on my last 2600. Nah, I think they are just from interference or poor rf modulation or something along those lines. Never looked that much into it and didn't really notice them until someone told me about them. It's a common thing with NES top loader systems. 1 Quote Link to comment Share on other sites More sharing options...
Dreamcast Gamer Posted January 3, 2017 Share Posted January 3, 2017 Nah, I think they are just from interference or poor rf modulation or something along those lines. Never looked that much into it and didn't really notice them until someone told me about them. It's a common thing with NES top loader systems. Oh good. I think the guy at the store I got my 2600 from would be pretty annoyed if I came back again to exchange something. I went in twice to exchange Joysticks, and once to exchange the console. The paddles are quite good for 2600 paddles. Quote Link to comment Share on other sites More sharing options...
