Bikerbob Posted March 15, 2017 Share Posted March 15, 2017 Well people, I have been trying to fix up an old Indus GT I had .. that had a bad display. I had thought it was the Seven seg. displays themselves. Now Im not so sure. I removed the old displayed.. replaced them with the same part # but was not able to get them to fit the same way the old ones did.. because the pins have been re-arranged. But they are in. Now I am still getting segments flaking out and disappearing.. and I think its the display board ribbon cable and its connection to the main board. See the attached pics. If anyone knows what type of ribbon or connectors I should search for? or what I could replace it with. I would really like some help on this one. Thanks James Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted March 15, 2017 Author Share Posted March 15, 2017 What about doing this? with a row of sockets or pins on the board and the display board? Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted March 15, 2017 Author Share Posted March 15, 2017 For people who design boards, and need headers etc.. how do you identify what type of header is what? I need it flexible on the display board end.. or right angle.. if I use a 24pin header, am I amble to keep the pins 12 to top row and 12 to bottom row? Hope someone can help. Quote Link to comment Share on other sites More sharing options...
1050 Posted March 15, 2017 Share Posted March 15, 2017 No real help from me, sorry about that. It's a specialized system, so common word phrases are likely to be wrong use in the first place. I can see that the spacing is likely to be one tenth inch exactly but IDE floppy cable isn't that either. And that type cable wired point to point manually is all I can come up with. The rainbow type pictured can help keep one sane somewhat? IC sockets are also .100" pin spacing if that helps. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 15, 2017 Share Posted March 15, 2017 Have you tried manually lighting the segments up via the ribbon cable? Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted March 18, 2017 Author Share Posted March 18, 2017 Yes.. what I ended up doing.. was taking machine sockets.. cutting them up into SIP lines of 12.. soldering them into the display board and main board. Then using a ribbon cable from an old header card.. solding those to the pins on the display board and then to headers that plug into the main board. Its not as pretty as I would like, but its worked.. everything is good now except I think in my soldering I have one trace now touching another causing the middle segment on one display to be on all the time. Otherwise its working fine. James Quote Link to comment Share on other sites More sharing options...
