soldering station recommendations ?
12 replies to this topic
#1 Shift838 OFFLINE
Shift838
  • 2,012 posts
  • SHIFT838
Posted Fri Mar 17, 2017 6:26 PM
Ok, looks like my Madell bit the dust after 12 years.  Any recommendations for a decent soldering station?
#2 arcadeshopper OFFLINE
arcadeshopper
  • 2,724 posts
Posted Fri Mar 17, 2017 6:57 PM
Hakko fx-888d
Sent from my LG-H830 using Tapatalk
#3 --- Ω --- OFFLINE
--- Ω ---
    TI-Runner
  • 10,955 posts
Posted Fri Mar 17, 2017 7:05 PM
Does anyone know why << this one on Ebay >> is so CHEAP for what you get?
I mean really, only $65.75 with shipping included?
#4 Nathan Strum OFFLINE
Nathan Strum
  • 7,568 posts
  • Enjoying a sandwich
Posted Fri Mar 17, 2017 7:06 PM
I have a Hakko 936 that I've had for years, and works great. Not sure what the current equivalent would be - maybe the 950.
#5 Shift838 OFFLINE
Shift838
  • 2,012 posts
  • SHIFT838
Posted Fri Mar 17, 2017 7:58 PM
Hakko fx-888d
I was just looking at that one Greg!
Damn...  You're in my head!
#6 arcadeshopper OFFLINE
arcadeshopper
  • 2,724 posts
Posted Fri Mar 17, 2017 7:59 PM
And it's what I use ;)
#7 Shift838 OFFLINE
Shift838
  • 2,012 posts
  • SHIFT838
Posted Fri Mar 17, 2017 8:20 PM
My wife happened to be at Frys here in Houston and she said they had one and it was on sale for $80, so i had her pick it up.
#8 Shift838 OFFLINE
Shift838
  • 2,012 posts
  • SHIFT838
Posted Fri Mar 17, 2017 9:55 PM
Did you buy a smaller tip or just use the standard one that came with it and what do you typically set your temperature to?
#9 arcadeshopper OFFLINE
arcadeshopper
  • 2,724 posts
Posted Fri Mar 17, 2017 9:56 PM
I use the chisel tip for most stuff 750
#10 Vorticon OFFLINE
Vorticon
  • 2,924 posts
Posted Fri Mar 17, 2017 10:04 PM
The Chinese work their magic again... One of the issue one would likely encounter is a lack of replacement tips in the future, that's assuming the thing worked long enough to get to that point. Tempting...
I ended up buying the standalone hot air station, something I don't have and can use. At $35 including shipping, I figured it's worth trying it out. I already have a good Hakko soldering station and several variable power supplies, so the extra features would have been redundant.
#11 wyerd OFFLINE
wyerd
    Moonsweeper
  • 415 posts
Posted Sat Mar 18, 2017 10:10 AM
I recently purchased a Hakko 888D and I can't recommend it enough! I recently had to replace a faulty PLCC CPU socket in my Atari STe. I've been using a very cheap and cheerful soldering iron from from Radio Shack which besides being big and clumsy, had a tendency of damaging the circuit board as there wasn't any temperature control. I also had a look at these hot air rework soldering stations and almost bought one, but they had a lot of mixed reviews. If the price is too good to be true, it more likely is. More research came up with the Hakko and at around $100 on Amazon, I decided to buy it. it is just fantastic to use! It heats up very quickly to the selected temperature making desoldering with soldering wick a breeze. Soldering was even easier, none of this "is the solder going to melt properly?" It just works! The socket was removed successfully and the new one soldered cleanly and without any fuss or mess. My best repair to date!
Edited by wyerd, Sat Mar 18, 2017 10:11 AM.
#12 Shift838 OFFLINE
Shift838
  • 2,012 posts
  • SHIFT838
Posted Sat Mar 18, 2017 11:30 AM
I got the Hakko FX-888D and got to use it for the first time earlier.  This little unit is great.
#13 CC Clarke OFFLINE
CC Clarke
    Space Invader
  • 33 posts
Posted Sun Mar 26, 2017 1:51 PM
Hakko makes a good product, (I use their fume extractors) but I have yet to find a better soldering workstation than those produced by Metcal (later bought out by OK Industries.)  If you know of a better one, I'd love to test one out.
Working in the aerospace industry, this is all I see used at all the contractors sites I've visited when high-reliability, ESD-safe soldering is required.  Note there are only two controls, a power switch  on top and a selector switch between two outputs (for a solder hand piece and a solder extractor) on the front.
No temperature controls are needed. The tip senses how much heat is required and the unit provides the power instantly.  I've never burned a board, lifted an etch, or even measeled the laminate with one of these.  I use one at home too.  There's nothing cheap about these, but if you can find one in your budget, by all means grab one!  Tips aren't cheap either, but last a long time.  Metcals are the gold standard for professional solder stations.
Pictured is a Metcal 500 series.
CCC
Edited by CC Clarke, Sun Mar 26, 2017 1:55 PM.
