f18a firmware update
46 replies to this topic
#26 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,520 posts
Posted Sat Mar 11, 2017 6:22 PM
Damn... that was FAST.  Too bad we don't have the 1.8 update program on the FlashROM99 for the TI!
Come to think of it, while my HDMI TI is 1.8, my main system is still running 1.6.   I think I'll ask in the TI section.
#27 Tursi OFFLINE
Tursi
  • 5,427 posts
  • HarmlessLion
Posted Sat Mar 11, 2017 7:07 PM
Will this work on an Adam as well?
I can't promise anything for Adam... mostly because I don't know what the compatibility issues are. I was told that Mario Bros didn't work on the Adam but I never got an opportunity to investigate why.
If it launches, it'll work. ;) Everything is carefully check-summed before it's committed. The host code does very little in this case, it just loads the updater to the F18A GPU and manages reading the joystick and cartridge banks.
#28 Tursi OFFLINE
Tursi
  • 5,427 posts
  • HarmlessLion
Posted Sat Mar 11, 2017 7:11 PM
Damn... that was FAST.  Too bad we don't have the 1.8 update program on the FlashROM99 for the TI! Come to think of it, while my HDMI TI is 1.8, my main system is still running 1.6.   I think I'll ask in the TI section.
You should be able to run the updater from your CF card or your HDX?
It will never be on the FlashROM99 (at least as it's designed today). It takes more than 32k. The bitstream alone is 166k and there's another 45k of ROM data. :)
#29 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,520 posts
Posted Sat Mar 11, 2017 7:14 PM
Oh yeah, I could run it from a CF, HDX, HxC or a 3.5... I was kind of thinking about people that might not have totally expanded systems.
#30 digress OFFLINE
digress
  • 1,104 posts
Posted Sun Mar 12, 2017 8:26 AM
Cool. Thanks for making this tool. Now for the unexpected question. can i downgrade the firmware to an earlier version?
Doing some play testing and it would be interesting to see what happens if I had an earlier version of the firmware.
Anyways just causing trouble. Thanks for making this upgrade. It'll help keep everyone up to date so there won't be any compatiblitlity issues with new f18a games.
#31 matthew180 OFFLINE
matthew180
  • 2,598 posts
Posted Mon Mar 13, 2017 1:04 AM
This updater kicks ass, thank you Tursi for taking the time and effort to reorganize the code-base and make the updater more portable.  I might have a crack at porting to the MSX1 since I have one I can test with.
@digress: The updater will not down-grade the firmware, but if you have a JTAG programmer you can load any version you want.  I only keep the latest firmware available, but the old version might be kicking around the Internet somewhere.  If you down-grade below V1.6, then you are guaranteed to have problems since the V1.6 changes were pretty substantial.  However, in every firmware release I have fixed bugs, so it is always recommended to run the latest firmware.
#32 Tursi OFFLINE
Tursi
  • 5,427 posts
  • HarmlessLion
Posted Fri Mar 24, 2017 10:35 PM
Apologies for the delay here, but work caught me off guard with some unexpected issues. However, that's done and I'm pleased to release the ColecoVision F18A updater for the 1.8 firmware.
Attached File  F18APureGPU_Coleco.rom   256KB   76 downloads
This is a 256k "megacart" style ROM, and I've tested it myself using the AtariMax SD cart.
It's had a few tests by myself and a couple of tests by Digress, so confidence is good, but I'd still like to hear a few more successes.
Over at Github the source code is available for porting: https://github.com/t...18aupdatecoleco
My goal with this project was to move the entire F18A update to the F18A GPU, so that the same code could be run on any system with the host only needing to provide a loader. The loader requires only keypresses and file data from the host machine.
Thanks to the careful checksumming and data CRC of the update code, writing the ColecoVision loader was fairly pleasant - bugs were extremely unlikely to damage the F18A. The data transfer is based on the TI disk access mechanism - if anyone takes a stab at porting it and finds the code a bit confusing, just let me know and I'll write up some better docs for you.
#33 vazquezrick OFFLINE
vazquezrick
    Chopper Commander
  • 211 posts
Posted Sun Mar 26, 2017 11:56 PM
Works great!!!
Thanks
#34 matthew180 OFFLINE
matthew180
  • 2,598 posts
Posted Mon Mar 27, 2017 2:22 PM
@Tursi: you're time and effort to produce this are greatly appreciated!  Now I really don't have any excuse (other than procrastination or laziness) to port it to the MSX. ;-)
#35 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Mon Mar 27, 2017 2:25 PM
A SV-328 port would be nice too.   Actually if it was ported to the MSX then making it work on a SV-328 would probably be trivial since it's 'almost' MSX compatible.
#36 phattyboombatty OFFLINE
phattyboombatty
  • 1,175 posts
Posted Wed Mar 29, 2017 11:01 PM
I just:
  • downloaded the ROM
  • transferred to my SD card
  • popped into my Ultimate SD for ColecoVision
  • and updated the firmware to v1.8 on my Adam
  • FLAWLESS VICTORY!!!
​This is killer! Tursi, you are an amazing programmer, and I am totally impressed with your work! Thank you for contributing to the ColecoVision scene. It is cool to have a modern "BIOS" type of updater for my 33 year old piece of tech!
#37 jblenkle OFFLINE
jblenkle
  • 4,722 posts
Posted Thu Mar 30, 2017 9:39 AM
So this would update the firmware on both the CV and ADAM F18As?
Is the update actually within this rom? Or is that another file?
I don't need an update as I have a brand new F18A just installed in my ADAM, but it's good to know for possible future updates.
attachicon.gifF18APureGPU_Coleco.rom
#38 matthew180 OFFLINE
matthew180
  • 2,598 posts
Posted Thu Apr 6, 2017 10:52 PM
phattyboombatty posted (post #36) that he ran the updater on his ADAM, so yes, it will update both the CV and ADAM.
Yes, this is a single ROM file that contains the program and firmware data you use with a CV/ADAM mega-cart of some sort (like the Ultimate SD, etc.)
#39 Ikrananka OFFLINE
Ikrananka
  • 2,834 posts
Posted Thu Jan 18, 2018 9:18 AM
Wow - somehow I missed this post.  This is awesome and once I get my CV with F18A back from loan I will use this to update my F18A.
A while ago I did buy a JTAG programmer but found that the cables it came with were the wrong pitch for the F18A connector.  I would still like to get the JTAG working, does anyone know where I can buy a reasonably priced cable that will work?
Edited by Ikrananka, Thu Jan 18, 2018 9:22 AM.
#40 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 610 posts
Posted Thu Jan 18, 2018 11:00 AM
This is what I use for JTAG.
https://store.digile...gramming-cable/
#41 Ikrananka OFFLINE
Ikrananka
  • 2,834 posts
Posted Thu Jan 18, 2018 3:34 PM
Ouch - is there no cheaper alternative?
#42 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 610 posts
Posted Thu Jan 18, 2018 3:36 PM
What jtag programmer do you have?
#43 Ikrananka OFFLINE
Ikrananka
  • 2,834 posts
Posted Thu Jan 18, 2018 3:38 PM
It's a cheap Chinese one from eBay, like this : eBay Auction -- Item Number: 201540354531
#44 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 610 posts
Posted Thu Jan 18, 2018 3:51 PM
Did it come with the 2mm 14 pin cable pictured? it looks like that should fit.
#45 Ikrananka OFFLINE
Ikrananka
  • 2,834 posts
Posted Thu Jan 18, 2018 4:08 PM
I discussed this was Matthew a while back but never got round to resolving the issue.  It seems that the connectors I received with mine are imperial (0.1" spacing) while the connector on the F18A board is metric (1mm spacing).  I tried to use the fly leads but the pins on the F18A are too small to make contact with the larger fly lead connectors supplied with my JTAG unit.
#46 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 610 posts
Posted Thu Jan 18, 2018 4:12 PM
The ebay listing shows a 2mm cable. You might be able to find a 2mm cable to plug in.
1 x 14-pin 2.0mm pitch 15cm flat cable,
something like this:
https://www.ebay.com...m-/181212516186
If you have the adapter board shown in the ebay listing you should be able to just get the cable
#47 matthew180 OFFLINE
matthew180
  • 2,598 posts
Posted Tue Jan 1, 2019 9:27 PM
A new firmware V1.9 is available for download from the first post in this thread (as usual):
http://atariage.com/...s/#entry2676606
This biggest change in this firmware is a fix to the horizontal timing that has been there since day-1.  It is amazing how many problems 6.4 pixels, or about 254ns) can cause, and how 59.4Hz refresh vs. 59.9Hz will break a good number of games!  On the 99/4A this fixes Pole Position, and probably some other titles that I am not aware of.  On the ColecoVision it fixes a rather large pile of titles, as well as the problems on the PAL ColecoVision consoles.
Note the unused sprite-linking feature was removed to ease up on the FPGA resource utilization.  There is a complete change-log entry in post #1, so if you are writing software for the F18A please review the changes.
Also in the update ZIP file is an in-system updater for the ColecoVision (requires a Mega-Cart).  Thanks to Tursi for making this happen, and for automating the tedious process of making the in-system updater programs in general.
I would like to encourage people to update, but as always, things can go wrong with the in-system updaters.  If something happens and you end up with a non-functional F18A, I have a $1 update service on my website (basically it costs you shipping).  I realize this can be expensive for people not in the U.S., but I might be able to find a few people in other countries who have a JTAG cable and who would be willing to help in cases where something goes wrong.
