Coleco with screen out of sync may be...
11 replies to this topic
#1 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Sat Feb 25, 2017 1:41 PM
Hi,
I have a coleco with out of sync i think with all games.
Something like this:
http://derbian.webs....lt.htm?id=c19_1
I have 10,90v in pin 8 of RAMs (the 12v line). Its low?
Any help? Thanks!
#2 cdn2a OFFLINE
cdn2a
    Star Raider
  • 72 posts
Posted Sun Feb 26, 2017 6:12 PM
So, first off.. it's a PAL Coleco. I don't know too much about those.
You can test the VDP, but odds are your getting a signal. (Based on you screen shot.)
Is the a tuneable slug/inductor in the modulator? For channel freq.
The part you have circled is an old shcool inductor.
#3 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,421 posts
  • Coding something good
Posted Sun Feb 26, 2017 6:15 PM
In NTSC Colecovision, checking pin 36 of VDP chip right to center of a composite jack and GND in side should generate a stable black & white picture.
I don't know about PAL, but it could be the same.
If the picture isn't stable then the VDP chip is damaged and needs replacement.
#4 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Mon Feb 27, 2017 6:30 PM
Hi guys...
It's a PAL version. nanochess, so i can connect a composite jack to pin36 (center) and the ground of VDP, external side of the jack (pin 1 may be, i need to search schematic of VDP).
Ok, thanks!
#5 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Wed Mar 1, 2017 10:48 AM
Anyone know the specifications of that old inductor encircled? I want to change it.
Thanks.
#6 cdn2a OFFLINE
cdn2a
    Star Raider
  • 72 posts
Posted Wed Mar 1, 2017 2:40 PM
They are ancient... They are rated by color codes.
PAL is prob different from NTSC check here...
If you desolder it you can measure it too.
http://www.vishay.co...ode-calculator/
#7 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Wed Nov 22, 2017 5:52 PM
Hi again..
Trying with some cartridges, i noticed about sound. Is good, no problem. Here a small video with "Decathlon" game.
https://youtu.be/JkmGIYVekJY
#8 Jinks OFFLINE
Jinks
  • 4,349 posts
Posted Thu Nov 23, 2017 5:06 PM
Mine does the same nfi how to fix
#9 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Wed Dec 6, 2017 12:33 PM
Mmmmmmm... suspect discovery. A pnp transistor, 2N3906 near vdp. Anyone can confirm the value of EBC in board?
Thanks!
#10 adamcon OFFLINE
adamcon
    Moonsweeper
  • 317 posts
Posted Wed Dec 6, 2017 3:14 PM
Thanks!
Replace it anyway.  This transistor is a huge problem in the ADAM data drives, and probably many other applications.
#11 Mauro72 OFFLINE
Mauro72
    Space Invader
  • 17 posts
Posted Thu Dec 21, 2017 1:15 PM
Fixed!!!! :)
Mixed problems, faulty power supply and two bad vrams. Now working!
Thanks!
#12 nanochess OFFLINE
nanochess
  • 5,421 posts
Posted Thu Dec 21, 2017 1:44 PM
Well done! :thumbsup:
