Repairing roller controller buttons?
7 replies to this topic
#1 eatenbygrues OFFLINE
eatenbygrues
    Space Invader
  • 24 posts
Posted Wed Mar 15, 2017 11:17 AM
So I recently acquired a roller controller in pretty bad shape (it was filthy), anyway I got it all cleaned up and amazingly the optical sensors still work fine, the buttons on the other hand do not. I managed to open the buttons (you can remove the black piece by snapping it out of the top) and found that all they are is little grey rubber contact buttons (like you would find in say a SNES controller). It looked like the rubber domes had become worn/brittle with time, two of them were torn.
1. Does anyone know of a replacement for the button contacts? (the grey rubber piece)
2. Does anyone know of a complete replacement for the switch? (as in de-soldering the old switch, putting a new one in).
(I can post pictures if needed)
Edited by eatenbygrues, Wed Mar 15, 2017 11:18 AM.
#2 eatenbygrues OFFLINE
eatenbygrues
    Space Invader
  • 24 posts
Posted Thu Mar 16, 2017 11:44 PM
Ok so I managed to get it working again, but I think we will eventually need to source some replacement contacts for these things because they aren't going to last forever. What ended up working for me:
  1. I removed the black cover of each switch and sort of 'massaged' them back into the correct position. I left it like this for about 2 days, and the rubber button contacts took their original shape. I'm not sure if it was moisture or what the deal was exactly.
  2. I also noticed that the solder joints on a few of them had become broken, so I had to reflow those joints.
So all four buttons work, but with the 'bottom' two I get a nice tactile response. The top two buttons work fine in that they register presses but they don't 'bounce back' like you would expect.
Edited by eatenbygrues, Thu Mar 16, 2017 11:45 PM.
#3 mykgerard OFFLINE
mykgerard
    Space Invader
  • 40 posts
Posted Mon May 15, 2017 5:44 PM
so hey... I have a similar problem.  only one of my roller controller buttons works (off and on)  I took it apart and I can't say I know what you are talking about as far as grey parts.  I see four little switches that look like white cubes with black tops.  Did you mean that you took the black tops off of those and there was grey underneath?
#4 Swami OFFLINE
Swami
  • 2,490 posts
Posted Mon May 15, 2017 8:59 PM
A refurbisher told me it is cheaper to buy a new one than get one of the accessories professionally refurbished, so I doubt there is much of a market for the parts. Who were the ones to buy up the mass Coleco liquidations back in the 80s? Like the Colecovision Best Electronics? Someone in New England most likely, since Coleco had a major plant in New York.
#5 NIAD OFFLINE
NIAD
  • 6,163 posts
Posted Fri May 19, 2017 10:04 PM
It's not always cheaper to buy a replacement especially if you own the necessary skill set to diagnose and repair issues as well as the time to spend. For those less skilled, it will be cheaper to buy a replacement, but don't throw away the defective item, rather donate it to someone like Yurkie who could repair or re-purpose the unit.
American Design Components and eColeco (called ADAM's House back then) are two that come to mind who bought large stocks of CV & ADAM goodness when Coleco started liquidating their videogame and computer stocks. eColeco is still in business and has a website at www.ecoleco.com
#6 mykgerard OFFLINE
mykgerard
    Space Invader
  • 40 posts
Posted Mon Jun 12, 2017 4:51 PM
so, how did you get the black tops off?
#7 vintagegamecrazy OFFLINE
vintagegamecrazy
    Chopper Commander
  • 214 posts
Posted Thu Feb 22, 2018 11:52 AM
Does anyone know where I can get replacement optical sensors for the roller controller? One is dead and I might as well replace the other one too.
#8 alortegac OFFLINE
alortegac
    Chopper Commander
  • 177 posts
Posted Sun Dec 16, 2018 7:13 PM
Is there a substitute part no? I need 1 sensor. Thanks
