Can Pokey make sound waveforms like in C64 Driller and Darkside music ?
pokey sound sid c64
19 replies to this topic
#1 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Thu Jan 12, 2017 4:51 AM
How hard is to produce sound waveforms like in C64's sid music from games Driller and Dark side ?
I'm interested in making a game that would use such spacy, trippy dragged sounds and would like to know how hard it would be ?
Driller:
Dark side:
Mostly I want those sounds at beginning that look like square waveform.
#2 Irgendwer OFFLINE
Irgendwer
  • 1,435 posts
Posted Thu Jan 12, 2017 5:15 AM
Not hard. Just use Pokey's 16 bit mode which occupies two sound channels for one tone. Related to the "Driller" sound that means the third wave isn't possible any more while playing two 16bit ones...
Pokey example for this sound:
http://asma.atari.or...ch.php?play=376
#3 pirx OFFLINE
pirx
    Moonsweeper
  • 447 posts
Posted Thu Jan 12, 2017 5:26 AM
quite close approximation is also available via software synthesis (look up SID player). Might be okayish for game startup screen.
#4 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Thu Jan 12, 2017 6:07 AM
Nice example ! Those beginning sounds are exactly what I was thinking of.
I would put these sounds as background music. I do need explosions and laser sounds inside game so will have to try doing something that combines that.
Yeah, I thought about going that route, but am afraid I won't have cpu cycles for that... Game will be pretty cpu intensive (lots of drawing on screen).
Found some examples from Emkay here on forum (http://atariage.com/...okey/?p=1813218)
It has nice "noise" channel but I don't like starting tone that much... One in that Ultrazocker sap file is better.
Where can I find info on that "16 bit" pokey mode ?
#5 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Thu Jan 12, 2017 8:12 AM
1. filter, not 16 bit.
2. there is a huge difference in the original driller sound and your link.
Edited by emkay, Thu Jan 12, 2017 8:12 AM.
#6 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Thu Jan 12, 2017 8:19 AM
That's why it's named "RMT final" . RMT doesn't use the 16 bit resolution correctly. So the bass was some "approximation". I should try an RMT Patch 8 version.
Don't forget this one:
it shows, there is much more possible ;)
#7 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Thu Jan 12, 2017 8:24 AM
And, not to forget this one...
#8 miker OFFLINE
miker
  • 1,895 posts
  • Stay Atari!
Posted Thu Jan 12, 2017 3:48 PM
Just a small demo.
No patches needed. :)
#9 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Thu Jan 12, 2017 5:02 PM
Awesome Miker :)
Looks like some channels are free ?
Hmmm...: Can you please try adding that "shhhhhhhh...." sound like a wind that starts at 19 sec into this video ?
https://youtu.be/UuvhB3hFMEM?t=19
Please.... :)
#10 miker OFFLINE
miker
  • 1,895 posts
  • Stay Atari!
Posted Thu Jan 12, 2017 11:42 PM
Ok, made really fast...
Doesn't be as pretty as original, though (versions with and without 1,79 clock).
  • Attached File  shhh.zip   718bytes   127 downloads
Edited by miker, Thu Jan 12, 2017 11:42 PM.
#11 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Fri Jan 13, 2017 2:43 AM
Thanks Miker!
Good enough for me to get the feel on how it can sound. Will try some custom Pokey playing routines to see what I can pull of with code generated sounds.
#12 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Fri Jan 13, 2017 2:56 PM
I wonder, what you expect there...
#13 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Fri Jan 13, 2017 3:50 PM
Nice one Emkay !
Could you share that RMT file ?
#14 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Fri Jan 13, 2017 10:47 PM
Nice one Emkay !
Just a quick edit in Patch 8. But, also playable in standard.
Could be interesting to add other voices.
To have the full tune with POKEY's abilities could be even nicer :)
#15 popmilo OFFLINE
popmilo
  • 1,569 posts
Posted Sat Jan 14, 2017 2:12 PM
Nice! Thanks!
#16 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Sat Jan 14, 2017 6:13 PM
Inspired by this thread, I tried something different.
You know, it is not possible to use the 15kHz and 64kHz at the same time. So, the try is to use "16 bit" modulations, here and there ;)
Unpatched RMT btw.
#17 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Tue Jan 17, 2017 3:23 PM
Can you imagine that very much "POKEY tunes" could do those SID tunes, using heavy bass sounds?
Using 16 Bit+Filter is possible with POKEY, but RMT makes it a horror to use. A 16 bit notation table could solve a lot of problems. Without that , it would be needed to create "100"s of different instruments for one instrument, to play a clean tune.
Edited by emkay, Tue Jan 17, 2017 3:24 PM.
#18 emkay ONLINE
emkay
  • 9,669 posts
  • What's up?
Posted Tue Jan 17, 2017 3:43 PM
Another try with RMT's possibilities. Showing different 16 bit modulations, but for my taste to dark an heavy sounding basses...
any opinions?
#19 Stephen OFFLINE
Stephen
  • 7,461 posts
  • A8 Gear Head
Posted Tue Jan 17, 2017 6:29 PM
any opinions?
Definitely some interesting sounds there.  I like the tune starting from 6:45 through 7:10.  Makes me want to hear it on my full home theater to see how low the bass really goes.
#20 marok OFFLINE
marok
    Combat Commando
  • 5 posts
Posted Wed Jan 18, 2017 10:53 AM
For me this emkay's music is incredible excellent!
Also tagged with one or more of these keywords: pokey, sound, sid, c64
