TI-99/4a nanoPEB RS-232 -> Tandy 102
43 replies to this topic
#26 arcadeshopper OFFLINE
arcadeshopper
  • 2,715 posts
Posted Wed Feb 15, 2017 10:15 PM
Am using a  serial -> USB convertor - hmmm may well even be that - I might try & install a serial card on the PC - good thinking!
Either that or try another usb adapter.. the ports on the TI tend to be picky about signal..  I use a FTDI chip USB adapter and it works great for HDX but others have had very frustrating times with USB adapters that don't work right with the TI you will always be better off with a real card
Greg
#27 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Tue Feb 28, 2017 9:26 PM
I modified Mass Transfer (40 columns) to work with the nano.  I didn't retrofit it with my high-speed routines, so the best speed is 2400 with dropped characters at 4800.  I uploaded it to Heatwave for test purposes.  Since I am still waiting for the power cord for my nano, I could only verify the program operates with a standard TI.
Hi InsaneMultitasker
I think I've grabbed the right disk off Heatwave. The file was called '@MT74NANO' which is a DSK that contains these 3 files:
  • MX74
  • MX75
  • MX76
Looks like I can load 'MX74' from the Editor/Assembler cart using "RUN PROGRAM FILE".
Sounds about right?
cheers
Daryn
#28 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,834 posts
Posted Tue Feb 28, 2017 9:33 PM
You got it. :)   Hopefully it will work; I really hate not being able to test things up front!
#29 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Thu Mar 2, 2017 7:35 PM
Gave it a go last night (after remembering how to add DSK's to the CF card for the nanoPEB!).
Going through the Run Program File, DSK1.MX74 etc etc didn't load and gave me an error 7.
Will try again in the weekend making sure I have the right files on my CF Card, 'cos it seemed to work on classic99 doing the same exact thing.
Will let you know!
Daryn
#30 Lee Stewart OFFLINE
Lee Stewart
  • 3,513 posts
Posted Thu Mar 2, 2017 10:27 PM
... Going through the Run Program File, DSK1.MX74 etc etc didn't load and gave me an error 7. ...
At the risk of suggesting the obvious, has the volume loaded on the nanoPEB with the MX74 files been mounted as DSK1?
...lee
#31 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Thu Mar 2, 2017 10:34 PM
...lee
Yeah I did a CALL MOUNT etc etc - actually I normally have the nanoPEB CATALOG stuff on DSK1, but I made the effort to move that stuff to DSK2 & made my DSK with the Mass Xfer stuff in DSK1 just in case- and I did run the CATALOG from DSK2 too see if the right disk was in DSK1.
I'II repeat what I did & just make sure, because I was in a hurry.
#32 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,834 posts
Posted Fri Mar 3, 2017 11:33 PM
Which method did you use to add the DSK to the CF card?
#33 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,834 posts
Posted Sat Mar 4, 2017 5:55 PM
I transferred Mass transfer 7.4 to my nano's CF device.  I was able to load the program using Editor Assembler option 5.  I grabbed a standard 9-to-25 pin cable, connected it to my UDS, and was able to telnet into Heatwave at 2400bps.  I am glad Jaime used a standard 9-pin RS232 pinout so that I didn't have to make my own cable!  I'm currently downloading a few files to the nano via Heatwave for testing... ;)    Hopefully your load problem is simple to resolve. You are using ALL CAPS, right? (and the file on the disk is capitalized?)
#34 Opry99er OFFLINE
Opry99er
  • 8,439 posts
Posted Sat Mar 4, 2017 7:01 PM
Well THAT is just too cool. :)
#35 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Sat Mar 4, 2017 9:08 PM
Woo! Tried my DSK on js99 & got the same error. So loaded the files back onto it this time in v9t9 format. Worked on js99. Then copied back onto CF card (all the time using xdt tools) and success! Loaded great. Thanks InsaneMultiTasker & everyone else.
Unfortunately it looks like I may have a faulty serial port on my nanoPeb. Still can't get an echo happening in Terminal mode from the TI to Linux using picocom. Will keep a lazy eye on a new nanoPeb.
Cheers everyone.
#36 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,834 posts
Posted Sat Mar 4, 2017 9:12 PM
Cheers everyone.
What pinouts/cable are you using on either end?  Might be something simple...
#37 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Sat Mar 4, 2017 11:09 PM
I guess thats the only other thing - it could be my null modem cable.
Have attached some piccies.
Attached File  IMG_20170305_171228.jpg   2.1MB   1 downloads Typing stuff in TERM mode on Tandy 102
Attached File  tandy2.png   50.77KB   1 downloads
Echoed out using picocom on ubuntu
So I know it "can" work.
For the TI, have now tried 3 different serial->usb convertors (left of piccie)
Attached File  IMG_20170305_171558.jpg   2.23MB   1 downloads
The middle one has FTDI. The top one is the one I use with the Tandy.
Attached File  IMG_20170305_171608.jpg   2.11MB   1 downloads
This is the null modem cable I am using
Attached File  IMG_20170305_171747.jpg   2.4MB   2 downloads
Settings in Mass Xfer
Attached File  IMG_20170305_173055.jpg   2MB   2 downloads
Typing stuff in Terminal mode
Attached File  ti99-3.png   49.5KB   2 downloads
Nothing appearing in Ubuntu. Tested with all 3 serial->usb converters.
Will keep on playing, will try another null modem cable. Or maybe a proper serial device on an old PC.
cheers
Daryn
#38 Shift838 OFFLINE
Shift838
  • 2,011 posts
  • SHIFT838
Posted Sun Mar 5, 2017 12:04 PM
attachicon.gifIMG_20170305_171228.jpg Typing stuff in TERM mode on Tandy 102
cheers
Daryn
If I'm seeing the picture right for the serial to USB adapters you are using the one with the LED light i know works as I use that one and have tested it with the TI while connected to both a Pi3 and a Windows machine.
I would think that maybe it's the cable or (hopefully not) you have a bad serial port on the Nano.
#39 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Tue Mar 14, 2017 1:18 PM
Hmmm - one thing I haven't tried is getting hold of a straight through RS232 cable.
InsaneMultiTasker - your post here:
http://atariage.com/...-3#entry3717509
Might indicate it would have more chance to work than perhaps a null modem cable? Or no real difference?
#40 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,834 posts
Posted Tue Mar 14, 2017 1:39 PM
Pretty sure you need the null/cross-over cable as you are connecting two DTE devices.  Are you certain your cable isn't a straight-through?  (I don't know how a Tandy COM port is wired).  There are some cables that don't pass all the signals.  Are you able to test the cable with a continuity tester?
When you type from the Mass Transfer side, does the cursor keep blinking or does it 'lock up'?  The latter could point to a CTS/RTS issue; see my most recent post in the midi thread.
#41 --- Ω --- OFFLINE
--- Ω ---
    TI-Runner
  • 10,938 posts
Posted Tue Mar 14, 2017 1:45 PM
The Tandy Model 100 & 102 were fun portable machines BITD.  I used to have the NEC PC8201A version.
It had two banks of 32K.  I also had mine hooked up to my TI-99/4A.
I always wished the versions of BASIC were more compatible between machines.  With all these "SUPER CARTRIDGES" we have now days it would be kind of cool if a version of GWBASIC was available for the TI.
#42 arcadeshopper OFFLINE
arcadeshopper
  • 2,715 posts
Posted Tue Mar 14, 2017 2:38 PM
I connect the tandy model 100 to the pc with a null modem. Therefore it should also connect to the nano with a null modem, but your cts/rts you found on the midi cable may be the issue.
I connect my nano to the PC for HDXS with a null modem.
Greg
#43 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Sun Mar 19, 2017 9:10 PM
Just for completeness, I purchased an RS232 Straight thru cable - nothing with picocom & linux.
My very last hope is purchasing the USB->Serial that Greg mentions in another thread:
https://www.amazon.c...0?ie=UTF8&psc=1
If that doesn't work then I will see if a new nanoPeb fixes the issue
#44 palmheads OFFLINE
palmheads
    Chopper Commander
  • 190 posts
Posted Thu May 18, 2017 8:07 PM
OK got hold of another nanoPeb.
Worked first time! :)
So TI using Mass X'fer (MX74) & nanoPeb with null modem cable connected to Ubuntu Linux and picocom! Got a echo terminal working! Great!
Will try my Tandy 102 in the weekend!!!
