Atari Pong Ever AV Modded?
7 replies to this topic
#1 virtvic OFFLINE
virtvic
    Star Raider
  • 53 posts
Posted Sat Jan 21, 2017 8:08 PM
Has the Atari home Pong series ever been AV modded?
I have a Super Pong and have never played it because I can't get a picture on an RF tv.
If I could AV mod it, I could at least try it on a more reliable tv. Picture would be vastly improved also...
#2 virtvic OFFLINE
virtvic
    Star Raider
  • 53 posts
Posted Sat Jan 21, 2017 8:29 PM
I have just looked inside it and it's not the popular pong on a chip AY-3-8500, it's a C010073-1
I'm trying to find a pin out to see if they are the same and therefore a simple mod is available already.
#3 omf OFFLINE
omf
    Dragonstomper
  • 787 posts
Posted Mon Feb 27, 2017 5:39 PM
something you could try is getting a composite cable earthing the outside with the board, power up your pong and touch each chip pin with the centre pole of the composite cable.
the voltage should be within what the tv can handle and you may be able to find some pins on the chip that output composite.
if you cant find any there you might try doing the same on the rf modulator pins, of course without a picture of the circuit board i cant be more specific but the above is worth a go
#4 ruthsarian OFFLINE
ruthsarian
    Space Invader
  • 19 posts
Posted Thu Mar 2, 2017 8:30 AM
I picked up a Tele-Games branded Pong console and was thinking about doing a composite video mod too. Attached are some pictures from inside the console.
Looks like I need to desolder the shield covering the solder side of the PCB, which I imagine will be a headache with all that thermal mass.
I'm still trying to figure out a plan of attack for the mod. I want to be as non-destructive as possible so the mod could be reverted one day if desired.
I'd like to continue using the RCA cable that came with the system (it's nice and long), but the RCA jack on the PCB means I'd have to either cut and strip one end of the cable or probably cut/rewire traces on the PCB. So I have no clue what I'm going to do and am still thinking on it.
As a side note, the security screws to open the case are "holt head" screws. I only found one driver online for holt head screws, it's called an "HY-50" screwdriver. I picked one up and while the bit is correct, it's too deep and won't grab onto the console's screws unless you file the thing down about a 1/2mm. And at $15-$20 range, it's not worth it. You can unscrew these things with pliers or a U-shaped "spanner" bit and a bit of perseverance.
#5 ruthsarian OFFLINE
ruthsarian
    Space Invader
  • 19 posts
Posted Thu Mar 9, 2017 9:44 PM
Based off the attached schematic (the only C-100 schematic I've ever seen) I lifted one leg of the diode at CR6 to essentially remove the RF modulation bit of the circuit. I then tried plugging the cable from 'R.F OUTPUT' (which should now be composite out) to the composite in on a TV and... nothing. I then tried pulling C29 and C27 and running a wire directly from L2 to 'R.F. OUTPUT' and still nothing. I'm guessing the composite signal needs to be amplified, but I've got no idea where to begin with that.
#6 Shockwav3 OFFLINE
Shockwav3
    Space Invader
  • 10 posts
Posted Thu Aug 16, 2018 7:28 AM
I know I'm a bit late to the party, but I just modified an Atari C-100 to output composite.
If you remove the battery casing temporarly and add a few wires you can lead the wires through the holes in the shielding and the rectangular cutout in the case and add a switch to maintain the original state without modifying the case. Switch can be glued to the compartment at the bottom with hot glue.
Quality between both is comparable, TV out has slightly more noise + grain and some interference from the speaker, composite has bleeding edges on the left (the ghosting on both photos is due to my smartphone camera). Adjusting the value of the pullup resistor at 1KOhm or using a different transistor for amplifying might help with composite. This modification is provided as "works for me" and was done on a "Tele-Games Pong" (is there such a thing as a PAL variant?).
It might also be possible to tap a usable signal from the CC3659 chip directly (one of the pins looked like a weak inverted video signal).
Schematic (MSPaint power!):
Locations:
My modifications (excuse the mess, these were taking during 'development'):
Quality comparision:
Underside of console (please ignore my mediocre hotglue-fu):
Edited by Shockwav3, Thu Aug 16, 2018 7:46 AM.
#7 Shockwav3 OFFLINE
Shockwav3
    Space Invader
  • 10 posts
Posted Thu Aug 16, 2018 11:06 AM
Hm ... turns out on my Sony PVM monitors I get a rainbow spectrum of colors for the white objects minus the top/bottom border on composite.
I'll look into that.
EDIT: Or is it supposed to be like that? Most videos on youtube show a color spectrum like mine ... I guess most TVs I've used have a problem with decoding the color in NTSC mode when using the TV out (I'm located in Germany - PAL territory)
Edited by Shockwav3, Thu Aug 16, 2018 11:55 AM.
#8 craftsman1234 OFFLINE
craftsman1234
    Space Invader
  • 10 posts
Posted Wed Oct 31, 2018 1:25 PM
Just saw this. Thanks for posting. Still testing on my PVM but so far so good using your method. I did not use the switch and for now instead of 75ohm 68ohm (what I could put together. The rainbow colors are normal and should be there.
Edited by craftsman1234, Wed Oct 31, 2018 1:29 PM.
