GranTorino551 Posted February 12, 2017 Share Posted February 12, 2017 Hello. First time writer, long time reader. Recently, a friend gave me a non-working early model SNES to try to repair. One deep cleaning and sound module transplant later, it was good as new. The problem arose when I went to reassemble the unit. All the parts fit right back into place as they should except for the cartridge flap. I can't seem to get the spring that holds the flap up in place correctly. I re-watched the guides I used to disassemble the unit multiple times and I can't see what I'm doing wrong. No matter what I do, I can't put the spring on in a way that holds the door up like it should. I've attached a few photos for reference. I apologize in advance if the answer is so simple, you all question my higher brain function. Quote Link to comment Share on other sites More sharing options...
Jeremy Popp Posted February 15, 2017 Share Posted February 15, 2017 Hello. First time writer, long time reader. Recently, a friend gave me a non-working early model SNES to try to repair. One deep cleaning and sound module transplant later, it was good as new. The problem arose when I went to reassemble the unit. All the parts fit right back into place as they should except for the cartridge flap. I can't seem to get the spring that holds the flap up in place correctly. I re-watched the guides I used to disassemble the unit multiple times and I can't see what I'm doing wrong. No matter what I do, I can't put the spring on in a way that holds the door up like it should. I've attached a few photos for reference. I apologize in advance if the answer is so simple, you all question my higher brain function. Still stumped on this? I believe one end of the spring slides under that groove and that main support holds it in place. If you're still confused, I can take one apart tonight to refresh my memory and get back with you. Quote Link to comment Share on other sites More sharing options...
GranTorino551 Posted February 17, 2017 Author Share Posted February 17, 2017 Still stumped on this? I believe one end of the spring slides under that groove and that main support holds it in place. If you're still confused, I can take one apart tonight to refresh my memory and get back with you. I know the long end fits into that groove, but the problem arises when trying to figure out where the smaller end goes. It seems to just stick out like a sore thumb. If you could take yours apart and post photos/videos, I'd greatly appreciate it. Quote Link to comment Share on other sites More sharing options...
Jeremy Popp Posted February 18, 2017 Share Posted February 18, 2017 I know the long end fits into that groove, but the problem arises when trying to figure out where the smaller end goes. It seems to just stick out like a sore thumb. If you could take yours apart and post photos/videos, I'd greatly appreciate it. Here are some pictures "as installed" on one of my cases. I pulled it away a little on the last image, and you can see for sure the longer end slides under the top pieces that snaps in. It's really hard to explain, but I hope this helps. Underside: Top: Pulled away some on the underside: Quote Link to comment Share on other sites More sharing options...
GranTorino551 Posted February 19, 2017 Author Share Posted February 19, 2017 Got it, thank you! Turns out I was trying to put the spring in upside down. Sometime the solution really is that simple. Thanks again. Quote Link to comment Share on other sites More sharing options...
Jeremy Popp Posted February 19, 2017 Share Posted February 19, 2017 Got it, thank you! Turns out I was trying to put the spring in upside down. Sometime the solution really is that simple. Thanks again. No problem, glad I could help. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted February 21, 2017 Share Posted February 21, 2017 those little buggers (not just snes but any spring loaded flap) stump me every time, and every time I say "next time im going to take a picture" but never do Quote Link to comment Share on other sites More sharing options...
