+InsaneMultitasker Posted February 25, 2017 Share Posted February 25, 2017 (edited) This looks really nice, but I guess it does not fully exploit the G7 mode. It's a port of the F18A graphics, isn't it? There are still many colored strokes, although every pixel may have an individual color. Correct. I suppose that If Tursi added a save option to his Convert9918 program that would mimic either the 8-bit [gggrrrbb] palette per bit, or the MYART picture format (which I believe is an RLE encoded stream of the raw data), then we could have pictures that would exploit the G7 mode. As it stands, each scan line (pixel row) contains at most 16 colors of a possible 256, based on the converted data. Edited February 25, 2017 by InsaneMultitasker Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 25, 2017 Author Share Posted February 25, 2017 It should be possible to produce files for the G7 mode using a generic graphics program like Paint Shop Pro. An uncompressed G7 file would be 48 KiB instead of the 18 KiB used by the F18A files. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 25, 2017 Author Share Posted February 25, 2017 It should be possible to produce files for the G7 mode using a generic graphics program like Paint Shop Pro. An uncompressed G7 file would be 48 KiB instead of the 18 KiB used by the F18A files. Here's an example. 04-bridge-g7.bin 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 25, 2017 Share Posted February 25, 2017 Here's an example. Here is what the raw data looks like without any manipulation. Definitely more clarity, although the palette needs to be translated and the image is shifted. Quite interesting 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 25, 2017 Author Share Posted February 25, 2017 Hmm, I can explain the palette because i have used rrrgggbb instead of gggrrrbb. Here is a fixed version. I don't know why your image is shifted and has noise at the top. I have exported it from Paint Shop Pro using the raw format, which I think is just a dump of the pixels. Edit: That palette wasn't right either. I will fix it... Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 25, 2017 Author Share Posted February 25, 2017 This should be right. 04-bridge-g7.bin 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 25, 2017 Author Share Posted February 25, 2017 Here's a version that's scaled instead of cropped to 256x192. 04-bridge-scaled-g7.bin 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 25, 2017 Share Posted February 25, 2017 The noise near the top of the image was my mistake - when I redid the image display loop for raw data, I forgot to set the initial VDP write address. Since the last address written to was always the same, the noise stayed in the same place during each iteration, and I assumed it was from the image data. The non-scaled image looks crisper but the color pixels are more discernible, especially in the blues. The scaled image looks muted but the colors seem smoother. 4 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 26, 2017 Share Posted February 26, 2017 I have exported it from Paint Shop Pro using the raw format, which I think is just a dump of the pixels. What version (and options) did you for the final image/palette? I was looking for a comparable program to play with, but I can't find any relevant raw format information, either for PSP or any other program. Feels like I may be hunting for the wrong info. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 26, 2017 Author Share Posted February 26, 2017 What version (and options) did you for the final image/palette? I was looking for a comparable program to play with, but I can't find any relevant raw format information, either for PSP or any other program. Feels like I may be hunting for the wrong info. I'm Using Paint Shop Pro 7.04 from the year 2000 - still works fine in Windows 10. The palette file is just a text file. You need to remove the .txt that I put on in order to attach it here. In PSP I loaded the image and then loaded the palette, this will fit the image to the palette. I then saved it using the .raw file type. fixed332.pal.txt 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 17, 2020 Author Share Posted April 17, 2020 I just stumbled over this, and to be honest I just love to hear any rendering of the Monkey Island II music. This was my own demo: 8 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted April 18, 2020 Share Posted April 18, 2020 oh how I loved all the nights with adventure games ? 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted January 9, 2022 Share Posted January 9, 2022 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted 7 hours ago Share Posted 7 hours ago I revisited the Geneve adaptation of Rasmus' demo and encountered a few bugs. Most notably, I was incorrectly setting the 9938 VRAM memory type to 16K not 64K. Rasmus' rendition sounds so good that I let it play most of the afternoon. The ZIPped files are in TIFILES format. MonkeyIsland2 demo Geneve adaptation 4-2024.zip 2 3 Quote Link to comment Share on other sites More sharing options...
