A 1200 Question...
13 replies to this topic
#1 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 504 posts
Posted Sun Mar 19, 2017 4:35 PM
Did any software take advantage of the Function Keys on the 1200?
DavidMil
#2 tjlazer OFFLINE
tjlazer
  • 1,822 posts
  • Retro Atari Addict
Posted Sun Mar 19, 2017 6:13 PM
I haven't seen anything, but I'm curious as well.
Edited by tjlazer, Sun Mar 19, 2017 6:13 PM.
#3 ACML OFFLINE
ACML
    Dragonstomper
  • 741 posts
Posted Sun Mar 19, 2017 6:26 PM
These work in BASIC, Atariwriter, etc., but you have to have the 600/800XL or 1200XL OS.  The 400/800 and XE OS ROMs do not support the added keyboard functions.
Non-Redefinable 1200XL Function Key Behavior
_____________________________________________________________
CONTROL + F1 Keyboard enable/disable (console keys not affected)
CONTROL + F2 Screen display enable/disable
CONTROL + F3 Key click sound enable/disable
CONTROL + F4 Domestic/International character set toggle
F1 Cursor up
SHIFT + F1 Cursor to upper-left corner
F2 Cursor down
SHIFT + F2 Cursor to lower-left corner
F3 Cursor left
SHIFT + F3 Cursor to start of physical line
F4 Cursor right
SHIFT + F4 Cursor to end of physical line
Edited by ACML, Sun Mar 19, 2017 6:30 PM.
#4 Gunstar OFFLINE
Gunstar
    Gunstar
  • 8,765 posts
Posted Sun Mar 19, 2017 7:20 PM
I love the irony of the 1200XL, as far as I know, the only Atari 8-bit with no PAL edition, yet the only one with a built-in International Character set! I use the function keys for cursor movement and disabling the keyboard and screen (works great to speed up rendering of Super 3D Plotter and ChromaCAD 3D projects) all the time. I wonder if Atarimania has a list hidden away like they do with lists of trackball/mouse programs, keypad programs, etc.
#5 Josť Pereira OFFLINE
Josť Pereira
  • 4,098 posts
Posted Sun Mar 19, 2017 9:57 PM
But my 800XL also had the International letters built in though directly pressing CONTROL it shows the gfxs forms.
What do you mean with that? It shows them first instead of the letters?
Edited by Josť Pereira, Sun Mar 19, 2017 9:58 PM.
#6 Gunstar OFFLINE
Gunstar
    Gunstar
  • 8,765 posts
Posted Mon Mar 20, 2017 7:42 AM
This is an educated guess, but I think that although your 800XL may have the International character set built in, a hold-over from the 1200XL OS, it can't be accessed with keyboard commands, or maybe not at all. You have to press control and F4 at the same time, and since there is no F4 on your 800XL...nada.
Edited by Gunstar, Mon Mar 20, 2017 7:43 AM.
#7 Josť Pereira OFFLINE
Josť Pereira
  • 4,098 posts
Posted Mon Mar 20, 2017 8:03 AM
Only posted because you said "yet the only one with a built-in international character set" ;).
Don't others than XLs also have?
#8 Gunstar OFFLINE
Gunstar
    Gunstar
  • 8,765 posts
Posted Mon Mar 20, 2017 9:19 AM
I guess I worded it wrong, I mean, the only one with a built-in International character set that can be used. ;)
If you add some function keys to your 800XL so you can press CONTROL+F4, then yes, other XL can have an I.C. set.
I could be wrong, but I don't think so. Can YOU access your 800XL I.C. set?
Edited by Gunstar, Mon Mar 20, 2017 9:23 AM.
#9 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 355 posts
Posted Mon Mar 20, 2017 9:51 AM
From what I remember, all XL/XE's can use international character set. POKE 756,204 enables, and POKE 756,224 returns it back to normal ATASCII characters. unless a modified OS uses that area for something else...
#10 Josť Pereira OFFLINE
Josť Pereira
  • 4,098 posts
Posted Mon Mar 20, 2017 10:23 AM
You get always alphabet, numbers and punctation, arithmetic and other symbols together, no need to POKE, those graphic forms (the ones that are displayed on the 65/130XE and XEGS in the front of the bottom three lines of keys).
If you POKE 756,204 then you get all the first and the graphic forms are replaced for the international character set.
Edited by Josť Pereira, Mon Mar 20, 2017 10:41 AM.
#11 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 504 posts
Posted Mon Mar 20, 2017 11:09 AM
This has been a very interesting and educational thread.  The only one that I remember (or think I remembered after I started this thread) was Syncalc.   I'm glad you guys have the
knowledge and are willing to share.  Keep it coming!
Thanks again,
David Milsop
Kingwood, Texas
#12 Gunstar OFFLINE
Gunstar
    Gunstar
  • 8,765 posts
Posted Mon Mar 20, 2017 11:41 AM
Well, it's good to know there is a way to select International Character sets on XL/XE's, but I am certainly glad I can do it far more easily by a couple of key presses and the irony of the only non-international Atari being the only one with such easy access is still valid.
#13 kheller2 OFFLINE
kheller2
  • 1,073 posts
Posted Tue Mar 21, 2017 5:23 AM
So along these lines, what programs made use of the extra LEDs? I swear there was a game that lit up each players turn.
#14 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 504 posts
Posted Tue Mar 21, 2017 11:36 AM
A good question kheller2.  And along with your question, what was Atari's description/reason for the L1 and L2 lights?
David
