Power Adapter Cable PSP to 600XL/800XL/65XE/130XE/XEGS
15 replies to this topic
#1 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Fri Feb 24, 2017 10:49 AM
These cables adapt a Sony PSP power adapter to an Atari XL/XE machine with 7-pin din connector. The original Atari power sources are huge and waste a lot of electricity in the form of heat. Easily use a reliable and efficient Sony PSP power adapter instead! It will provide the same 5V AC that an Atari power brick provides and sufficient amps. I personally assemble and test each of these. Each utilizes a high quality metal connector to interface the Atari, not cheap plastic connectors from China. $12 shipped in the USA.
Edited by Serpentor, Mon Mar 20, 2017 6:04 PM.
#2 masschamber OFFLINE
masschamber
  • 1,093 posts
Posted Fri Feb 24, 2017 2:40 PM
wow, that is an awesome thing you made there, have to go see if I still have an original psp power supply kicking around before I buy one though
#3 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Sat Feb 25, 2017 7:35 AM
Thank you.  In addition to replacing the original Atari adapter, it is also able to work with the PSP-180u adapter, making it possible to power the Atari through a lighter socket.  Anyone wanting to bring old school 8-bit gaming to a tailgate party, RV, or on the go can now easily do so :)
#4 ianoid OFFLINE
ianoid
  • 2,864 posts
Posted Sat Feb 25, 2017 7:43 AM
Cool looking, but then why can't we make a USB to Atari 8-bit with the 5v requirement being the same. AmIright?
I would consider one of those if I didn't already have a switching PS hack I bought. Those are slick looking!
#5 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Sat Feb 25, 2017 9:24 AM
Thank you for the compliment on my adapter.  I considered USB but decided against it.  I just don't see the upside to it since USB ports don't typically supply enough power to meet the Atari's needs.  People would need to find higher powered hubs, and it would all get a bit confusing since most people think they can plug a USB cable into any port and things should work.  I think it's easier to stick to properly powered power bricks with small form factors.  The PSP power supply was the best option I found taking size and quality into account.
Edited by Serpentor, Sat Feb 25, 2017 9:26 AM.
#6 davidcalgary29 OFFLINE
davidcalgary29
  • 5,615 posts
Posted Sat Feb 25, 2017 10:45 PM
Amazing! I haven't used my PSP in about five years, so I'll at least be able to use the power supply for something. Will it work with Vita power supply as well?
#7 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Sat Mar 4, 2017 2:48 PM
Four sold. Six left from the initial batch of ten.
#8 Scooter83 OFFLINE
Scooter83
    Dragonstomper
  • 608 posts
Posted Sun Mar 5, 2017 5:17 AM
Will this work with the xegs? I assume it would but figure I'd ask
#9 Scooter83 OFFLINE
Scooter83
    Dragonstomper
  • 608 posts
#10 brenski OFFLINE
brenski
  • 1,501 posts
  • How should we f**k off, oh Lord ?
Posted Sun Mar 5, 2017 11:45 AM
hi, are there any left, and you're willing to post to UK,
or are these USA voltage only?
Edited by brenski, Sun Mar 5, 2017 11:47 AM.
#11 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Sun Mar 5, 2017 12:02 PM
It will. I should add that to the thread title.
#12 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Sun Mar 5, 2017 12:05 PM
I have five left and will look into the power requirements of the PAL systems.  I designed it with the American released unit in mind, but perhaps it can work for systems from other regions.
#13 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Mon Mar 20, 2017 11:32 AM
Four remaining
#14 masschamber OFFLINE
masschamber
  • 1,093 posts
Posted Mon Mar 20, 2017 12:47 PM
anyone in the fence ill say it works perfectly
#15 zetastrike OFFLINE
zetastrike
    Moonsweeper
  • 366 posts
Posted Mon Mar 20, 2017 7:33 PM
Will this work with any official PSP adapter?  I have a 3000, if that matters.
#16 Serpentor OFFLINE
Serpentor
    Star Raider
  • 83 posts
Posted Tue Mar 21, 2017 10:12 AM
It should work.  I've never seen a PSP adapter below 1500mah, and that is sufficient to power the various Atari systems with the 7-pin connector.
