Cap and VR kit specifications & replacement locations for the 2600 variants
29 replies to this topic
#1 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Mon Feb 13, 2017 4:09 PM
For 6 switch units to include the "Heavy" & "Light" sixer six switch units...
Heavy Sixer
Switchboard:
Replace C103 & C104 with a .22uf 100v or better mylar cap - regardless of what you find there.
Replace C106 with a 2200uf 16v or higher electrolytic cap
Replace A101 with a 7805 Voltage Regulator
Replace C105 with a 4.7uf 35v or higher electrolytic cap
Mainboard:
Replace C201 with a 4.7uf 35v or higher electrolytic cap
Light Sixer
Switchboard:
Replace C103 with a .22uf 100v or better mylar cap - regardless of what you find there.
Mainboard:
4 switch units - both woody and Vader variants rev 1-16
Replace C241 & 242 with a .1uf 100v or better mylar cap - regardless of what you find there. Versions 8's will almost always have ceramic disk... replace them with mylar.
Replace C243 with a 2200uf 16v or higher electrolytic cap
Replace A203 with a 7805 Voltage Regulator
Replace C201 & C214  with a 4.7uf 35v or higher electrolytic cap
IF you have a 4 switch unit AND your board revision level is LESS THAN version 16, install the 820ohm resistor between pins 6 & 9 of the TIA chip on the SOLDER SIDE of the circuit board.
Edited by mojoatomic, Mon Feb 13, 2017 4:26 PM.
#2 xucaen OFFLINE
xucaen
  • 1,330 posts
  • Back from the flood, looking to buy more games!
Posted Tue Feb 14, 2017 10:48 AM
fangirl_excited_crying_love_happy_emoji_
#3 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Tue Feb 14, 2017 10:58 AM
Glad you like it, hope it helps folks out :-)
#4 save2600 ONLINE
save2600
  • 15,593 posts
Posted Tue Feb 14, 2017 11:08 AM
I have to do my H6'er soon... colors no longer accurate and won't stay dialed in. Of course there has to be *one* cap under the heavy shielding that needs to be replaced!     :lol:
(would have been too easy had everything been accessible on the switch panel)
#5 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Tue Feb 14, 2017 1:27 PM
Won't be so bad, just a few screws on the the H6'er
Are your colors floating around when the unit warms up? Is there increased static after awhile, or just wonky colors?
#6 save2600 ONLINE
save2600
  • 15,593 posts
Posted Tue Feb 14, 2017 1:56 PM
No static and no wavy/rainbow/floaty color stuff going on. No funky RF stuff at all, tint slightly off is the thing and no amount of trying to dial in, even after leaving on for hours helps. Using the first screen on the color bar generator confirms what's going on that way - phase shifting. Have a 4-switch that exhibited the same symptom, but changed its caps and after warm up, colors now stabilize.
#7 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Tue Feb 14, 2017 2:33 PM
You beat me to it - that would be my guess a s well :-)
#8 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Tue Feb 14, 2017 5:01 PM
Heavy Sixer
Switchboard:
Mainboard:
Light Sixer
Switchboard:
Mainboard:
Anyone have this in a kit? I have 2 units that could use updates. Check my RF thread.
#9 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Tue Feb 14, 2017 5:15 PM
This Jackass has some... :-)
#10 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Tue Feb 14, 2017 5:59 PM
Not a nice way to talk about yourself. Lol
How much for a kit.
#11 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Tue Feb 14, 2017 6:59 PM
How much for a kit.
Pm sent
#12 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Wed Feb 15, 2017 12:53 PM
Just ordered 2 kits!
#13 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Sun Feb 19, 2017 11:37 AM
Is it possible to get pics of exactly where to place the resistor on the chip?
Just want to make sure I get it right. Thanks.
#14 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Sun Feb 19, 2017 1:49 PM
Sure, I'll take a pic when I get back home -
#15 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Sun Feb 19, 2017 3:23 PM
9AF4E08B-F67A-4249-8592-9A18BFE3CCFE_zps
Ok, just installed on a version 8 board... pin 6 & 9 of the TIA
#16 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Sun Feb 19, 2017 4:16 PM
Before -
1128E5F2-7578-4AA8-9164-5BBE4EE6920C_zps
After -
C38B3F8F-9F69-45F8-AC83-761A69C6C421_zps
Edited by mojoatomic, Sun Feb 19, 2017 4:18 PM.
#17 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Sun Feb 19, 2017 4:34 PM
Before video -
after video -
Edited by mojoatomic, Sun Feb 19, 2017 4:43 PM.
#18 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Wed Feb 22, 2017 8:28 AM
If I still have similar picture quality issues after replacing all of the capacitors and installed the resistor, can it be anything other than the old RF cable preventing me from getting a nice clean picture? Is there anything else I can try other than eliminating RF altogether and installing the composite upgrade kit I have?
#19 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Wed Feb 22, 2017 11:19 AM
Make sure to also install the Voltage Regulator. If there are still issue, a RF cable replacement would be in order. Also, it is possible to do an RF adjustment, but only after you've qualified or eliminated the RF cable as the culprit.
#20 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Wed Feb 22, 2017 12:03 PM
The voltage regulator was replaced. Can I just trim down another RCA cable or should I go online and search for one? Best Electronics I think is sold out.
#21 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
#22 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
#23 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Wed Feb 22, 2017 12:41 PM
Personally, I would make my own cable from RG6 and a crimp or compression type F type connector.
#24 Hank Rearden OFFLINE
Hank Rearden
    Moonsweeper
  • 383 posts
Posted Wed Feb 22, 2017 1:31 PM
What is the correct connector for inside the Atari? They have that short stubby one inside. Can you buy them at Lowe's?
#25 mojoatomic OFFLINE
mojoatomic
    Chopper Commander
  • 185 posts
Posted Wed Feb 22, 2017 1:51 PM
Unfortunately - no :-(
You have 3 options...
trim the nose of a regular RCA connector - this actually works fine
Desolder and reuse the original stubby RF/RCA connector from your original cable
Buy new stubby solder type coax style RCA connectors - I "Think" these are the ones...
