Getting A8 Online with Lantronix and 850 Interface
108 replies to this topic
#101 moonlight_mile ONLINE
moonlight_mile
    Chopper Commander
  • 145 posts
Posted Tue Aug 8, 2017 11:25 AM
Is there a way to change the port number on an mss100 from 3001/2001? I have scoured the net and can't seem to find the way to change 3001 to say 7777 or 9876, etc.
Got my answer. Gotta do it on the router side.
#102 moonlight_mile ONLINE
moonlight_mile
    Chopper Commander
  • 145 posts
Posted Wed Aug 9, 2017 9:45 AM
Guys, I am still working on my mss100.
It is not passing anything to the serial device after a signal has been dropped. (The telnet user disconnects).
I have an mss100->gender changer->atari terminal cable->850
It is a bad mss100 or could it be a bad cable?
I traced the pins on my terminal cable and nothing seems to match up to the above pinouts. Here is how my cable is wired up.
Db9. Db25
Pin# 1------->pin #5
Pin# 2------->pin#4
Pin# 3------->pin#3
Pin# 4------->pin#2
Pin# 5------->pin#6
Pin# 6------->pin#20
Pin# 7------->pin#7
Pin# 8------->no pin connection
Pin# 9------->no pin connection
Also inside the cable there are two wires it connected to any pin on the db25 side.
Any help appreciated
#103 DrVenkman OFFLINE
DrVenkman
  • 2,992 posts
  • Back off, man! I'm a scientist.
Posted Wed Aug 9, 2017 10:10 AM
I have the same basic setup but with a P:R:Connection. Works great. Hard to say what’s happening with yours. Did you make you own cable or are you using the Atari Terminal Cable?
#104 moonlight_mile ONLINE
moonlight_mile
    Chopper Commander
  • 145 posts
Posted Wed Aug 9, 2017 10:15 AM
Using a cx-88 atari cable
It works great but on the bbs I am testing if someone disconnects the mss100 doesn't tell the bbs anyone disconnected. That's where my issue is.
#105 Kyle22 OFFLINE
Kyle22
  • 3,301 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Wed Aug 9, 2017 9:02 PM
I have a UDS-10, so I don't know about the MSS100.  I would think there would be some settings you can change relating to Carrier Detect. Make 100% sure that the RS232 CD line is wired properly.
#106 moonlight_mile ONLINE
moonlight_mile
    Chopper Commander
  • 145 posts
Posted Fri Aug 11, 2017 9:25 AM
I jumpered one of the wires in the db9 end of the cable and it works. I really wonder if my "terminal" cable was wired up as a modem cable. But for now it is working. Now if I could only get Express to start sending the "press return" without the connecting party to hit it first I will be golden.
Edited by moonlight_mile, Fri Aug 11, 2017 9:25 AM.
#107 Tillek OFFLINE
Tillek
    Dragonstomper
  • 673 posts
Posted Fri Aug 11, 2017 4:27 PM
The problem with some "terminal cables" and some null modem adapters is that they take the shortcut of not wiring things that they feel the terminals didn't need.
When I tried using TCPSER and the Commodore BBS server, I wired up my own cable (the Jim Brain version) and it seemed to work better for that (I never tried it on my ST BBS, since I used a regular modem cable with a radio shack null adapter, which apparently is better than most null adapters).
The real issue is that some BBS software needs those lines that aren't always hooked up, and some don't.
Now do you have it working the way you like?  Or are you still having issues?
(My next cabling project is to design some way for me to use port 2 so I can go 56k again on my BBS, but somehow fool it into thinking that port one DCD line is high so that Space Empire Elite still works.
#108 moonlight_mile ONLINE
moonlight_mile
    Chopper Commander
  • 145 posts
Posted Fri Aug 11, 2017 6:31 PM
Yup it is working like a charm. Just gotta figure out how to get the bbs to start as soon as it connects without the user hitting return a few times. Not exactly sure how or what I can do about that.
#109 Tillek OFFLINE
Tillek
    Dragonstomper
  • 673 posts
Posted Sat Aug 12, 2017 11:01 AM
I would have to say that's an Express problem as neither one of my BBS's do that.
