funkheld Posted February 17, 2017 Share Posted February 17, 2017 Hi good afternoon. Where can I get the two files from? RTSCAN.COM RTWRITE.COM Thank you. greeting ------------------------------------------- Here is Jeff Reister's PD Runtime package for the Action! 8 bit language. To use it in the simplest form, simply add to the beginning of your Action! program the line INCLUDE "D:RUNTIME.ACT" and compile as normal. If the compile is successful, the resulting file can be run as a binary file (No Action! cartridge necessary). Additional programs not included here because they are binaries: RTSCAN.COM - run against your source file to produce a listing showing which RUNTIME.ACT routines are actually required by your program. Allows you to trim out unneeded routines to save symbol table space, etc. RTWRITE.COM - If you send the output from RTSCAN.COM to a disk file, you can then run RTWRITE on that file -- it in turn outputs the trimmed down version of RUNTIME.ACT for you. These should be available from any respectable Atari club library. Of course, you don't need them for most programs, just include the full RUNTIME.ACT and don't get fancy. The whole works is on the computer services GEnie, Delphi, Compuserve. ------------------------------------------------------------------ Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted February 17, 2017 Share Posted February 17, 2017 Would be nice if Action could compile 65816 code, maybe a runtime for 65816 aswell. 1 Quote Link to comment Share on other sites More sharing options...
ricortes Posted February 17, 2017 Share Posted February 17, 2017 russg uploaded a pretty thorough zip RUNTIME.ZIP http://atariage.com/forums/topic/181823-analog-magazine-disk-image-31-0685/I'm not sure about the differences between RTSCAN2 and RTSCAN3 that are floating around. Quote Link to comment Share on other sites More sharing options...
funkheld Posted February 18, 2017 Author Share Posted February 18, 2017 hello thanks. this is ok : http://atariage.com/...-image-31-0685/ greeting Quote Link to comment Share on other sites More sharing options...
