+Larry Posted March 5, 2017 Share Posted March 5, 2017 @ Frankie- Thanks. The only differences that I see are that my FTDI adapter uses com 3 with RI. It might be wired to RI. (?) I need to look at that sometime. And my XP ran better with the Master Timing set at +40 to +50. Interestingly, it runs worse on my Win7-64 box @ 3.4 GHz. In fact, it crashed windows to the BSOD. Think I'm done with this exercise... -Larry Edit: Couldn't resist.. I got out another adapter -- the one from Sloopy that is the SIO plug mini type. This one sets itself up as Com 4, but as DSR, and it works much better. I can get 3X on my XP machine, with the Master Schedule set at the default of zero. The SIO even sounds better -- cleaner, if that makes any sense. Also went back and opened up the original FTDI adapter, and it was wired as RI. Rewired it to DSR, and now it sounds and works just as good as the Sloopy adapter. 3 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 9, 2017 Share Posted March 9, 2017 funny how data set ready has always worked better as it is indeed a flow control line... where as ring indicate has historically had mixed success being used in that fashion.... but it does make sense if you think about their designed purpose and how virtual serial ports software simulates those lines Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 15, 2017 Share Posted March 15, 2017 I made my own SIO2PC USB cable with one of these: http://www.ebay.com/itm/6P-FTDI-FT232RL-USB-to-Serial-adapter-module-USB-TO-TTL-RS232-Cable-F-Arduino-5v-/111241824248?hash=item19e68787f8:g:7ScAAOxycmBSs3lW All I had to do was add the SIO plug. This one uses CTS for the command line. It works perfectly with APE Pro and RespeQt. It runs full speed (divisor zero) in RespeQt, and PCLink works great. 5 Quote Link to comment Share on other sites More sharing options...
