Shift838 Posted January 31, 2017 Share Posted January 31, 2017 I sacrificed one of my cartridges that I have multiples of (TI Invaders) and cut off carefully the piece of the cartridge to use to insert in the cartridge port on the main board. Used a Ribbon cable to strip the ends and solder them to the piece of the Cartridge L connector Cartridge (L connector) port view (i believe this is the right pinout scheme) ====================== |2 36| |1 35| ====================== using the salvaged cut cartridge, solder odd wires on the back side of board (so pin 1 is on the backside left far pin) and even wires on top. Solder the odd wires on the back of the L Connector and Even wires on the Front of the L connector. So just a straight through. Then plug the salvaged cartridge board in the port on the 99/4A with Pin 1 to the left. Does this sound right or do I have something off? I have done this and when I plug it in and boot the TI up with a cartridge in the L connector and I just get a black screen and a tone. unplug the cartridge and it boots. I have checked and verified there are no bridged connections and continuity seems to be good from the respective pins on the salvaged board to the L connectors pin (provided my interpretion is correct of the pin layout). I am wondering if I have something wrong with my interpretation of how the connector needs to be wired. Thanks.. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted January 31, 2017 Author Share Posted January 31, 2017 i got it working. My perspective was off. I actually just needed to reverse the pins on one side of the cable. The L shape adapter threw me off. Now I have a 16" cartridge extension cable... 6 Quote Link to comment Share on other sites More sharing options...
