The FinalGROM 99
568 replies to this topic
#376 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Sun Jul 30, 2017 7:08 AM
Good point. :)   What I meant is that my patch file "version_1_1.avr" will update the FG99 uC, but you need to rename it to UPDATE.AVR first.
I'll reword the section.
#377 arcadeshopper OFFLINE
arcadeshopper
  • 3,392 posts
Posted Mon Jul 31, 2017 1:04 AM
So how can I tell the update worked?
Greg
Sent from my LG-H830 using Tapatalk
#378 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,495 posts
  • Distracted at the Keyboard
Posted Mon Jul 31, 2017 4:42 AM
Greg
You won't see the system volume information in the menu of the final grom or you can put a folder on the final grom and set it to hidden in windows then check if it shows up in the FG menu.
#379 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Mon Jul 31, 2017 5:36 AM
Also, there's a little dot behind the v1.  Yeah, it's too subtle.  :ponder:
#380 Barry Nelson OFFLINE
Barry Nelson
    Space Invader
  • 25 posts
Posted Tue Aug 1, 2017 5:01 AM
The cart "Red Baron" does not run on a FinalGROM 99. Pretty much everything else has worked. Red Baron uses this cartridge type:
pagedcru
Cartridges with one ROM of 8K to 64K rom_socket
Uses CRU banking (DataBioTics)
But I can't seem to get it to work in the FinalGROM 99. I don't think the FinalGROM supports the pagedcru cartridge paging method. The attached
rpm  file works fine in MESS/MAME.
#381 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Tue Aug 1, 2017 5:48 AM
No, you're exactly right.  The FG99 only supports bank switching that writes to ROM cart space >6xxx/>7xxx.
A lot of CRU switching carts have been converted to this, but Red Baron probably hasn't been yet.
#382 x24b OFFLINE
x24b
    Star Raider
  • 90 posts
Posted Tue Aug 1, 2017 1:58 PM
Is there an Assembly Language source or Extended Basic source dump for Red Baron? I would LOVE to study it.
#383 Ksarul OFFLINE
Ksarul
  • 4,670 posts
Posted Wed Aug 2, 2017 2:57 PM
Red Baron (also known as Spad XIII) was written in Assembly--and I have never seen a copy of the source code for it.
Edited by Ksarul, Wed Aug 2, 2017 2:58 PM.
#384 x24b OFFLINE
x24b
    Star Raider
  • 90 posts
Posted Wed Aug 2, 2017 3:17 PM
Years ago I tried to disassemble SpadXIII and found it had copy protection.
I never was able to open the file to see the disassembled program.
With the FinalGROM 99 we will be able to run larger and more involved programs, and coupled with the F18A video capabilities we should be able to create actual simulator type programs.
The programs created may be simple wire-frame affairs, but can be an order of magnitude more sophisticated than SpadXIII.
Flight simulators are not trivial, but even with the limitations of the original hardware SpadXIII was a wonderful product.
It had most of what a flight simulator needs (stripped to the bare minimum).
I'd LOVE to see an updated, sophisticated SpadXIII, or even Flight Simulator equivalent to the green screen wire-frame Apple version.
Do we know the Author? Is he/she still around and coding? Would they release the source so some of us could take a whack at it?
#385 PeteE OFFLINE
PeteE
    Chopper Commander
  • 147 posts
Posted Wed Aug 2, 2017 6:09 PM
I converted RedBaron to the bank switching method that works on FinalGrom99.  You can get the file redbaron8.bin from this post.
#386 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,241 posts
Posted Wed Aug 2, 2017 6:17 PM
I've updated the FR99/FG99 thread and this made feature of the week PeteE!
Edited by --- Ω ---, Wed Aug 2, 2017 6:38 PM.
#387 chue OFFLINE
chue
    Chopper Commander
  • 237 posts
Posted Thu Aug 3, 2017 12:01 PM
I put too much time into this, and the results are not as good as I would have liked.  Here's my case...
The coloring is FinalGROM RedTM to match the FinalGROM itself.  In total I used 2 cases, ruining one.
Disclaimer: Thanks to the magic of photography (strategic angling of subject, jpeg compression, depth of field), the imperfections in the case are not seen in the photos.
#388 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Thu Aug 3, 2017 12:06 PM
I updated version patch 1.1 so that the FinalGROM 99 is now showing a proper V1.1 in the menu.  It also ups the SD access delay to 5 ms.  If your SD card still doesn't work after the patch, I recommend using a different card (4-8 GB seem ideal).
#389 vectrexroli OFFLINE
vectrexroli
    Moonsweeper
  • 476 posts
Posted Fri Aug 4, 2017 11:38 AM
Got my 3D printed case for the FinalGROM99. It fits in perfectly, the only modification I did is that I soldered in a new red LED and let that one shine through Ralph´s original label.
#390 eightbit OFFLINE
eightbit
  • 3,284 posts
Posted Sun Aug 6, 2017 12:56 AM
Ralph and c0d3m4st4 both have made my late summer a really enjoyable one ;) I am looking forward to Halloween (my favorite time of the year) and figured I'd go with that theme for the case for this incredible board. Did the same for Jedimatt's 32KB module. I am super happy to say the least ;)
#391 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,241 posts
Posted Tue Aug 8, 2017 8:07 PM
I'm really lovin' this new cartridge shell by c0d3m4st4. :thumbsup:
I wanted to make a video of it today, but spent hours at the emergency room with a family member so I did not get the chance.  :_(
Anyway, I like the way the SD card is TOTALLY FLUSH with the front of the cartridge when fully inserted.  That is so nice!  Unfortunately I buggered up the label a little when cutting out the notch for the SD card... dammit! :mad:   Soooo, I'll still get the video made, but it'll probably next week as time allows.
BTW - c0d3m4st4, if you are reading this, this is your best work yet.  I also like the design of your buttons.  Excellent!  I'm going to design a new label too (as time allows).  I'm figuring it'll have a built-in window for the LED showing "activity".
#392 c0d3m4st4 OFFLINE
c0d3m4st4
    Space Invader
  • 42 posts
Posted Wed Aug 9, 2017 2:33 AM
Glad you like it :)
Hopefully that was nothing serious and he/she is fully recovered!
Cheers!
#393 suberbanator OFFLINE
suberbanator
    Combat Commando
  • 6 posts
Posted Sun Aug 20, 2017 10:28 AM
i know finalgrom bins cannot be used on flashrom but can flashrom bins be used on finalgrom
it may have already been posted and i missed it thanx
#394 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Sun Aug 20, 2017 10:43 AM
Yes, here.   :)
#395 suberbanator OFFLINE
suberbanator
    Combat Commando
  • 6 posts
Posted Sun Aug 20, 2017 10:53 AM
Theoretically, yes.
The FlashROM 99 didn't have any filename restrictions, though, so some FlashROM 99 programs may be missing (short filename ending in D) or not working (short filename ending in G) when used in the FinalGROM 99.  The details are in the "Filenames" section of the homepage, which sounds more complicated that it is.
The other way around will list GROM images, but the FlashROM 99 will think they're ROM images.
To avoid confusion, I'd would not mix them personally, but it works if you know what you're doing.
thanks ralph
#396 Casey OFFLINE
Casey
    Moonsweeper
  • 256 posts
Posted Sun Sep 17, 2017 1:25 PM
I'm late to the party, but I finally got my FinalGROM 99 put together in a cartridge over the weekend, and I must say, what an amazing and useful piece of technology.  My friend who did the actual assembly in a beige cartridge was very impressed (and he's usually not that impressed with anything for my old TI computer).  Thanks Ralph for a wonderful device!
#397 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Mon Sep 18, 2017 10:23 AM
Thanks for your kind words, Casey!
#398 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,495 posts
Posted Fri Oct 13, 2017 5:39 PM
Finally.  This is it:
You may notice a few last-minute changes to the final prototype.  The FinalGROM 99 now uses plain SD sockets, although you can still fit an Arduino shield if you want.  Also, a second reset button resets the TI 99.  This is useful for programs that don't react to FCTN-=.  Finally, the 5V SRAM was replaced by its 3.3V couterpart, which is cheaper and easier to get.
As already mentioned, with only a few modifications, the FinalGROM 99 fits a standard cart shell.
You can also combine both reset buttons by getting a DPST switch for your case.
I updated the homepage to include the additional hardware features and some software changes I did (mostly, advanced modes, help viewer texts, and image dumping).  The latter allows you to write the contents of the image in SRAM back to SD cart.  This is useful for saving high scores, progress, or preferences.
You'll also find ordering information on the homepage.  Please allow a few days for me to reply, especially in the beginning.  While the boards are mostly complete, I need to add a few components, and, more significantly, program and test the final carts.
Thanks go to Jim (brain) for nudging me to use real SD sockets and introducing me to a cheap model, and to Eric (speccery) for analyzing an electrical program on the first prototype!
EDIT: added links
Can't find the final grom label, I'm in Chicago with a friend who offered to print vinyl label sheet full of them. Need ASAP. Help! :) The label that looks like TI printed it, I think Ralph's original.
#399 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,241 posts
Posted Fri Oct 13, 2017 5:56 PM
Ralph is currently selling it, so I believe out of courtesy it's not been duplicated.  I'm unaware of the file floating around.
#400 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,495 posts
Posted Fri Oct 13, 2017 6:12 PM
ooooooooh. Didn't know the labels were for sale too. my bad.,,, no worries.
