doctorclu Posted January 22, 2017 Share Posted January 22, 2017 Hey all, I know .mod files are used for lot of game development projects these days so I'll ask here: Has anyone had to adjust a mod to play slower or faster? If so, what utility did you use to make that speed change to a .mod file? I've tried Milky Tracker for the Mac and while you can play a .mod file at different rates of speed I didn't find where you could save the speed change. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted January 22, 2017 Author Share Posted January 22, 2017 40 views and no response. LOL! Ok, I'll try the Amiga boards... Quote Link to comment Share on other sites More sharing options...
neo_rg Posted January 22, 2017 Share Posted January 22, 2017 You need to use a compatible module editor / maker and set the tempo to what you want, what computer are you using. Quote Link to comment Share on other sites More sharing options...
lotek_style Posted January 22, 2017 Share Posted January 22, 2017 You need to set the speed in a Tracker and then choose any of the the channels... Usually it's an "F-Command". I suggest to check the tracker tutorials. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted July 24, 2023 Author Share Posted July 24, 2023 Just found Protracker 2 clone for Windows and Mac here... https://16-bits.org/pt2.php Quote Link to comment Share on other sites More sharing options...
ggn Posted July 24, 2023 Share Posted July 24, 2023 If you run into any sort of incompatibility (because there are at least 2 versions of the MOD format, and your player might not support one or the other), you can also try https://openmpt.org (Windows only) which should handle pretty much everything. Quote Link to comment Share on other sites More sharing options...
