Lynx 1 screw problem. Need help.
14 replies to this topic
#1 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Mon Jan 9, 2017 7:08 PM
for some strange reason i just took my lynx 1 apart again and now i cant get the back cover on the cart door side to screw back in all the way....im really struggling with this. 😕
I didn't have an issue the first time u took the lynx 1 apart...I Dont know what went wrong..
#2 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Mon Jan 9, 2017 7:11 PM
When back cover is off, screw screws in tight just fine..
#3 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Mon Jan 9, 2017 7:12 PM
When I put cover in and drop in screw to screw in, it won't screw in, and screw drops right out.
I Dont get it.
It didn't do this last time I took it apart.
Doesn't make sense.
Does anyonw know wgat the problem is?
Edited by Stun Runner 87, Mon Jan 9, 2017 7:28 PM.
#4 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Mon Jan 9, 2017 7:32 PM
And again, when I take back cover off, the screw reaches the hole and tighens in properly without a problem.
I Dont get it. Does anyone know what I'm doing wrong?
#5 Stephen Moss OFFLINE
Stephen Moss
  • 1,009 posts
Posted Tue Jan 10, 2017 3:36 AM
I have never taken a Lynx apart but two possibilities immediately sprint to mind...
1) The cover is not correctly located leaving a gap which the screw is to short to bridge
2) Some of the screws are slightly longer than others and you have used a longer one where you should not have leaving you with one that is to short for where you are trying to use it.
#6 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Tue Jan 10, 2017 4:28 AM
U might be right.
Its a Mcwill mod, so it had to be taken apart before.
There's 4 Screws.
For the cart door side(side with the d pad) the 2 shorter screws go in.
On the button side, the 2 longer screws go in, so I know I put them in right spots.
The last time I opened the case was over a month ago. I screwed them in real tight when I put it back on, Maybe too tight.
I opened it again yesterday to clean dust off of Mcwill screen surface. When I put it back together yesterday, thats when I noticed I couldnt get the screws to screw in. They Dont stay in.
Could the reason be because of the last time I opened it up a month ago when I might of screwed the screws way too tight?
And if so, can it be fixed.
Or does it need a whole new back cover?
Edited by Stun Runner 87, Tue Jan 10, 2017 4:32 AM.
#7 cowdog360 OFFLINE
cowdog360
    Moonsweeper
  • 280 posts
Posted Tue Jan 10, 2017 12:34 PM
Hey there, this is really common on the Lynx I.  The plastic in the screw holes is very brittle and breaks off.  I've had this happen on two Lynx I's.  I've tried repairs with plastic epoxy/filler, no luck.  In the end I used screws that were a tiny bit longer that could bit into the plastic at the end of the mounting holes, being careful to not have too long of screws to go through the case. At this point, anyone doing mods on the Lynx I should really consider it an open it once, get it done and leave it alone thing (I wouldn't open it for cleanings regularly).
#8 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Tue Jan 10, 2017 4:39 PM
Thank you. Its funny you said that, because I can see am indentation on the front shellcase where screws went almost completely through, most likely from previous owner.
I think Best Electronics sells replacement shells, because it most likely will need it now.
Thanks for the reply my friend.
I will contact you in the near future in regards to my other Lynx 2 when im ready for upgrades.
You did an excellent job when you did my Mcwill for my Lynx 2.
It works great, and you were right. Once someone plays the Mcwill, they will never go back to the original led screen 😀. Pure Awsomeness.👍👍👍👍👍👍👍
#9 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Wed Jan 11, 2017 1:42 PM
I still Dont understand why a slightly longer screw wouldnt help reach the bottom of the screw hole that isn't worn out.
The reason I say that is because when the shell cover is off, the screws reach fine. Its when I put cover shell back on that the screws Dont reach plastic that isn't worn.
The last resort I can think of is Krazy Glue or cement..LoL,
There isnsomthing that Ace Hardware sells called "Lock Tight" that's made for screws when the threads Dont grip hole. but that would mean shell will be permanately closed.
Or is that a horrible idea? 🤗
Edited by Stun Runner 87, Wed Jan 11, 2017 2:26 PM.
#10 BadPricey OFFLINE
BadPricey
    Moonsweeper
  • 387 posts
Posted Wed Jan 11, 2017 4:06 PM
Don't glue it because you may want to reopen it in the future. Who knows what will break if you go down that path. Try longer screws or a new case.
#11 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Wed Jan 11, 2017 4:09 PM
I will probably just order a new case backing from Best Electronics if they have any in stock.
My glue idea was pretty ridiculous. LoL
#12 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Wed Jan 11, 2017 4:11 PM
I tried to find longer screws at Menards and radio shack but they didn't have the size I needed. I was looking for some just a tad bit longer than originals.
Edited by Stun Runner 87, Wed Jan 11, 2017 4:28 PM.
#13 BadPricey OFFLINE
BadPricey
    Moonsweeper
  • 387 posts
Posted Wed Jan 11, 2017 4:15 PM
I don't think you need the back part, you need the part your screwing into, yes?
#14 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Wed Jan 11, 2017 4:29 PM
Possibly.
The plastic part doesn't look damaged, although it probably is just worn in inside of screw holes where the screw grips.
Edited by Stun Runner 87, Wed Jan 11, 2017 4:31 PM.
#15 Stun Runner 87 OFFLINE
Stun Runner 87
  • 1,222 posts
Posted Thu Jan 12, 2017 1:29 AM
I found solution.
I went to ace hardware earlier and bought 2 screws a half inch longer than originals, and they griped perfectly.
Simple solution that worked.
Case is securely closed now.
