TRS Model 4 Screen problems
polyex
My model 4 screen is jittery. It jiggles and the size changes rapidly back and forth at times. Sometimes it is stable but for the most part it is not stable. I had an identical thing happen to me with a Wizard of Wor arcade machine. Turned out to be a sync problem with a bad transistor. Are the schematics to these Model 4 monitors around? Anyone know common failure points for sync problems?
Regards,
Adam
basically.. the power supplys are weak.. they get weaker with time.. they probably need new caps and so does the monitor chassis.. the flickering tends to happen during disk access which is the highest current draw my model 4 does this but it's tolerable so I haven't done the rebuild. Not sure if there are cap-kits to buy or if I have to just take it apart and make my own list. Also using modern lower power drives helps.
Greg
