Balck Screen with ATARI Module
6 replies to this topic
#1 Brood69 OFFLINE
Brood69
    Space Invader
  • 13 posts
Posted Fri Feb 24, 2017 12:35 AM
Hi guys,
I have a great fully working French/Scart Colecovision.
My problem is coming with the Module #1 : when plugging it, I just get a black screen and it won't read any game cartridge.
Unplugged, I get my Colecovision back as usual...
I already cleaned up the connectors many times, both in th extension slot and the Atari module,  and did not identify any other potential issues.
Anyone can help ?
#2 SiLic0ne t0aD OFFLINE
SiLic0ne t0aD
  • 2,198 posts
  • Rock 'N Roller, Space Patroller
Posted Fri Feb 24, 2017 4:26 AM
Replacing the capacitors inside wouldn't hurt.
#3 Brood69 OFFLINE
Brood69
    Space Invader
  • 13 posts
Posted Fri Feb 24, 2017 6:53 AM
I initially thought the Atari Module was just a rewiring...but indeed, after opening it, there is way more than that !
Mine looks brand new (I have it in box) and I will start looking at the electronic components.
Any other ideas welcome
#4 ten-four OFFLINE
ten-four
    Dragonstomper
  • 893 posts
  • Here i am... again!
Posted Fri Feb 24, 2017 7:27 AM
Hi Brood69.
You need a French CBS Atari Module for your French CBS Scart ColecoVision.
I am in the same boat as you, I have had several ColecoVisions.
But when I bought the French CBS Scart version few years back and would try my UK CBS Atari module it was all black screen.
​The French pin out is not the same as the U.S. and the "normal" CBS version.
​I do not have the French CBS Atari Module myself so.
it should be possible to change, but I have not had time to even look at it
#5 Brood69 OFFLINE
Brood69
    Space Invader
  • 13 posts
Posted Fri Feb 24, 2017 3:39 PM
Damned, I am done !!
Will check my Atari module but that must be it...
So I have an almost new module #1 for sale :-)
#6 Brood69 OFFLINE
Brood69
    Space Invader
  • 13 posts
Posted Tue Feb 28, 2017 2:53 AM
In fact no...I had a French version of the Expansion Module 1 too !
So it does not work...I need to check the Inside.
One quick question : when you switch on the Colecovision with the module connected but no Game cartridge inserted, do you get anything else than a blanck screen ?
#7 ten-four OFFLINE
ten-four
    Dragonstomper
  • 893 posts
Posted Tue Feb 28, 2017 2:36 PM
French CBS ColecoVision turned on and U.K. CBS Exp. Module 1 connected.
There is both Black screen with or without Atari cartridge inserted. (PAL Silver).
I know the sound can't work, but it can be fixed.
