Controller Issues
2 replies to this topic
#1 reklen OFFLINE
reklen
    Star Raider
  • 77 posts
Posted Wed Mar 8, 2017 12:46 AM
I just got a refurbished Colecovision.  It seems to be working fine, better than any I had before.  However, it only seems to work with Coleco joysticks and 2600 joysticks.  I read that 7800 joysticks and europads should work, but they didn't.  The Genesis pad did, but when I played Frenzy, the screen kept blacking out, which didn't happen when I used a 2600 stickl.  The reason I'm asking is because I just got a Roller Controller, and the thing worked, for about 5 minutes, now it just goes up and down  Likewise, when I try the 7800 joystick, the characters won't go down, just up, left and right.  Do you think this is a port issue?
#2 fiddlepaddle OFFLINE
fiddlepaddle
  • 2,359 posts
Posted Wed Mar 8, 2017 10:48 PM
Some genny controllers work ok, some don't. 2600 sticks are fine, but you'll need a y-adapter to use the keypad on the colecovision controller (don't know about 7800). Lots of Roller controllers seem to develop that problem; can be fixed but usually requires a part (I don't have specifics).
#3 SiLic0ne t0aD OFFLINE
SiLic0ne t0aD
  • 2,204 posts
  • Rock 'N Roller, Space Patroller
Posted Thu Mar 9, 2017 4:13 AM
You'll need to take the roller controller apart and clean the actual rollers, there's probably some crud on them. Using some DeOxit D5 might not be a bad idea as well.
