SpartaDOS3.x Ingognito Clock Driver?
Incogniti SpartaDOS RTime8
1 reply to this topic
#1 Kyle22 ONLINE
Kyle22
  • 4,098 posts
  • broadway1.lorexddns.net 10001
Posted Fri Feb 10, 2017 11:35 PM
First of all, sorry if this info is found elsewhere. I searched but couldn't find it.  It is my hope that if a solution is found that it helps others with the same issue.
I am running Sparta 3.x on my Incognito 800, and the clock is wrong.  I remember something about Incognito being different from RT8, but I don't remember if it's just hardware addresses that need patched, or what.
I am trying to get Carina BBS running.  It claims to use the Z: handler, but I haven't seen any Z: references in the code yet.
I have seen COMTAB+16 in the code which indicates that it reads the time from Sparta directly rather than using Z:
Ideas?
Edit: To clarify, the clock is CORRECT in SDX, and in anything (DOS 2.x or whatever) that uses Z:.  Is is only wrong in disk based Sparta.
Edited by Kyle22, Fri Feb 10, 2017 11:38 PM.
#2 Triads OFFLINE
Triads
    Moonsweeper
  • 281 posts
Posted Sat Feb 11, 2017 12:11 AM
Are you loading ZHAND & TDLINE w/ TD OFF? Its required for MOE to show proper time. There is a Y2K fixed TDLINE out there as well.
Edited by Triads, Sat Feb 11, 2017 12:14 AM.
Also tagged with one or more of these keywords: Incogniti, SpartaDOS, RTime8
