Ultimate Atari Cart (Electrotrains) Pre-Order by 18 APR 17
Ultimate 800XL SD-Card Multicart Electrotrains
265 replies to this topic
#251 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,257 posts
Posted Sat Mar 10, 2018 9:05 AM
Folks,
If you are still looking for an Ultimate Cart and/or an UNO cart, eBay is doing a 20% off coupon!  PSPRING20 It is valid until 8 pm 09 March Friday-Today.  Save up to $19 on the Ultimate and $11.20 on the UNO
Here is a link to all of my auctions
https://preview.tinyurl.com/yctetvoc
-M
too bad your post came at 8:31pm and the coupon expired at 8pm..... oh well... late to the party again...
#252 SS OFFLINE
SS
  • 6,265 posts
Posted Sat Mar 10, 2018 9:21 AM
Too bad indeed because the coupon expired at 8:00pm *PST*. You could have squeezed it in just under the wire. :(
#253 _The Doctor__ OFFLINE
_The Doctor__
  • 6,257 posts
Posted Sat Mar 10, 2018 12:16 PM
If I was glued to AA at the time I might have... but  we also need time for cat, wife, food, and other such silly stuff :) travel nighbors etc.
Too old am I, too slow, and my timing to miss is impeccable as ever...
Edited by _The Doctor__, Sat Mar 10, 2018 12:18 PM.
#254 Zap! OFFLINE
Zap!
  • 1,761 posts
Posted Sat Mar 24, 2018 9:58 PM
Folks,
-M
It seems many of us missed it. Any other coupons coming up? :)
#255 MacRorie OFFLINE
MacRorie
  • 1,008 posts
  • No matter where you go, there you are.
Posted Sat Mar 24, 2018 9:59 PM
If I find out about them, I will let people know ASAP.  It's nice because eBay foots the bill.  I get the full amount, people get a discount, and there are more Atari cartridges in the world!
#256 Zap! OFFLINE
Zap!
  • 1,761 posts
Posted Sat Apr 7, 2018 10:15 PM
Awesome thanks!
#257 tane OFFLINE
tane
    Star Raider
  • 97 posts
Posted Thu Apr 26, 2018 10:23 AM
Ultimate Cart: Can the Shrouded box header be used to connect an external SD card?
It has 10 pin vs 8 pins used with a SD card.
Edited by tane, Thu Apr 26, 2018 10:55 AM.
#258 Zoyx OFFLINE
Zoyx
  • 1,581 posts
  • Prominent Internet User
Posted Tue Feb 5, 2019 11:08 PM
Just got an Atari 400. With this system, my Ultimate Cartridge boots up, but no menu. The cart works great with my XEGS. Is my early run cart not compatible with 400/800? Print on my PCB seems to indicate that.
#259 _The Doctor__ OFFLINE
_The Doctor__
  • 6,257 posts
Posted Tue Feb 5, 2019 11:54 PM
two things to do with your 400, make sure you have enough memory, and make sure cartridge port is standard and not using cas signal.
#260 Zoyx OFFLINE
Zoyx
  • 1,581 posts
Posted Wed Feb 6, 2019 12:58 AM
When I do a PRINT FRE(0) in BASIC ... I get something over 13000. I have no idea what the difference is between standard and CAS. This 400 hasn't been modded in anyway.
#261 MacRorie OFFLINE
MacRorie
  • 1,008 posts
Posted Wed Feb 6, 2019 1:02 AM
Wow, that is a very different PCB.  It should be the same as a regular model.  I will have to pull my unmodded 400 out and do some tests.
#262 Zoyx OFFLINE
Zoyx
  • 1,581 posts
Posted Wed Feb 6, 2019 1:43 AM
One thing I am going to try is install the latest firmware. I have to wait a bit for the USB Blaster to ship to me, though. Apparently the menu is in the firmware, and not handled by boot.rom. Hoping that changes things.
#263 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 756 posts
Posted Wed Feb 6, 2019 1:55 AM
You must have a 48 KB memory expansion to it work. Even when the menu software would work, the loader needs more space and/or the program to be loaded needs more then 16 KB RAM.
#264 Zoyx OFFLINE
Zoyx
  • 1,581 posts
Posted Wed Feb 6, 2019 2:21 AM
Ultimate cart supports the Atari 400. Doesn't give a memory requirement.
Now it might be true in my case... I have an early run version.
#265 _The Doctor__ OFFLINE
_The Doctor__
  • 6,257 posts
Posted Wed Feb 6, 2019 11:22 AM
technically correct in that you need enough memory to run the selection menu,
so long as you run only 400 compatible ROMS/BINS, it will emulate the cart and will run just fine. For xex loading or anything else not so much unless you have expanded the memory...
There still may be an issue with the cart port needing modification on your 400, basically the same fix as on the 800, a simple, simple fix if needed.
I no longer have a 400 for direct testing... sadly.
#266 Zoyx OFFLINE
Zoyx
  • 1,581 posts
Posted Tue Feb 12, 2019 11:08 PM
Installing the new firmware didn't do it. Same as before. The ultimate cart works fine on my XEGS. Boots, but no menu on my 400.
Also tagged with one or more of these keywords: Ultimate, 800XL, SD-Card, Multicart, Electrotrains
