Regarding the CV Power Brick, is it actually unsafe to use?
7 replies to this topic
#1 ReddMcKnight OFFLINE
ReddMcKnight
    Star Raider
  • 89 posts
  • Founder of The Knights of Atari
Posted Mon Feb 20, 2017 4:18 PM
Besides it's overwhelmingly large size, is it actually unsafe to use for any reason? Is an Electric Fire or something more likely to start when using one or something? Or is it safe to use as long as you unplug it when your done? Can you use it for extended periods of time without issue? (Extended periods of time means 45 Minutes or more)
#2 save2600 OFFLINE
save2600
  • 14,788 posts
Posted Mon Feb 20, 2017 4:32 PM
I'd just keep that big bastard hooked to a power strip at all times and turn off when not using. I do that with all my game systems and their adapters and have never once had a problem.
Then there's people that'll tell you they leave their adapters plugged into the wall and have for years with no problems. Whatever. Leaving AC/DC adapters plugged in and converting power 24/7 definitely gets warm or HOT to the touch - and there's your potential fire hazard waiting to happen.   ;)
#3 jblenkle OFFLINE
jblenkle
  • 4,349 posts
Posted Mon Feb 20, 2017 4:43 PM
I don't think it's unsafe, but I would turn it off or unplug it when not in use. I'm paranoid as about a year ago I was using my Atari computer and went out of the room for less than a minute. When I cam back in, the power supply was smoking!!!
#4 Jinks OFFLINE
Jinks
  • 4,220 posts
Posted Mon Feb 20, 2017 5:43 PM
Every console gets unplugged here when done. Hell my toaster and coffee maker as well. I dont trust cheap or old electronics with my house.
#5 Kiwi OFFLINE
Kiwi
  • 1,436 posts
Posted Tue Feb 21, 2017 4:27 PM
I'm honestly more worried that it'll fry my Colecovision then it bursting into flames.  So I looked and brought the Canadian Power Supply.  Just keep a fire extinguisher near by, just in case either the power supply or the Colecovision burst into flame.  In seriousness, they should be safe.  I never heard of Adam printer or US Colecovision power supply bursting into flame so I wouldn't worry too much about it.
#6 SiLic0ne t0aD OFFLINE
SiLic0ne t0aD
  • 2,227 posts
  • Rock 'N Roller, Space Patroller
Posted Wed Feb 22, 2017 2:21 AM
I've left mine plugged in for months, even years at a time.. No problems whatsoever. I think you'll be fine.
#7 Vectorman OFFLINE
Vectorman
    Chopper Commander
  • 240 posts
Posted Wed Feb 22, 2017 10:24 AM
I store my poorly sealed cans of gasoline and oil soaked rags right next to where I keep mine plugged in 24/7/365. Sure it gets too hot to touch and makes a burning plastic smell, but no flames or smoke. No problems yet. I say totally safe.
#8 PkK OFFLINE
PkK
    Moonsweeper
  • 467 posts
Posted Fri Feb 24, 2017 5:16 AM
I've never heard of a CV power supply failing in a way that damages the CV. Usually when they break, the voltage gets lower, resulting in graphics errors or the CV not turning on at all. But the CV will still work with a good power supply.
Philipp
