1088XEL Alternative Mother-Board Project
mytek
Yes. Now I know why Incognito is white.
I hate to say it, but the white Lotharek produced boards are absolute shit when it comes to having to re-work them. Never in my life have I seen a board discolour so quickly. It's easier to re-work an XF551 or bad quality 130XE than these things.
I think the author mentioned that white will discolor with excess heat, or if reflowed/reworked. So perhaps it is a quality check reason that Lotharek uses it, in order to verify that the board assembly house isn't overheating the board. But yes I agree with you Stephen that it doesn't stand up well to any rework. Actually I like the yellow, but as pointed out, the silkscreen is usually fixed at white which doesn't contrast well. And lets face it unless you plan to mount this in a clear case, you aren't going to see the board anyway. So green really is the best and cheapest cost, and allows for easy inspection and/or rework.
- Michael
  • Like 5
About cost: I just ordered 5 PCBs at Elecrow and I could choose any color I liked for the same ridiculous low price.
5 PCBs of about 5 by 7 cm. For 8,71 euro shipped to Europe....
I chose black but since it's a prototype still I should have went with plain green for checking stuff....o well too late now :)
About white lotharek PCBs:
you can already see at the connectors that indeed the white boards brown very quickly from heat. (Also the soldering is not exactly perfect at the connectors ...too many "bulbs" IMHO but then again...hand work....
Yeah it's all just a stupid detail.....almost like fashion.....first it was blue, then red, then purple.....I'll take two boards whatever color they will come in :):)
Michael what software did you use for the PCB design ? I noticed you have a nice logo on it......which is an absolute nightmare to achieve with Eagle CAD..... I tried DIPtrace which seems a lot user friendlier than Eagle but the autoroutes seems a lot less intelligent....and yes I used the autoroute......it actually did a pretty damn good job.....manually corrected what needed to be corrected (thicker traces for power and routing those smartly etc.)
Edited by Level42
I think I'm partial to the black-on-green of my Telegames Heavy Sixer. :)
Anyone notice that this PCB was already designed using computer software.....pretty damn early. Look at the first Sinclair Spectrum board which was hand-routed.....(which has its charm IMHO....but that's probably because I remember designing a PCB with clear sheets, vinyl sticky traces and rub-off symbols. )
The very first arcade PCBs are hand-routed too but they were pretty quick to switch to computers....late 70s...
I've use Diptrace pretty heavily now for the last two or three years. In the schematics module you can go into the Objects menu and chose Net Classes. It opens up a window that you can define various net classes for trace width and clearance. Then right click on a wire in the schematic and chose properties, in the window that pops up change the class of the wire to what ever net class you want. Once you are ready to do the board layout, you've got it defined already and it will honor that class property when it goes to route. Advanced class properties can be and should be setup in the board layout module.
I used ExpressPCB for the schematic and PCB layout. Xcheck for the netlist and DRC checks. And Copper Connection for the ExpressPCB and logo import, as well as gerber file export. All free packages except for Copper Connection which unfortunately now belongs to ExpressPCB. I'm glad I bought it when I did.
I've used Eagle in the past for doing up to 4-layer board designs, but never really liked the interface. If I recall correctly, Eagle first started out as a MSDOS application and was then migrated over to Windows, which probably accounts for the odd interface. Although ExpressPCB lacks all the bells and whistles other applications have, it is extremely easy to learn, and as can be seen by the 1088XEL board, quite capable of taking on large projects. It also runs very reliably under Wine in my Linux box, and should do so in a MAC as well, so you really aren't limited as to what computer you wish to use. And it is a ROCK SOLID app, never ever locking up. No auto-routing, but I don't miss that. The biggest obstacle was lack of Gerber export, which I worked around by purchasing Copper Connection a year ago for $49. So basically my entire suite of Schematic Capture and PCB Layout software cost me just under $50. It's sad that Copper Connection is now under ExpressPCB's control, who pulled out the Gerber export feature unless you pay them a much larger fee.
- Michael
I'm looking forward to see the types of cases people choose and create. I was putting a few things up on Ebay, and for this Fisher Price toy it dawned on me that it would be a cool case for the 1088XEL. It has plenty of room inside, could house a 7" lcd panel, and the movie slot fits an Atari8 cart perfectly. ?post-8513-0-53047600-1508200544_thumb.jpg
  • Like 4
Of course there's always "The Big Box" from taco bell.
Fit's pretty nice.
Just kidding :P
Now for a bit of seriousness...
First board assembled from final test batch appears to work good right out of 'the box' ;) .
And it works even better if you put the chips in (and I'm not talking tortilla) :) .
I'll post a video in a few days with the CF Card adapter (XEL-CF) and flashjazzcat's new 1088 specific BIOS on board.
- Michael
  • Like 8
The Fisher Price Movie Theatre as case isn't completely ridiculous. We had this in 1975:
That was a $20k item and no toy at the time. The toy case very much lends itself to the small built-in screen portable form factor we used to have before the laptop was invented. The A8 has even been made to display movie clips so there is that too.
  • Like 7
Actually, what would really be cool would be to house it in something similar to this Dolch PAC 64.
I used to own a custom Dolch machine with this same form factor and they're really quite nice to use.
Lots of room inside for upgrades/cards, as well as drives (internal and external); nice keyboard and screen too.
Edited by MrFish
  • Like 5
Although I really like the potential of this case, at the same time I feel it's too big. After all, this is a Mini-ITX motherboard and we have an equally small HDD aspect in the XEL-CF MPBI adapter. What would be very cool is to find a suitable LCD monitor that could also house the 1088XEL for an All-in-One system. Even cooler still if it were patterned from the original Apple MAC, but with a smaller form factor. The CF card could be inserted from the front just like the original floppy. But of course it would have Atari branding, and a perhaps the 800XL color scheme. Sounds like a good 3D printed case project.
- Michael
Now that's also quite nice!
Edit: do you think that keyboard speaks PS2?
- Michael
Edited by mytekcontrols
*** BOARD MANUFACTURING FILE RELEASE for DIY ***
Production Gerber Files: 1088XEL_Rev1_1_production_gerbers.zip
I've done two test batches through EasyEDA, and both times they came out fantastic and for a very reasonable price. If you use that link, you can simply drag and drop the zipped gerber file, and then fill out the details on the order form.
IMPORTANT: Chose 170 mm x 170 mm, 4-Layer, 2 mm Thick Board and the number of boards you wish to order. All other options can be left at defaults, unless you wish to customize things like solder mask color and/or surface finish to your preference.
There are two shipping options depending upon where you live. DHL is very fast, but not cheap. However you'll get your boards in approximately 1 week choosing that option.
I still have some tweaks to do with the PIC firmware files, but i should get that done and uploaded here in about a week from today.
Enjoy :) !!!
- Michael
Please note that today marks exactly 9 months since this topic and first post were made. I also highly recommend going in on a group buy such as the one MacRorie is putting together. And once again let me warn you that assembly of this board requires an individual with excellent soldering and electronic assembly skills, and should not be attempted by a beginner.
  • Like 10
