F8 Rom Sec Is BAD
EF ROM diags2e
3 replies to this topic
#1 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 51 posts
Posted Sun Feb 19, 2017 12:19 PM
Using "Master Diagnostics IIe" (Diags2E.dsk from http://apple2online....ts/diags2e.zip)performing the "Motherboard ROM test" I receive "F8 Rom Sec is BAD".
I assumed this ROM was contained in the EF ROM chip, and swapping the chip with one from another board (same ROM part 342-0134-A) results in the same error.
The motherboard is a 1982 unenhanced Rev B, original chips.
I could not find documentation for "Master Diagnostics IIe".
Might this ROM code be located in another chip?
In case of a false positive report from this software, is there another utility known to test ROMs comprehensively?
Apple's "Apple IIe Diagnostics, V2.1" doesn't report an error during the "ROM/ CPU Test".
The system otherwise operates normally, except for the random wonky lock-up or dump to the monitor.
Attached File  F8 Rom Sec Is BAD 25%.JPG   83.87KB   2 downloads
#2 trash_44fr OFFLINE
trash_44fr
    Space Invader
  • 33 posts
Posted Fri Feb 24, 2017 2:43 PM
Hello Bloodnose,
Using the Master Diagnostics IIe image in an emulator, I experienced exactly the same behaviour with an unenhanced //e. The ROM test is okay with an enhanced //e so your Apple is probably ok.
You can try the XPS diagnostics which works great with an unenhanced //e (but not with an enhanced one).
#3 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 51 posts
Posted Thu Mar 2, 2017 1:56 PM
Thank you for the emulator idea.  It is a good comparison.
XPS diagnostics only tests the C0 and E0 ROMs.
I will keep looking for a diagnostic tool that is more comprehensive.
#4 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 51 posts
Posted Thu Mar 2, 2017 2:26 PM
I found the "APPLE ][ DEALER SERVICE PROGRAMS" ftp://ftp.apple.asimov.net/pub/apple_II/images/disk_utils/diagnostics/Apple%20%5d%5b%20Dealer%20Service%20Programs.dsk
which tests the F8, and it passes.
Reply to this topic
Also tagged with one or more of these keywords: EF, ROM, diags2e
