Personal 4 port cartridge expansion project
4 port cartridge Expansion
105 replies to this topic
#1 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
  • Distracted at the Keyboard
Posted Sun Jan 15, 2017 5:58 PM
OK, I think it's time to start this topic. I almost have everything I need I think. First I want to copy and paste some important information from another thread () just to consolidate it here:
Tursi, on 05 Jan 2017 - 04:21 AM, said:snapback.png
ROM Select and GROM Select should be enough. The problem with the Navarone Widget is it did NOT cut GROM Select. For some reason for the GROMs it cut the -5v, which the UberGROM doesn't use.
Sinphaltimus, on 09 Jan 2017 - 8:28 PM, said:snapback.png
ROM Select? Maybe +5 and the GROM Select?
Tursi - "GS* (GROM Select) and ROMG* (ROM Gate).  :)
Switching power isn't recommended, although you would need it if you get too many carts on there. (I have no idea how many too many is). The problem is that when you activate power to a chip, it likely won't be a clean transition and can cause the chip to malfunction."
   Name    I/O  Use
1   RESET   <    Resets the system (active high)
2   GND          Signal ground
3   D7      <>   Data bus, bit 7 (least significant)
4   CRUCLK* >    Inversion of TMS9900 CRUCLOCK pin
5   D6      <>
6   CRUIN   <    CRU input to TMS9900
7   D5      <>
8   A15     >    Address bus, bit 15 / also CRU output bit
9   D4      <>
10  A13     >
11  D3      <>
12  A12     >
13  D2      <>
14  A11     >
15  D1      <>
16  A10     >
17  D0      <>   Data bus, bit 0 (most significant)
18  A9      >
19  VCC          +5 Volts power supply
20  A8      >
21  GS*     >    Grom select. Active low is addr in >9800-9FFF
22  A7      >
23  A14     >    Address bus, bit 14. Select mode: low=data / high=addr
24  A3      >
25  DBIN    >    Active high = read memory
26  A6      >
27  GRC     >    GROM clock: color burst of VDP 9918A
28  A5      >
29  VDD          -5 Volts power supply
30  A4      >
31  GR      <    Active high = GROM ready
32  WE*     >    Active low = write enable (derived from TMS9900 WE*)
33  VSS
34  ROMG*   >    Active low if addr in >6000-7FFF
35  GND
36  GND
Here's the idea I'm going with.
I'm going to mount an edge connector to a large board along with 4 cartridge ports. With 4 carts installed, you should just barely be able to slide a piece of paper between carts.
Lined up along one side will be an AV switch box with 4 buttons. The input AV output jacks will be shorted to complete the circuit. Basically, connect RCA plugs with their individual wires soldered together. This way I can splice the GS* (GROM Select) to left audio in and the ROMG* (ROM Gate) to right audio in per 4 inputs. Since I still have the ability to cut more lines (the video jack and the S-Video jack) per button, is there another cut you'd recommend? Like maybe the + &/or -5v? Or no?
The finished project will work by simply pressing the 1 button for cart 1 or 2 for cart 2 etc...
I'm not at all concerned with the ability to switch carts with the console powered on although it would be nice. That's why I'm wondering about cutting additional lines. Shutting the console off to switch is fine however. I'm really just looking to cut down the wear and tear on the cart port. The 4 cart expander will be connected to the console via cart expander cable. It's a personal project to solve a personal need at low cost. I will document it all with photos and text as I make progress sharing the experience and hopefully have a fully functional 4 port cart expander by the end. Remaining hopeful I will be able to start this coming weekend.
This is the exact switch box I plan to use.
Edited by Sinphaltimus, Thu Jan 19, 2017 4:52 AM.
#2 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Wed Jan 18, 2017 5:56 PM
Quick update. After some consultation, it appears I'll need to install some pull up resistors. (Thanks Tursi).
I've also concluded that it will require the console be turned off during the cartridge switch.
Next I have to order another GROM extension cable I think. I've been holding off. thinking I could figure something out to save on having to buy another but with my current setup, the existing one is too short. And I'm considering another option as opposed to 2 extension cables end to end.
Just creating an extension edge card straight through then length of the coffee warmer. But realistically, I think I'm going to dremel a hole in the bottom of the console and feed the extension down through that instead of up through the cartridge port.
This is stuff I don't figure out until I actually begin making it all. Sure there's some preplanning for the electronic stuff, but not so much for the cutting and gluing and things of that sort.
I hope to put together a quick mock up tomorrow just to help me visualize it in a few form factors.
#3 sjt OFFLINE
sjt
    Star Raider
  • 58 posts
Posted Wed Jan 18, 2017 10:09 PM
If I'm understanding what you are doing.....you want to make a push button widget?
The push button part of your project is a bit of an over kill.
With  support circuitry it would be possible to use a single push sw to select different cartridges.
Why not just make a board with daisy chained connectors and use a conventional slide switch along with a reset button.
You then switch cartridges and do a reset.... this works, Naverone sold a lot of them.
I think there is enough room for 4 cartridges.  Not with advanced switching (4 position slide sw?)
#4 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Thu Jan 19, 2017 4:39 AM
Because I have no idea what I'm doing and the more crazy it looks aesthetically speaking the more I'll love it.
Honestly, it seems like a relatively easy project compared to many other things and with the switch box already built, connecting lines and resistors "should" be a breeze. I'm going to work it ourr on paper this weekend. I really like the idea of the push buttons.
#5 sjt OFFLINE
sjt
    Star Raider
  • 58 posts
Posted Thu Jan 19, 2017 11:58 AM
Enjoy!,  have fun.
To help you, here are the details on how Navarone made the widget.
They used a 3 position double contact switch.
They switched the following lines:
One side of the switch, connected Rom Low to each of the different sockets 1-3
The other side of the switch, connected -5v to sockets 1-3 at the same time.
All pin 19 (Vdd +5) were connected to each socket through a 50K resistor.
All remaining pins are daisy chained to each socket.
The reset button  connects GND to Vdd -5
The board I'm attaching a photo of was made sometime around 1984 or later in Hong Kong.
Parts list.
3- Leader EG-2540-36 Sockets
3- 50K resistors
1- Plastic button with carbonized insert (reset button)
1- Plastic slide sw with 2 seperate contacts
Misc: top and bottom covers, pcb, screws
That's all there is to it.
Edited by sjt, Thu Jan 19, 2017 11:58 AM.
#6 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Thu Jan 19, 2017 1:23 PM
Enjoy!,  have fun.
Parts list.
3- 50K resistors
Wow! Great resource! Thanks for sharing all of this!
#7 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Fri Jan 20, 2017 4:05 PM
In a perfect world it will look as close to this as possible. I'm imperfect so we'll see how it goes.
Waiting on some more parts. I also have to go through my parts list and see if I have a 50k resistor.
What's the tolerance there? Would 47k suffice?
Attached File  20170120_145329.jpg   536.23KB   6 downloads
#8 Ksarul OFFLINE
Ksarul
  • 5,148 posts
Posted Fri Jan 20, 2017 4:23 PM
Most resistors have a 10% tolerance factor, so 47K would probably work fine. The primary purpose of the resistor is to smooth out voltage spikes as you switch out the slots, so anything close will probably work great. . .
#9 sjt OFFLINE
sjt
    Star Raider
  • 58 posts
Posted Fri Jan 20, 2017 11:48 PM
As Ksarul says ...just use 47K or resistors in series or parallel to get close.....
#10 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Sat Jan 21, 2017 6:03 PM
So I did some more planning and practical examination and such today. I don't want to start the project without a schematic and I still have to desolder one of the GROM port adaptors to get the edge connector I need for the GROM port extension cable.
All the photos are here,
https://m.facebook.c...533&ref=m_notif
I'll share a few below...
Checking out minimum spacing.
16178976_10207984235475704_3927579416576
With carts inserted.
16179811_10207984293597157_3703193257578
All this nonsense I don't need.
16179131_10207984304117420_3622537460477
So much more nonsense I don't need.
16143491_10207984307877514_2034007613400
Now this I need!
16112971_10207985763673908_5617485446605
Mock layout of how I hope things will go with a new board awaiting the dremel.
16112551_10207985840715834_1130491319364
Edited by Sinphaltimus, Sun Jan 22, 2017 7:26 AM.
  • RXB likes this
#11 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Sun Jan 22, 2017 5:48 PM
It hurt to do it but it had to be done. THANKS TURSI!
16196036_10207994858181265_156898645466516265444_10207994858581275_3815085743854
My final layout plans. Next, fit everything in to place then figure out wiring. I plan to use the board as much as possible but I imagine the board is strictly for holding everything in place and the rest will be all wired. I may use the board strictly for the cut lines and resistors. (ROM&GROM lines). And wire everything else.
Not sure yet. I have to see what it looks like on paper first.
16143344_10207994976664227_3756644401575
#12 Tursi OFFLINE
Tursi
  • 5,498 posts
  • HarmlessLion
Posted Mon Jan 23, 2017 12:37 AM
Don't even worry about it - there are so many of those floating around ;)
#13 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Mon Jan 23, 2017 4:37 AM
It was painful. But I'm guessing there are more of these remaining than there are working consoles, that's what I kept telling myself. :)
#14 Tursi OFFLINE
Tursi
  • 5,498 posts
  • HarmlessLion
Posted Mon Jan 23, 2017 11:06 AM
Well, I have hundreds. ;)
Attached File  CartPorts.jpg   82.75KB   4 downloads
And I know I'm not the only one. ;)
#15 sparkdrummer OFFLINE
sparkdrummer
  • 1,047 posts
  • Status? I don't need no stinkin' status!
Posted Mon Jan 23, 2017 11:23 AM
Ive got close to that many, with a TI-99/4A wrapped around them.
#16 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,639 posts
Posted Mon Jan 23, 2017 11:26 AM
Hey Tursi, I don't have any cartridge port spares!!  You hoarder!  Want to sell me a couple at a fair price?
#17 Ksarul OFFLINE
Ksarul
  • 5,148 posts
Posted Mon Jan 23, 2017 11:28 AM
I've got about a dozen loose ones, and a whole lot more with consoles wrapped around them. If you really want to make more than one of these, I can make you a small board design that you can use to make as many of them as you want. . .
#18 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Mon Jan 23, 2017 11:30 AM
Tursi was very generous, I can reciprocate and send you some of the extras he sent me. Just pm me.
Edited by Sinphaltimus, Mon Jan 23, 2017 2:09 PM.
#19 Tursi OFFLINE
Tursi
  • 5,498 posts
  • HarmlessLion
Posted Mon Jan 23, 2017 4:49 PM
oh no you don't! This is MY hoard we're trying to clear out. ;)
Send me your address Omega. ;)
#20 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,639 posts
Posted Mon Jan 23, 2017 5:03 PM
PM Sent!
#21 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Tue Jan 24, 2017 5:16 PM
So I cut the board tonight. Going to drill the screw holes this weekend AND I'm gonna have to drill connections for some part too since the holes are too small for the GROM ports and not at all aligned for the Switches. But that's OK, the baord is realy going to be used to just hold everything in place. Just about all the connections will be wired.
16177948_10208017513067623_1795269098109
16251581_10208017520267803_7532670528608
I'll also need to file down the cuts to fine tune them.
Edited by Sinphaltimus, Tue Jan 24, 2017 5:17 PM.
#22 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Wed Jan 25, 2017 5:56 AM
So I got to drill some holes this morning. I hope to get the grom port holes drilled out tomorrow morning...
16251653_10208022461591333_5493090739858
16179513_10208022463631384_2388192522981
16299613_10208022469751537_7397761231886
#23 Meddler OFFLINE
Meddler
    Star Raider
  • 64 posts
Posted Wed Jan 25, 2017 8:50 AM
As you can imagine the Great Doctor has covered this (though, in his way, to expand) and tells us exactly what Naverone did in the first few paragraphs:
http://www.nouspikel...titechpages.htm
All chips are connected and powered except -5 is switched.
Too easy!
#24 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Wed Jan 25, 2017 9:54 AM
Too easy!
Yep, but I also read elsewhere that is buggy with certain cartridges that way.
I wish I could find the source of that info or possibly someone can chime in to confirm or deny it.
I have two plans in place until I gain more clarity, the navarone way or the way Tursi suggests with 2 lines cut (neither one being the -5v).
I'm still a bit of a way from deciding. My short term goal is to build it first. Then wire it up. I'm hopeful I will have it built this weekend giving all next week to figure out the best way to wire it up.
I'm pretty sure these switches allow me to cut up to 3 lines per button if not more. Obviously less is desired but I want to do what will work with all carts, ubergroms and more.
Edited by Sinphaltimus, Wed Jan 25, 2017 9:56 AM.
#25 Meddler OFFLINE
Meddler
    Star Raider
  • 64 posts
Posted Wed Jan 25, 2017 10:29 AM
Hell! With those switches you can switch all lines! :)
The Great Doctor addresses the 'buggy' problem later in the upgrade article but this has nothing to do with the basic Navarone Widget.
p.s the Navarone Widget is so simplistic you might as well try it first.
http://www.ti99.com/...pander-navarone
again...Good Luck. ;)
Edited by Meddler, Wed Jan 25, 2017 11:12 AM.
Also tagged with one or more of these keywords: 4 port, cartridge, Expansion
